FHEM - Hausautomations-Systeme => ZWave => Thema gestartet von: cmillsy am 02 Juli 2014, 12:53:18
Titel: multi sensor (AEON LABS) reports humidity wrong
Beitrag von: cmillsy am 02 Juli 2014, 12:53:18
Hi. Since an update to the zwave module the humidity reported is wrong (13312%). When i first got the sensor there wasn't any handling so i changed the module to suit as so:
parse => { "06310501(..)(....)" => 'sprintf("temperature:%0.1f %s",'.
                      'hex($2)/(10**int(hex($1)/32)), '.
                      'hex($1)&8 ? "F":"C")',
               "06310505(..)(..)" => 'sprintf("humidity:%0.1f %", '.
                      'hex($2)/(10**int(hex($1)/32)))'},},
This worked fine for my sensor. Since the update the humidity is reported incorrectly.
Titel: Antw:multi sensor (AEON LABS) reports humidity wrong
Beitrag von: rudolfkoenig am 06 Juli 2014, 14:58:21
According to the spec, SENSOR_MULTILEVEL messages contain beside the value itself the bytecount of the value, precision and scale. ZWAVE.pm takes all these parameter into account to format the value.
Could you please send me the raw message, so I can check if the implementation is wrong, or your sensor is ignoring the spec. In the latter case you could help by using a userReading to reformat the message.
Beitrag von: cmillsy am 10 Juli 2014, 11:44:27
here's a section from my log file
SW: 06
2014.07.10 10:33:43 5: ZWDongle_Read ZWDongle_1: 00040004063105030a03e8
2014.07.10 10:33:43 5: ZWDongle_1 dispatch 00040004063105030a03e8
2014.07.10 10:33:43 4: ZWDongle_1 CMD:APPLICATION_COMMAND_HANDLER ID:04 ARG:063105030a03e8
2014.07.10 10:33:44 5: ZWDongle/RAW: /010c0004080406310505013600fb
2014.07.10 10:33:44 5: SW: 06
2014.07.10 10:33:44 5: ZWDongle_Read ZWDongle_1: 0004080406310505013600
2014.07.10 10:33:44 5: ZWDongle_1 dispatch 0004080406310505013600
2014.07.10 10:33:44 4: ZWDongle_1 CMD:APPLICATION_COMMAND_HANDLER ID:04 ARG:06310505013600
2014.07.10 10:33:44 5: Triggering pir (1 changes)
2014.07.10 10:33:44 5: Notify loop for pir humidity: 13568 %
2014.07.10 10:33:44 4: eventTypes: ZWave pir humidity: 13568 % -> humidity: .* %
2014.07.10 10:33:44 5: ZWDongle/RAW: /010c0004000406310505013600f3
I've also attached a pdf which shows the spec for the Aoen Labs multi sensor
Beitrag von: rudolfkoenig am 11 Juli 2014, 16:15:22
The sensor sends two-bytes as value, but it flags it as one-byte.
FHEM ignored (partly) this length-information up till now, but I changed that.
The change is in the SVN repository, and available after tomorrow 8AM via update.
Beitrag von: cmillsy am 14 Juli 2014, 11:48:21
THanks. That solved it!   :)
