ich habe seit heute plötzlich das Problem, daß mein CUL am Rpi immer wieder die Verbindung verliert und anschließend wieder herstellt:
2014.12.27 23:30:15 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2014.12.27 23:30:16 3: Setting CUL_0 baudrate to 9600
2014.12.27 23:30:16 1: /dev/ttyACM0 reappeared (CUL_0)
2014.12.27 23:30:16 3: CUL_0: Possible commands: BbCFiAZEGMKUYRTVWXefmltux
2014.12.27 23:30:20 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2014.12.27 23:30:20 3: Setting CUL_0 baudrate to 9600
2014.12.27 23:30:20 1: /dev/ttyACM0 reappeared (CUL_0)
2014.12.27 23:30:21 3: CUL_0: Possible commands: BbCFiAZEGMKUYRTVWXefmltux
2014.12.27 23:30:25 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2014.12.27 23:30:26 3: Setting CUL_0 baudrate to 9600
2014.12.27 23:30:26 1: /dev/ttyACM0 reappeared (CUL_0)
2014.12.27 23:30:26 3: CUL_0: Possible commands: BbCFiAZEGMKUYRTVWXefmltux
2014.12.27 23:30:28 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2014.12.27 23:30:30 3: Setting CUL_0 baudrate to 9600
2014.12.27 23:30:30 1: /dev/ttyACM0 reappeared (CUL_0)
2014.12.27 23:30:30 3: CUL_0: Possible commands: BbCFiAZEGMKUYRTVWXefmltux
2014.12.27 23:30:36 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2014.12.27 23:30:36 3: Setting CUL_0 baudrate to 9600
2014.12.27 23:30:36 1: /dev/ttyACM0 reappeared (CUL_0)
2014.12.27 23:30:36 3: CUL_0: Possible commands: BbCFiAZEGMKUYRTVWXefmltux
2014.12.27 23:30:43 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2014.12.27 23:30:44 3: Setting CUL_0 baudrate to 9600
2014.12.27 23:30:44 1: /dev/ttyACM0 reappeared (CUL_0)
2014.12.27 23:30:44 3: CUL_0: Possible commands: BbCFiAZEGMKUYRTVWXefmltux
2014.12.27 23:31:24 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2014.12.27 23:31:48 3: Setting CUL_0 baudrate to 9600
2014.12.27 23:31:48 1: /dev/ttyACM0 reappeared (CUL_0)
2014.12.27 23:31:48 3: CUL_0: Possible commands: BbCFiAZEGMKUYRTVWXefmltux
Der CUL arbeitet im Mode homematic.
Entweder ist das ein culfw Fehler, was durch das HM Modul ausgeloest wird, oder liegt es an unzureichende Stromversorgung-
wenn das problem einfach so auftritt - ohne FW update - ist es evtl die HW.
die CUL wird aus CUL_HM nicht disconnected - es wäre ggf ein bug in 00_CUL. Das darf ich garnicht ändern ;)
Wie kann ich den Fehler weiter eingrenzen ? Neues Netzteil ? Update machen ? Es wundert mich, daß der Fehler so plötzlich auftritt...
wenn du keine änderung gemacht hast (update) seitdem der Fehler auftritt ist es eher ein HW problem.
wenn es ein HW problem ist... musst du an der HW messen.
es könnte das netzteil der CUL oder des PC (PI,...) sein. Du kannst also beides der reihen nach austauschen (wenn du ersatz hast)
wenn es die SW ist schalte zurück auf die letzte bekannt-gute config
