ich habe aus versehen den channel 4 eines meiner HM-CC-RT-DN gelöscht, wie bekomme ich den jetzt zurück?
List sieht jetzt so aus:
DEF 22170C
IODev HmLanAdapter
NAME HeizungFenster
NR 38
STATE T: 22.5 desired: 20.0 valve: 0
TYPE CUL_HM
channel_01 HeizungFenster_Weather
channel_02 HeizungFenster_Climate
channel_03 HeizungFenster_WindowRec
channel_05 HeizungFenster_ClimaTeam
channel_06 HeizungFenster_remote
Readings:
2014-11-21 21:01:01 Activity alive
2014-11-21 19:47:14 CommandAccepted yes
2014-09-16 22:22:16 D-firmware 1.0
2014-09-16 22:22:16 D-serialNr KEQ0511429
2014-09-16 22:07:51 PairedTo 0x41
2014-09-16 22:07:51 R-backOnTime 10 s
2014-09-16 22:07:51 R-btnLock unlock
2014-09-16 22:07:51 R-burstRx on
2014-09-16 22:07:51 R-cyclicInfoMsg on
2014-09-16 22:07:51 R-cyclicInfoMsgDis 0
2014-09-16 22:07:51 R-globalBtnLock off
2014-09-16 22:07:51 R-intKeyVisib invisib
2014-09-16 22:07:51 R-localResDis off
2014-09-16 22:07:51 R-lowBatLimitRT 2.1 V
2014-09-16 22:07:51 R-modusBtnLock off
2014-09-16 22:07:51 R-pairCentral 0x41
2014-09-16 22:07:51 RegL_00: 01:01 02:01 09:01 0A:00 0B:00 0C:41 0E:0A 0F:00 11:00 12:15 16:00 18:00 19:00 1A:00 00:00
2014-11-21 21:00:07 ValvePosition 0
2014-11-21 21:00:07 actuator 0
2014-09-16 22:19:41 battery ok
2014-11-21 21:00:07 batteryLevel 2.7
2014-11-21 21:00:07 boostTime -
2014-11-21 21:00:07 controlMode manual
2014-11-21 21:00:07 desired-temp 20.0
2014-11-21 21:00:07 measured-temp 22.5
2014-11-21 21:00:07 motorErr ok
2014-11-21 21:00:07 partyEnd -
2014-11-21 21:00:07 partyStart -
2014-11-21 21:00:07 partyTemp -
2014-11-21 21:00:07 state T: 22.5 desired: 20.0 valve: 0
2014-11-20 11:54:10 time-request -
Helper:
mId 0095
rxType 140
Io:
newChn +22170C,00,01,00
prefIO
rxt 2
vccu
p:
22170C
00
01
00
Mrssi:
mNo
Prt:
bErr 0
sProc 0
Q:
qReqConf
qReqStat
Role:
dev 1
Shregw:
07 04
IODev HmLanAdapter
actCycle 000:10
actStatus alive
autoReadReg 4_reqStatus
expert 2_full
firmware 1.0
model HM-CC-RT-DN
room Wohnzimmer
serialNr KEQ0511429
subType thermostat
webCmd getConfig:burstXmit
FHEM und den HM-CC-RT-DN in Pairing modus Versetzen
Das wars schon, super danke
Hab dann doch noch ein Problem....
Der FileLog und damit der Plot sind weg.
Jetzt hab ich den FileLog über ein
define HeizungFensterLog FileLog HeizungFenster_Log HeizungFenster_Clima neuangelegt.
Wenn ich aber einen Plot anlegen will kommt immer das keine Daten im Log sind.
Was hab ich falsch gemacht? Das list des LOgFiles sieht so aus:
Zitat von: screenshot
To add a regexp an eventTypes definationis needed
Alternativ http://fhem.de/commandref#createlog (http://fhem.de/commandref#createlog)
Oder ein backup wiederherstellen bevor du den Thermostat gelöscht hast.
Das wiederherstellen ist das Problem, das ich viele änderungen durchgeführt habe bevor ich gemerkt habe das es diesen fehler gibt.....
Wie nutze ich createlog? in meinem autocreate find ich kein createlog!?
ZitatTo add a regexp an eventTypes definationis needed
Damit hats geklappt, nun ist es gelöst :-)
