create log message with hint to LaCrossePairForSec if a LaCrosse message is received, LaCrossePairForSec is not set and no LaCrosse device is defined
create log message with hint to LaCrossePairForSec if a LaCrosse message is received, LaCrossePairForSec is not set and no LaCrosse device is definedView Changes
Source: create log message with hint to LaCrossePairForSec if a LaCrosse message is received, LaCrossePairForSec is not set and no LaCrosse device is defined (http://sourceforge.net/p/fhem/code/6513/)
