FHEM - Anwendungen => Multimedia => Thema gestartet von: mattwire am 06 Oktober 2014, 23:52:56
Titel: Patch: Samsung TV (STV) voll command Leiste
Beitrag von: mattwire am 06 Oktober 2014, 23:52:56
Hier gibts ein Patch fuer Die VollLeiste der IPKommande Der Samsung TV (Quelle: http://openremote.org/display/docs/OpenRemote+2.0+How+To+-+Samsung+TV+Remote (http://openremote.org/display/docs/OpenRemote+2.0+How+To+-+Samsung+TV+Remote)
diff --git a/70_STV.pm b/70_STV.pm
index 3b9f06b..3dc8793 100644
--- a/70_STV.pm
+++ b/70_STV.pm
@@ -164,13 +164,27 @@ sub STV_Define($$)
   if ( $hash->{Port} eq 55000 ){
-      $hash->{".validcommands"} = "0 1 2 3 4 5 6 7 8 9 UP DOWN LEFT RIGHT ENTER ".
-                    "MENU PRECH GUIDE INFO RETURN CH_LIST EXIT ".
-                    "SOURCE AD PICTURE_SIZE VOLUP VOLDOWN MUTE ".
-                    "TOOLS POWEROFF CHUP CHDOWN CONTENTS W_LINK ".
-                    "RSS MTS SRS CAPTION TOPMENU SLEEP ESAVING ".
-                    "PLAY PAUSE REWIND FF REC STOP ".
-                    "TV HDMI PIP_ONOFF ASPECT EXT20";
+      $hash->{".validcommands"} = "0 1 2 3 4 5 6 7 8 9 11 12 3SPEED 4_3 16_9 AD ADDDEL ALT_MHP ANGLE ".
+"ANTENA ANYNET ANYVIEW APP_LIST ASPECT AUTO_ARC_ANTENNA_AIR AUTO_ARC_ANTENNA_CABLE AUTO_ARC_ANTENNA_SATELLITE ".
+"AUTO_ARC_ANYNET_AUTO_START AUTO_ARC_ANYNET_MODE_OK AUTO_ARC_AUTOCOLOR_FAIL AUTO_ARC_AUTOCOLOR_SUCCESS ".
+"AUTO_ARC_CAPTION_ENG AUTO_ARC_CAPTION_KOR AUTO_ARC_CAPTION_OFF AUTO_ARC_CAPTION_ON AUTO_ARC_C_FORCE_AGING ".
+"AUTO_ARC_JACK_IDENT AUTO_ARC_LNA_OFF AUTO_ARC_LNA_ON AUTO_ARC_PIP_CH_CHANGE AUTO_ARC_PIP_DOUBLE ".
+"AUTO_ARC_PIP_LARGE AUTO_ARC_PIP_LEFT_BOTTOM AUTO_ARC_PIP_LEFT_TOP AUTO_ARC_PIP_RIGHT_BOTTOM ".
+"AUTO_ARC_PIP_RIGHT_TOP AUTO_ARC_PIP_SMALL AUTO_ARC_PIP_SOURCE_CHANGE AUTO_ARC_PIP_WIDE AUTO_ARC_RESET ".
+"AUTO_ARC_USBJACK_INSPECT AUTO_FORMAT AUTO_PROGRAM AV1 AV2 AV3 BACK_MHP BOOKMARK CALLER_ID CAPTION CATV_MODE ".
+"CHDOWN CHUP CH_LIST CLEAR CLOCK_DISPLAY COMPONENT1 COMPONENT2 CONTENTS CONVERGENCE CONVERT_AUDIO_MAINSUB ".
+"CUSTOM CYAN DEVICE_CONNECT DISC_MENU DMA DNET DNIe DNSe DOOR DOWN DSS_MODE DTV DTV_LINK DTV_SIGNAL DVD_MODE ".
+"DVI DVR DVR_MENU DYNAMIC ENTER ENTERTAINMENT ESAVING EXIT EXT1 EXT2 EXT3 EXT4 EXT5 EXT6 EXT7 EXT8 EXT9 EXT10 ".
+"EXT11 EXT12 EXT13 EXT14 EXT15 EXT16 EXT17 EXT18 EXT19 EXT20 EXT21 EXT22 EXT23 EXT24 EXT25 EXT26 EXT27 EXT28 ".
+"EXT29 EXT30 EXT31 EXT32 EXT33 EXT34 EXT35 EXT36 EXT37 EXT38 EXT39 EXT40 EXT41 FACTORY FAVCH FF FF_ FM_RADIO ".
+"GAME GREEN GUIDE HDMI HDMI1 HDMI2 HDMI3 HDMI4 HELP HOME ID_INPUT ID_SETUP INFO INSTANT_REPLAY LEFT LINK LIVE ".
+"MAGIC_BRIGHT MAGIC_CHANNEL MDC MENU MIC MORE MOVIE1 MS MTS MUTE NINE_SEPERATE OPEN PANNEL_CHDOWN PANNEL_CHUP ".
+"PANNEL_ENTER PANNEL_MENU PANNEL_POWER PANNEL_SOURCE PANNEL_VOLDOW PANNEL_VOLUP PANORAMA PAUSE PCMODE ".
+"PERPECT_FOCUS PICTURE_SIZE PIP_CHDOWN PIP_CHUP PIP_ONOFF PIP_SCAN PIP_SIZE PIP_SWAP PLAY PLUS100 PMODE POWER ".
+"POWEROFF POWERON PRECH PRINT PROGRAM QUICK_REPLAY REC RED REPEAT RESERVED1 RETURN REWIND REWIND_ RIGHT RSS ".
+"RSURF SCALE SEFFECT SETUP_CLOCK_TIMER SLEEP SOUND_MODE SOURCE SRS STANDARD STB_MODE STILL_PICTURE STOP ".
+"SUB_TITLE SVIDEO1 SVIDEO2 SVIDEO3 TOOLS TOPMENU TTX_MIX TTX_SUBFACE TURBO TV TV_MODE UP VCHIP VCR_MODE ".
+"VOLDOWN VOLUP WHEEL_LEFT WHEEL_RIGHT W_LINK YELLOW ZOOM1 ZOOM2 ZOOM_IN ZOOM_MOVE ZOOM_OUT";
     my $system = $^O;
     my $result;
     if($system =~ m/Win/) {
Titel: Antw:Patch: Samsung TV (STV) voll command Leiste
Beitrag von: Zwiebel am 12 Oktober 2014, 14:47:05
Hallo mattwire,
ich hab den patch von dir erst jetzt gesehen! Sollte ab morgen per update zur verfügung stehen.
Bitte um meldung falls es nicht funktioniert, ich kann das nicht überprüfen.
Zwiebel
