FHEM - Hausautomations-Systeme => Homematic => Thema gestartet von: betateilchen am 14 Mai 2014, 23:18:13
Titel: Was um alles in der Welt passiert da???
Beitrag von: betateilchen am 14 Mai 2014, 23:18:13
2014-05-14_23:14:32 powermeter CMDs_done
2014-05-14_23:14:40 powermeter CMDs_done
2014-05-14_23:14:41 powermeter CMDs_done
2014-05-14_23:14:42 powermeter CMDs_done
2014-05-14_23:14:43 powermeter CMDs_done
2014-05-14_23:14:48 powermeter CMDs_done
2014-05-14_23:14:49 powermeter CMDs_done
2014-05-14_23:14:50 powermeter CMDs_done
2014-05-14_23:14:51 powermeter CMDs_done
2014-05-14_23:14:56 powermeter CMDs_done
2014-05-14_23:14:57 powermeter CMDs_done
2014-05-14_23:14:58 powermeter CMDs_done
2014-05-14_23:14:59 powermeter CMDs_done
2014-05-14_23:15:04 powermeter CMDs_done
2014-05-14_23:15:05 powermeter CMDs_done
2014-05-14_23:15:06 powermeter CMDs_done
2014-05-14_23:15:12 powermeter CMDs_done
2014-05-14_23:15:13 powermeter CMDs_done
2014-05-14_23:15:14 powermeter CMDs_done
2014-05-14_23:15:15 powermeter CMDs_done
2014-05-14_23:15:20 powermeter CMDs_done
2014-05-14_23:15:21 powermeter CMDs_done
2014-05-14_23:15:22 powermeter CMDs_done
2014-05-14_23:15:23 powermeter CMDs_done
2014-05-14_23:15:28 powermeter CMDs_done
2014-05-14_23:15:29 powermeter CMDs_done
2014-05-14_23:15:30 powermeter CMDs_done
2014-05-14_23:15:36 powermeter CMDs_done
2014-05-14_23:15:37 powermeter CMDs_done
2014-05-14_23:15:38 powermeter CMDs_done
2014-05-14_23:15:44 powermeter CMDs_done
2014-05-14_23:15:52 powermeter CMDs_done
2014-05-14_23:15:53 powermeter CMDs_done
2014-05-14_23:15:54 powermeter CMDs_done
2014-05-14_23:15:55 powermeter CMDs_done
2014-05-14_23:16:00 powermeter CMDs_done
2014-05-14_23:16:01 powermeter CMDs_done
2014-05-14_23:16:02 powermeter CMDs_done
2014-05-14_23:16:03 powermeter CMDs_done
2014-05-14_23:16:08 powermeter CMDs_done
2014-05-14_23:16:09 powermeter CMDs_done
2014-05-14_23:16:10 powermeter CMDs_done
2014-05-14_23:16:11 powermeter CMDs_done
2014-05-14_23:16:16 powermeter CMDs_done
2014-05-14_23:16:17 powermeter CMDs_done
2014-05-14_23:16:18 powermeter CMDs_done
2014-05-14_23:16:19 powermeter CMDs_done
2014-05-14_23:16:24 powermeter CMDs_done
2014-05-14_23:16:25 powermeter CMDs_done
2014-05-14_23:16:26 powermeter CMDs_done
2014-05-14_23:16:27 powermeter CMDs_done
2014-05-14_23:16:32 powermeter CMDs_done
2014-05-14_23:16:40 powermeter CMDs_done
2014-05-14_23:16:41 powermeter CMDs_done
2014-05-14_23:16:42 powermeter CMDs_done
2014-05-14_23:16:43 powermeter CMDs_done
2014-05-14_23:16:48 powermeter CMDs_done
2014-05-14_23:16:49 powermeter CMDs_done
2014-05-14_23:16:50 powermeter CMDs_done
2014-05-14_23:16:51 powermeter CMDs_done
2014-05-14_23:16:56 powermeter CMDs_done
2014-05-14_23:16:57 powermeter CMDs_done
2014-05-14_23:16:58 powermeter CMDs_done
2014-05-14_23:16:59 powermeter CMDs_done
2014-05-14_23:17:04 powermeter CMDs_done
2014-05-14_23:17:05 powermeter CMDs_done
2014-05-14_23:17:08 powermeter CMDs_done
2014-05-14_23:17:09 powermeter CMDs_done
2014-05-14_23:17:12 powermeter CMDs_done
2014-05-14_23:17:13 powermeter CMDs_done
2014-05-14_23:17:14 powermeter CMDs_done
2014-05-14_23:17:15 powermeter CMDs_done
2014-05-14_23:17:20 powermeter CMDs_done
