I got a smart meter, and when I connect it within linux, and I run the following command
sudo cu -l /dev/ttyUSB0 -s 9600 --parity=none
I get this output every 10 seconds
/ISk5\2ME382-1003
0-0:96.1.1(4B413650303035313534323830333133)
1-0:1.8.1(02179.828*kWh)
1-0:1.8.2(01358.495*kWh)
1-0:2.8.1(00000.001*kWh)
1-0:2.8.2(00000.000*kWh)
0-0:96.14.0(0001)
1-0:1.7.0(0000.25*kW)
1-0:2.7.0(0000.00*kW)
0-0:17.0.0(0999.00*kW)
0-0:96.3.10(1)
0-0:96.13.1()
0-0:96.13.0()
0-1:24.1.0(3)
0-1:96.1.0(4730303135353631303133333035303133)
0-1:24.3.0(150221220000)(00)(60)(1)(0-1:24.2.1)(m3)
(01218.277)
0-1:24.4.0(1)
Ho can I use this in fhem. Is this possible with the emcd device, with a classdev?
regards Richard
I think it should be possible. I had a brief play with ECMD some time back but that was with a server that sent back unpredictable messages.
From memory you will need to construct the classdef (I think there is info in the wiki) but from what you have written you won't need to worry about sending responses.
A forum search for S0 (S zero and perhaps add tty) may find something that others have already got working.
