FHEM - Hausautomations-Systeme => Homematic => Thema gestartet von: ChrisW am 16 April 2014, 21:57:39
Titel: Immer Verbindung Verloren
Beitrag von: ChrisW am 16 April 2014, 21:57:39
Seit ein paar Update leider weiss ich nicht genau seit wann verabschiedet sich der HMLAN neustes Update heute ...
2014-04-16 21:55:41 CUL_HM CUL_HM_HM_ES_PMSw1_Pl_24ACA3 ResndFail
2014-04-16 21:55:41 CUL_HM CUL_HM_HM_ES_PMSw1_Pl_24ACA3 CMDs_done_Errors:1
2014-04-16 21:55:41 CUL_HM CUL_HM_HM_ES_PMSw1_Pl_24ACA3 MISSING ACK
2014-04-16 21:55:43 CUL_HM CUL_HM_HM_ES_PMSw1_Pl_24B23E ResndFail
2014-04-16 21:55:43 CUL_HM CUL_HM_HM_ES_PMSw1_Pl_24B23E CMDs_done_Errors:1
2014-04-16 21:55:43 CUL_HM CUL_HM_HM_ES_PMSw1_Pl_24B23E MISSING ACK
2014-04-16 21:55:46 HMLAN HMLAN cond: timeout
2014-04-16 21:55:46 HMLAN HMLAN Xmit-Events: timeout:1
2014-04-16 21:55:46 HMLAN HMLAN prot_timeout: last
2014-04-16 21:55:46 HMLAN HMLAN DISCONNECTED
2014-04-16 21:55:46 HMLAN HMLAN cond: disconnected
2014-04-16 21:55:46 HMLAN HMLAN Xmit-Events: disconnected:1
2014-04-16 21:55:46 HMLAN HMLAN prot_disconnected: last
ZitatLOG:
014.04.16 21:53:36 3: Device CUL_HM_HM_ES_PMSw1_Pl_24ACA3 added to ActionDetector with 000:10 time
2014.04.16 21:53:36 3: Device CUL_HM_HM_ES_PMSw1_Pl_24B23E added to ActionDetector with 000:10 time
2014.04.16 21:55:17 1: 192.168.2.32:1000 reappeared (HMLAN)
2014.04.16 21:55:17 1: HMLAN_Parse: HMLAN new condition init
2014.04.16 21:55:17 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_24ACA3_Sw statusRequest
2014.04.16 21:55:18 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_24ACA3_Pwr statusRequest
2014.04.16 21:55:19 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_24ACA3_SenPwr statusRequest
2014.04.16 21:55:19 1: HMLAN_Parse: HMLAN new condition ok
2014.04.16 21:55:20 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_24B23E_Sw statusRequest
2014.04.16 21:55:21 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_24B23E_Pwr statusRequest
2014.04.16 21:55:22 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_24B23E_SenPwr statusRequest
2014.04.16 21:55:24 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_24B23E_SenI statusRequest
2014.04.16 21:55:25 3: CUL_HM set CUL_HM_HM_ES_PMSw1_Pl_24B23E_SenU statusRequest
2014.04.16 21:55:26 3: CUL_HM set HM1_FunkSteckdose statusRequest
2014.04.16 21:55:46 1: HMLAN_Parse: HMLAN new condition timeout
2014.04.16 21:55:46 1: 192.168.2.32:1000 disconnected, waiting to reappear
2014.04.16 21:55:46 1: HMLAN_Parse: HMLAN new condition disconnected
Titel: Antw:Immer Verbindung Verloren
Beitrag von: martinp876 am 17 April 2014, 07:27:45
was steht im HMLAN? Kommen die keepalives?
was sagt apptime?
hast du prozesse, die lange laufen?
Beitrag von: ChrisW am 17 April 2014, 09:52:31
Hier mal die HMLAN Infos
Beitrag von: martinp876 am 17 April 2014, 12:54:13
schöner als ein Bild ist immer der Text ;-)
es wurde also ein timeout gemeldet, dann ein disconnect.
Es wurde eine Message min 7,5 sec verzögert
keepalive ist min einmal 3,1 sec verzögert gewesen.
Ich tippe auf einen Delayin deinem System.
Starte einmal "apptime" - möglichst kurz vor dem erwarteten Problem
Beitrag von: ChrisW am 17 April 2014, 14:03:44
Bitte ein paar Infos was genau ich machen soll ;)
Beitrag von: martinp876 am 18 April 2014, 12:08:03
apptime steht im Commandref - das solltest du lesen.
mache
apptime
=> die Zietberechnung wird gestartet
apptime
=> die Zeiten werden ausgegeben
apptime clear
=> die messungen werden gelöscht und es wird neu gezählt.
Aus den Ergebnissen von apptime kann man evtl sehen, wer in FHEM bummelt.
Du musst schon probieren, es selbst zu interpretieren, da es von deiner Installation abhängt. ggf kannst du auch einschränken,wann es passiert, apptime zu diesen Zeitpunkt starten/rücksetzten und beobachten
Beitrag von: ChrisW am 18 April 2014, 13:19:39
hmm nichts was auffällig ist finde ich ... ABER hab nun mal den HMLAN direkt angeschlossen vorher über DLAN scheint nun Stabiel zu laufen
