ich versuche ne Zeitschaltung meiner Weihnachtsbeleuchtung hin zubekommen,
habe auch ein code schnipsel gefunden den ich nutzen möchte.
define .... WeekdayTimer ...
mein problem ist das in fhem commandref das helper modul fehlt
Contents
Introduction
Fhem command types
Device specification
Fhem commands
attr backup CULflash createlog define delete deleteattr deletereading displayattr fheminfo get getstate ?,help include inform JsonList list modify notice quit reload rename rereadcfg save set setdefaultattr setreading setstate shutdown sleep trigger update usb version xmllist
Devices
global
ALL3076 ALL4000T ALL4027 BS CM11 CUL CUL_EM CUL_FHTTK CUL_HM CUL_HOERMANN CUL_IR CUL_MAX CUL_RFR CUL_TX CUL_WS ECMD ECMDDevice EGPM EGPM2LAN EIB EM EMEM EMGZ EMWZ ENIGMA2 ESA2000 EnOcean FBAHA FBDECT FHT FHT8V FHZ FRM FRM_AD FRM_I2C FRM_IN FRM_LCD FRM_OUT FRM_PWM FRM_SERVO FS20 GDS HMLAN HMS HMinfo HTTPSRV HUEBridge HUEDevice I2C_BMP180 IPCAM IPWE IT Itach_Relay JeeLink KM271 KS300 LGTV LIRC LISTENLIVE LUXTRONIK2 M232 M232Counter M232Voltage MAX MAXLAN MSG MSGFile MSGMail NetIO230B OREGON OWAD OWCOUNT OWDevice OWFS OWID OWLCD OWMULTI OWSWITCH OWServer OWTEMP OWTHERM OWX PCA301 PIFACE POKEYS RFXCOM RFXMETER RFXX10REC RSS RandomTimer Revolt SCIVT SISPM SIS_PMS SML STV SWAP SWAP_0000002200000003 SYSSTAT TCM TRX TRX_ELSE TRX_LIGHT TRX_SECURITY TRX_WEATHER TUL TellStick USBWX USF1000 VIERA VantagePro2 WEBCOUNT WEBIO WEBIO_12DIGITAL WEBTHERM WS2000 WS300 WS3600 Weather X10 XmlList YAMAHA_AVR ZWDongle ZWave mailcheck panStamp xxLG7000
Helper modules
at autocreate average Calendar DbLog dewpoint dummy eventTypes FHEM2FHEM FHEMWEB FB_CALLMONITOR FileLog FLOORPLAN HCS Heating_Control holiday LightScene notify openweathermap PID PRESENCE PachLog readingsGroup remotecontrol SUNRISE_EL sequence speedtest structure SVG telnet Twilight THRESHOLD Utils watchdog weblink WOL
und wenn ich mit "Define ... Weekdaytimer..." aufrufe kommt folgende fehler Meldung:
Unknown module WeekdayTimer, choose one of ALL3076 ALL4000T ALL4027 BS CM11 CUL CUL_EM CUL_FHTTK CUL_HM CUL_HOERMANN CUL_IR CUL_MAX CUL_RFR CUL_TX CUL_WS CULflash Calendar DbLog ECMD ECMDDevice EGPM EGPM2LAN EIB EM EMEM EMGZ EMWZ ENIGMA2 ESA2000 EnOcean FBAHA FBDECT FB_CALLMONITOR FHEM2FHEM FHEMWEB FHT FHT8V FHZ FLOORPLAN FRM FRM_AD FRM_I2C FRM_IN FRM_LCD FRM_OUT FRM_PWM FRM_SERVO FS20 FileLog GDS HCS HMLAN HMS HMinfo HTTPSRV HUEBridge HUEDevice Heating_Control I2C_BMP180 IPCAM IPWE IT Itach_Relay JeeLink JsonList KM271 KS300 LGTV LIRC LISTENLIVE LUXTRONIK2 LightScene M232 M232Counter M232Voltage MAX MAXLAN MSG MSGFile MSGMail NetIO230B OREGON OWAD OWCOUNT OWDevice OWFS OWID OWLCD OWMULTI OWSWITCH OWServer OWTEMP OWTHERM OWX PCA301 PID PIFACE POKEYS PRESENCE PachLog RFXCOM RFXMETER RFXX10REC RSS RandomTimer Revolt SCIVT SISPM SIS_PMS SML STV SVG SWAP SWAP_0000002200000003 SYSSTAT TCM THRESHOLD TRX TRX_ELSE TRX_LIGHT TRX_SECURITY TRX_WEATHER TUL TellStick Twilight USBWX USF1000 VIERA VantagePro2 WEBCOUNT WEBIO WEBIO_12DIGITAL WEBTHERM WOL WS2000 WS300 WS3600 Weather X10 YAMAHA_AVR ZWDongle ZWave at autocreate average backup dewpoint dummy eventTypes fheminfo holiday mailcheck notify openweathermap panStamp readingsGroup remotecontrol sequence speedtest structure telnet watchdog weblink xxLG7000
Ich habe eine Fb 7390 und habe "fhem-5.5-fb7390.image" von der seite "http://fhem.de/fhem_DE.html" benutzt
mfg
ingo
http://fhem.de/commandref.html#WeekdayTimer (http://fhem.de/commandref.html#WeekdayTimer)
ich würde mal ein update machen :)
was Link auf die aktuelle Refernz soll, erschliest sich mir auch nicht ?
Hallo und Danke für die schnelle Antwort
das ist mein problem das helper modul ist nicht vorhanden!
den link wollte ich nur zur info welches image ich nutze
mfg
ingo
das Image ist 2 Monate alt
update ist dein Freund ;)
hallo
update gibt folgende Meldung
update-20130127-001 confirmed on 2013-12-16 17:41:26: 1
fehler meldung wenn ich weekdaytimer benutze ist:
in der log steht der eintrag
2013.12.16 17:41:26 1: notice update-20130127-001 confirmed on 2013-12-16 17:41:26: 1
wenn du es confirm hast :) ,
nochmal update, das dauert aber eine weile wegen backup, es sei denn du hast es ausgeschalten
und falls das auch nicht hilft, update force
da wird ein zwangsupdate von allen dateien gemacht
jetzt klappt es
DANKE DANKE DANKE ;D ;D ;D ;D ;D ;D ;D ;D :D :D :D :D :D :D :D :D
