Hab heute mal wieder ein Update gemacht.
2015.01.10 20:02:16 1: RMDIR: ./restoreDir/2015-01-03
2015.01.10 20:02:16 1: UPD ./CHANGED
2015.01.10 20:02:16 1: UPD ./configDB.pm
2015.01.10 20:02:16 1: UPD FHEM/00_THZ.pm
2015.01.10 20:02:17 1: UPD FHEM/01_FHEMWEB.pm
2015.01.10 20:02:17 1: UPD FHEM/09_CUL_FHTTK.pm
2015.01.10 20:02:17 1: UPD FHEM/10_CUL_HM.pm
2015.01.10 20:02:17 1: UPD FHEM/10_HXBDevice.pm
2015.01.10 20:02:18 1: UPD FHEM/32_SYSSTAT.pm
2015.01.10 20:02:18 1: UPD FHEM/33_readingsGroup.pm
2015.01.10 20:02:18 1: UPD FHEM/70_Jabber.pm
2015.01.10 20:02:18 1: UPD FHEM/72_FRITZBOX.pm
2015.01.10 20:02:18 1: UPD FHEM/73_PRESENCE.pm
2015.01.10 20:02:18 1: UPD FHEM/90_at.pm
2015.01.10 20:02:18 1: UPD FHEM/92_FileLog.pm
2015.01.10 20:02:18 1: UPD FHEM/98_RandomTimer.pm
2015.01.10 20:02:18 1: UPD FHEM/98_SVG.pm
2015.01.10 20:02:18 1: UPD FHEM/98_configdb.pm
2015.01.10 20:02:19 1: UPD FHEM/98_statistics.pm
2015.01.10 20:02:19 1: UPD FHEM/Color.pm
2015.01.10 20:02:19 1: UPD docs/commandref.html
2015.01.10 20:02:20 1: UPD docs/commandref_DE.html
2015.01.10 20:02:21 1: UPD www/images/fhemSVG/access_keypad_1.svg
2015.01.10 20:02:21 1: UPD www/images/fhemSVG/access_keypad_2.svg
2015.01.10 20:02:21 1: UPD www/images/fhemSVG/hm_keymatic.svg
2015.01.10 20:02:21 1: UPD www/images/fhemSVG/remote_control.svg
2015.01.10 20:02:21 1: UPD www/pgm2/defaultCommon.css
2015.01.10 20:02:21 1: UPD www/pgm2/fhemweb.js
2015.01.10 20:02:21 1: UPD www/pgm2/fhemweb_colorpicker.js
2015.01.10 20:02:21 1: UPD www/pgm2/fhemweb_knob.js
2015.01.10 20:02:22 1: UPD www/pgm2/fhemweb_multiple.js
2015.01.10 20:02:22 1: UPD www/pgm2/fhemweb_noArg.js
2015.01.10 20:02:22 1: UPD www/pgm2/fhemweb_slider.js
2015.01.10 20:02:22 1: UPD www/pgm2/fhemweb_svg.js
2015.01.10 20:02:22 1: UPD www/pgm2/fhemweb_textField.js
2015.01.10 20:02:22 1: UPD www/pgm2/fhemweb_time.js
2015.01.10 20:02:22 1: UPD www/pgm2/images/ui-bg_flat_0_aaaaaa_40x100.png
2015.01.10 20:02:22 1: UPD www/pgm2/images/ui-bg_flat_75_ffffff_40x100.png
2015.01.10 20:02:22 1: UPD www/pgm2/images/ui-bg_glass_65_ffffff_1x400.png
2015.01.10 20:02:22 1: UPD www/pgm2/images/ui-bg_glass_75_dadada_1x400.png
2015.01.10 20:02:22 1: UPD www/pgm2/images/ui-bg_glass_75_e6e6e6_1x400.png
2015.01.10 20:02:22 1: UPD www/pgm2/images/ui-bg_highlight-soft_75_cccccc_1x100.png
2015.01.10 20:02:22 1: UPD www/pgm2/images/ui-icons_222222_256x240.png
2015.01.10 20:02:22 1: UPD www/pgm2/jquery.knob.min.js
2015.01.10 20:02:22 1: UPD www/pgm2/svg.js
2015.01.10 20:02:23 1: UPD www/pgm2/svg_style.css
2015.01.10 20:02:23 1: New entries in the CHANGED file:
2015.01.10 20:02:23 1: - feature: fhemweb.js rewrite based on jQuery, single-widget-implementation
2015.01.10 20:02:23 1: - feature: SVG: multiple sources allowed, Plot-Editor
2015.01.10 20:02:23 1: - feature: textfield-long and knob widgets
2015.01.10 20:02:23 1: - added: some new icons by Rampler
2015.01.10 20:02:23 1: - feature: PRESENCE: new reading "presence" which contains the current (or
2015.01.10 20:02:23 1: last known) presence state (can be "absent" or "present")
2015.01.10 20:02:23 1: - bugfix: 70_Jabber.pm: hardening XML::Stream Process() call and fix of
2015.01.10 20:02:24 1: ssl_verify
2015.01.10 20:02:24 1: - feature: readingsGroup: allow devspec :FILTER= expressions in device
2015.01.10 20:02:24 1: selection
2015.01.10 20:02:24 1: update finished, "shutdown restart" is needed to activate the changes.
2015.01.10 20:02:26 1: fheminfo server response: ==> ok
Nun habe ich folgende Fehler im LOG.
Prototype after '@' for main::Text2Speech_SplitString : @$$$$ at ./FHEM/98_Text2Speech.pm line 446, <$fh> line 451.
2015.01.10 20:05:55 1: PERL WARNING: Argument "undef" isn't numeric in numeric lt (<) at ./FHEM/98_SVG.pm line 1095.
2015.01.10 20:05:55 1: PERL WARNING: Argument "undef" isn't numeric in numeric gt (>) at ./FHEM/98_SVG.pm line 1097.
Kann mir da jemand helfen?
Mike
Das Problem haengt mit dem fhemweb_js_umbau zusammen, und ich gehe davon aus, dass Du dblog verwendest. Wenn ja, und dann habe ich es evtl. behoben. Wenn nein, dann brauche ich die Ausgangsdaten der Plots und die plot-Definition um es zu debuggen.
Danke für die schnelle Antwort.
Das ganze läuft noch nicht über dblog. Wo finde ich die Ausgangsdaten der Plots und die plot-Definitionen?
Bin darin noch nicht so firm :o
Nach Umstellung auf DBLog, funktioniert es wieder.
DANKE,
Mike
Gesendet von meinem HUAWEI P6-U06 mit Tapatalk
