I would appreciate any help anyone can give with this!
RFXmngr is displaying the following:
0B11000B0002998003000070
Packettype = Lighting2
subtype = AC
Sequence nbr = 11
ID = 0029980
Unit = 3
Command = Off
Signal level = 7
0B11010C0000198003000040
subtype = HomeEasy EU
Sequence nbr = 12
ID = 0001980
Unit = 3
Command = Off
Signal level = 4
0B11000D0002998003010F70
subtype = AC
Sequence nbr = 13
ID = 0029980
Unit = 3
Command = On
Signal level = 7
0B11010E0000198003010F40
Sequence nbr = 14
ID = 0001980
Unit = 3
Command = On
Signal level = 4
Events (Filter:TRX*.*):
2015-03-29 20:38:56 TRX RFXTRXUSB DISCONNECTED
2015-03-29 20:38:56 TRX RFXTRXUSB CONNECTED
2015-03-29 20:39:00 TRX RFXTRXUSB DISCONNECTED
2015-03-29 20:39:00 TRX RFXTRXUSB CONNECTED
2015-03-29 20:39:04 TRX RFXTRXUSB DISCONNECTED
2015-03-29 20:39:04 TRX RFXTRXUSB CONNECTED
2015-03-29 20:39:05 TRX RFXTRXUSB UNKNOWNCODE 019e
2015-03-29 20:39:14 TRX RFXTRXUSB DISCONNECTED
2015-03-29 20:39:14 TRX RFXTRXUSB CONNECTED
FHEM ha just added this?
nternals
CFGFN
DEF
AC 0000600710 light
IODev
RFXTRXUSB
NAME
TRX_AC_0000600710
NR
20665
STATE
off
TRX_LIGHT_deviceid
0000600710
TRX_LIGHT_devicelog
light
TRX_LIGHT_type
AC
TYPE
TRX_LIGHT
Readings
state
off
2015-03-29 20:39:44
TRX_AC_0000600710
Attributes
IODev
RFXTRXUSB
deleteattr
room
TRX_LIGHT
deleteattr
verbose
5
deleteattr
Probably associated with
FileLog_TRX_AC_0000600710
FileLog
