FHEM - Entwicklung => FHEM Code changes => Thema gestartet von: System am 20 April 2015, 02:00:07
Titel: 98_WeekdayTimer, 98_Heating_Control: some improvements to set Parameter/Temperature of a past switch when starting/defining a WD or HC.
Beitrag von: System am 20 April 2015, 02:00:07
98_WeekdayTimer, 98_Heating_Control: some improvements to set Parameter/Temperature of a past switch when starting/defining a WD or HC. Improvements to corectly set state to active/<temp>/<Param>View Changes
Source: 98_WeekdayTimer, 98_Heating_Control: some improvements to set Parameter/Temperature of a past switch when starting/defining a WD or HC. (http://sourceforge.net/p/fhem/code/8456/)