2014-05-14_23:17:21 powermeter CMDs_done
2014-05-14_23:17:22 powermeter CMDs_done
2014-05-14_23:17:23 powermeter CMDs_done
2014-05-14_23:17:28 powermeter CMDs_done
2014-05-14_23:17:29 powermeter CMDs_done
2014-05-14_23:17:36 powermeter CMDs_done
2014-05-14_23:17:37 powermeter CMDs_done
2014-05-14_23:17:38 powermeter CMDs_done
2014-05-14_23:17:39 powermeter CMDs_done
2014-05-14_23:17:44 powermeter CMDs_done
2014-05-14_23:17:45 powermeter CMDs_done
   CFGFN
   DEF        24A73E
   IODev      wz_HMUSB
   LASTInputDev az_HMUSB
   MSGCNT     4749
   NAME       powermeter
   NR         62
   STATE      CMDs_done
   TYPE       CUL_HM
   az_HMUSB_MSGCNT 2379
   az_HMUSB_RAWMSG E24A73E,0000,1FBB3022,FF,FFCC,AE845E24A73E0000008060A200055200710915FE
   az_HMUSB_RSSI -52
   az_HMUSB_TIME 2014-05-14 23:16:53
   channel_01 powermeter_Sw
   channel_02 powermeter_Pwr
   channel_03 powermeter_SenPwr
   channel_04 powermeter_SenI
   channel_05 powermeter_SenU
   channel_06 powermeter_SenF
   lastMsg    No:AE - t:5E s:24A73E d:000000 8060A200055200710915FE
   protLastRcv 2014-05-14 23:16:53
   protSnd    2317 last_at:2014-05-14 23:16:51
   protState  CMDs_done
   rssi_at_az_HMUSB avg:-53.09 min:-57 max:-51 lst:-52 cnt:2425
   rssi_at_wz_HMUSB avg:-73.33 min:-81 max:-69 lst:-75 cnt:2416
   wz_HMUSB_MSGCNT 2370
   wz_HMUSB_RAWMSG E24A73E,0000,5D737297,FF,FFB4,EAA45F24A73E1270008060A2000553006F0916FD
   wz_HMUSB_RSSI -76
   wz_HMUSB_TIME 2014-05-14 23:16:51
   Readings:
     2014-05-14 19:38:18   Activity        alive
     2014-04-13 15:27:06   D-firmware      1.5
     2014-04-13 15:27:06   D-serialNr      KEQ0966683
     2014-04-13 15:40:30   PairedTo        0x127000
     2014-04-13 15:40:30   R-intKeyVisib   visib
     2014-04-13 15:40:30   R-localResDis   off
     2014-04-13 15:40:30   R-pairCentral   0x127000
     2014-04-13 15:40:30   RegL_00:        02:81 0A:12 0B:70 0C:00 18:00 00:00
     2014-05-14 23:16:51   state           CMDs_done
   Helper:
     mId        00AC
     rxType     1
     Io:
       newChn     +24A73E,00,01,1E
       nextSend   1400102213.12703
     Mrssi:
       mNo        AE
       max        az_HMUSB
       Io:
         az_HMUSB   -52
         wz_HMUSB   -73
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       dev        1
     Rssi:
       At_az_hmusb:
         avg        -53.0973195876288
         cnt        2425
         lst        -52
         max        -51
         min        -57
       At_wz_hmusb:
         avg        -73.3336092715232
         cnt        2416
         lst        -75
         max        -69
         min        -81
     Shadowreg:
   IODev      wz_HMUSB
   actCycle   000:10
   actStatus  alive
   autoReadReg 0_off
   expert     2_full
   firmware   1.5
   group      CUL_HM
   model      HM-ES-PMSw1-Pl
   room       95 PowerMeter
   serialNr   KEQ0966683
   subType    powerMeter
   webCmd     getconfig
Titel: Antw:Was um alles in der Welt passiert da???
Beitrag von: martinp876 am 15 Mai 2014, 10:57:29
sorry, keine Ahnung. Welche Kommandos werden gesendet? Rohmessags bitte.
Seit wann ist dass de Fall?
Beitrag von: betateilchen am 15 Mai 2014, 11:11:19
Seit gestern. Und ich hab keine Lust mehr, mich dauernd wegen Homematic rumzuärgern.
