Hallo *,
habe erfolgreich meinen Fensterkontakt (optisch) in Betrieb genommen:
Readings:
2014-12-13 06:34:34 Activity alive
2014-12-09 20:44:12 CommandAccepted yes
2014-12-09 20:44:10 D-firmware 1.0
2014-12-09 20:44:10 D-serialNr LEQ0919250
2014-12-09 20:44:12 PairedTo 0x29A083
2014-12-09 20:44:12 R-cyclicInfoMsg on
2014-12-09 20:44:13 R-eventDlyTime 0 s
2014-12-09 20:44:13 R-msgScPosA open
2014-12-09 20:44:13 R-msgScPosB closed
2014-12-09 20:44:12 R-pairCentral 0x29A083
2014-12-09 20:44:12 R-sabotageMsg on
2014-12-09 20:44:13 R-sign on
2014-12-09 20:44:12 R-transmDevTryMax 6
2014-12-09 20:44:13 R-transmitTryMax 6
2014-12-09 20:44:12 RegL_00: 02:01 09:01 0A:29 0B:A0 0C:83 10:01 14:06 00:00
2014-12-09 20:44:13 RegL_01: 08:01 20:9C 21:00 30:06 00:00
2014-12-09 20:44:11 aesKeyNbr 00
2014-12-14 19:27:42 alive yes
2014-12-14 19:27:42 battery ok
2014-12-14 19:27:42 contact closed (to HMLAN1)
2014-12-14 19:27:42 recentStateType info
2014-12-14 19:27:42 sabotageError off
2014-12-14 19:27:42 state closed
2014-12-14 16:49:31 trigDst_29A083 noConfig
2014-12-14 16:49:31 trigger_cnt 160
Mich stört allerdings, das diese Meldung (alive: yes)
ungefähr jede Stunde erscheint.
2014-12-14_16:49:31 WF.tuerkontakt contact: closed (to HMLAN1)
2014-12-14_17:31:39 WF.tuerkontakt alive: yes
2014-12-14_17:31:39 WF.tuerkontakt battery: ok
2014-12-14_17:31:39 WF.tuerkontakt sabotageError: off
2014-12-14_17:31:39 WF.tuerkontakt closed
2014-12-14_17:31:39 WF.tuerkontakt contact: closed (to HMLAN1)
2014-12-14_18:26:54 WF.tuerkontakt alive: yes
2014-12-14_18:26:54 WF.tuerkontakt battery: ok
2014-12-14_18:26:54 WF.tuerkontakt sabotageError: off
2014-12-14_18:26:54 WF.tuerkontakt closed
2014-12-14_18:26:54 WF.tuerkontakt contact: closed (to HMLAN1)
2014-12-14_19:27:42 WF.tuerkontakt alive: yes
2014-12-14_19:27:42 WF.tuerkontakt battery: ok
2014-12-14_19:27:42 WF.tuerkontakt sabotageError: off
2014-12-14_19:27:42 WF.tuerkontakt closed
2014-12-14_19:27:42 WF.tuerkontakt contact: closed (to HMLAN1)
Ich frage in einem notify den open ab, was natürlich ärgerlich ist, wenn das jede Stunde passiert.
Dachte schon das liegt am ActionDetector, doch da habe ich den Tuerkontakt entfernt.
Kann mir jemand sagen, wie ich das Alive verhalten steuern kann ?
warum oder was hindert dich das Attribut
event-on-change-reading .*
bei dem Sensor zu setzten
@fhem-hm-knecht
Super Tipp, sieht wesentlich besser aus..
Der Sensor macht wohl weiterhin seine Checks, die Meldungen sind aber weg...
DANKE
