Bei meinem Wandthermostat vom Typ HM-TC-IT-WM-W-EU ist das RegL_07. leer. Gleichzeitig ist commState gleich CMD_done_Errors:1.
Hier das Listing vom Gerät:
CUL1_MSGCNT 100440
CUL1_RAWMSG A0C6E84702D4D5400000000C633::-83:CUL1
CUL1_RSSI -83
CUL1_TIME 2026-11-06 12:13:25
DEF 2D4D54
FUUID 61583ee4-f33f-ae46-2483-30f547d26c2ea6d6
IODev CUL1
LASTInputDev CUL1
MSGCNT 100440
NAME Wz_Th
NR 230
NTFY_ORDER 48-Wz_Th
STATE Spannung: ok, 2.7 V
TYPE CUL_HM
channel_01 Wz_Th_Weather
channel_02 Wz_Th_Climate
channel_03 Wz_Th_WindowRec
channel_06 Wz_Th_remote
channel_07 Wz_Th_SwitchTr
disableNotifyFn 1
eventCount 4732
lastMsg No:6E - t:70 s:2D4D54 d:000000 00C633
protCmdDel 1843
protCondBurst on
protLastRcv 2026-11-06 12:13:25
protRcv 100323 last_at:2026-11-06 12:13:25
protRcvB 2 last_at:2026-11-05 12:08:15
protResnd 90 last_at:2026-11-06 11:34:38
protResndFail 45 last_at:2026-11-06 11:47:38
protSnd 1427 last_at:2026-11-06 11:47:35
protSndB 283 last_at:2026-11-06 11:47:32
protState CMDs_done_Errors:1
rssi_CUL1 cnt:249 min:-79 max:-62 avg:-69.61 lst:-66
rssi_at_CUL1 cnt:100440 min:-104 max:-47.5 avg:-81.89 lst:-83
CL:
Authenticated 0
BUF
FD 68
FW_ID 1793963350.95829
LASTACCESS 1793963737.02035
NAME WEB_192.168.2.79_49542
NR 10002855
PEER 192.168.2.79
PORT 49542
SNAME WEB
SSL
STATE Connected
TEMPORARY 1
TYPE FHEMWEB
canAsyncOutput 1
encoding UTF-8
2026-11-06 12:15:34 state Connected
2026-11-06 11:47:32 CommandAccepted yes
2026-11-05 14:32:35 D-firmware 1.3
2026-11-05 14:32:35 D-serialNr LEQ0594414
2026-11-06 11:47:32 IODev CUL1
2026-11-06 11:34:30 PairedTo 0x41189E
2026-11-06 11:34:30 RegL_00. 00:00 01:01 02:01 09:01 0A:41 0B:18 0C:9E 0F:00 11:00 12:16 16:00 18:00 19:00 1A:00
2026-11-06 12:00:01 battery ok
2026-11-06 12:00:01 batteryLevel 2.7
2026-11-06 11:48:32 cfgState ok
2026-11-06 11:47:38 commState CMDs_done_Errors:1
2026-11-06 12:00:01 desired-temp 20.5
2026-11-06 12:00:01 measured-temp 19.8
2025-07-23 15:34:37 powerOn 2025-07-23 15:34:37
2025-07-23 15:34:37 recentStateType info
2026-11-06 11:47:38 state RESPONSE TIMEOUT:RegisterRead
2026-11-05 13:55:31 time-request -
2026-11-04 12:34:22 trigLast fhem:80
RegL_07.:
VAL
helper:
HM_CMDNR 110
PONtest 1
cSnd 0141189E2D4D5400040000000007,0141189E2D4D5400040000000007
cfgStateUpdt 0
lastMsgTm 1793963605.10679
mId 00AD
peerFriend -
peerOpt -:thermostat
regLst 0
rxType 6
supp_Pair_Rep 0
ack:
cmds:
TmplKey :no:1793885313.55792
TmplTs 1793885313.55792
cmdKey 0:1:0::Wz_Th:00AD:00:
cmdLst:
assignHmKey noArg
clear [({msgErrors}|msgEvents|rssi|attack|trigger|register|oldRegs|readings|all)]
deviceRename -newName-
fwUpdate -filename- [-bootTime-]
getConfig noArg
getDevInfo noArg
getRegRaw (List0|List1|List2|List3|List4|List5|List6|List7) [-peerChn-]
inhibit [(on|{off})]
raw -data- [...]
regBulk -list-.-peerChn- -addr1:data1- [-addr2:data2-]...
regSet [(prep|{exec})] -regName- -value- [-peerChn-]
reset noArg
sysTime noArg
tplDel -tplDel-
tplSet_0 -tplChan-
unpair noArg
lst:
condition slider,0,1,255
peer
peerOpt
tplChan
tplDel
tplPeer
rtrvLst:
cmdList [({short}|long)]
deviceInfo [({short}|long)]
list [({normal}|full)]
param -param-
reg -addr- -list- [-peerChn-]
regList noArg
regTable noArg
regVal -addr- -list- [-peerChn-]
saveConfig [-filename-]
tplInfo noArg
expert:
def 0
det 0
raw 1
tpl 0
io:
flgs 0
newChn +2D4D54,00,00,00
nextSend 1793963605.20647
rxt 0
vccu
p:
2D4D54
00
00
00
prefIO:
mRssi:
mNo 6E
io:
CUL1:
-81
-81
peerIDsH:
prt:
awake 0
bErr 0
brstWu 0
sProc 0
tryMsg:
q:
qReqConf 02,03,06,07
qReqStat
regCollect:
role:
dev 1
prs 1
rssi:
CUL1:
avg -69.6104417670683
cnt 249
lst -66
max -62
min -79
at_CUL1:
avg -81.8954749103946
cnt 100440
lst -83
max -47.5
min -104
shRegW:
07 02
shadowReg:
tmpl:
IODev CUL1
autoReadReg 5_readMissing
event-min-interval measured-temp:300
event-on-change-reading .*
event-on-update-reading measured-temp
expert rawReg
firmware 1.3
group Heizung-Thermostat
model HM-TC-IT-WM-W-EU
mqttPublish battery:topic={"/SmartHome/Wz/$device/$name"}
msgRepeat 1
room Raum->Wohnzimmer
serialNr LEQ0594414
stateFormat Spannung: battery, batteryLevel V
subType thermostat
verbose 0
webCmd getConfig:clear msgEvents
Ich brauche da Hilfe:
Gruß Eberhard
