FHEM => Sonstiges => Thema gestartet von: BlackStone am 30 August 2015, 14:57:13
Titel: Fehler nach Update vom 30.08.15 10_CUL_HM.pm
Beitrag von: BlackStone am 30 August 2015, 14:57:13
ich habe mich gerade gewundert, weil etwas nicht so lief wie gedacht, und schaue mal nichtssagend ins logfile.
naja und da hats mir die log zugehagelt.  :o
2015.08.30 09:40:13 1: RMDIR: ./restoreDir/2015-08-27
2015.08.30 09:40:14 1: UPD ./CHANGED
2015.08.30 09:40:14 1: UPD FHEM/10_CUL_HM.pm
2015.08.30 09:40:14 1: UPD FHEM/10_ZWave.pm
2015.08.30 09:40:14 1: UPD FHEM/23_LUXTRONIK2.pm
2015.08.30 09:40:14 1: UPD FHEM/42_SYSMON.pm
2015.08.30 09:40:15 1: UPD FHEM/57_Calendar.pm
2015.08.30 09:40:15 1: UPD FHEM/74_Unifi.pm
2015.08.30 09:40:15 1: UPD FHEM/98_Text2Speech.pm
2015.08.30 09:40:15 1: UPD FHEM/HMConfig.pm
2015.08.30 09:40:16 1:
2015.08.30 09:40:16 1: New entries in the CHANGED file:
2015.08.30 09:40:16 1:   - feature: 98_Text2Speech.pm:
2015.08.30 09:40:16 1:               - Quality and Speed as new Parameter
2015.08.30 09:40:16 1:               - Bugfixing with Google Download
2015.08.30 09:40:16 1:               - added VoiceRSS as new Ressouce
2015.08.30 09:40:16 1:               - TTS_FileTemplateDir: Beginning with absolute directory now possible
2015.08.30 09:40:16 1:               - TTS_Timeout (optional) added
2015.08.30 09:40:16 1: Calling /usr/bin/perl ./contrib/commandref_join.pl, this may take a while
2015.08.30 09:40:39 1: EN FHEM/00_SIGNALduino.pm: Unbalanced ul (1, last line ok: 1751)
2015.08.30 09:40:39 1: *** EN FHEM/14_SIGNALduino_RSL.pm: No document text found
2015.08.30 09:40:39 1: update finished, "shutdown restart" is needed to activate the changes.
2015.08.30 09:40:41 1: fheminfo server response: ==> ok
2015.08.30 09:40:50 0: Server shutdown
2015.08.30 09:40:53 1: Including fhem.cfg
2015.08.30 09:40:53 3: WEB: port 8083 opened
2015.08.30 09:40:53 3: WEBphone: port 8084 opened
2015.08.30 09:40:53 3: WEBtablet: port 8085 opened
2015.08.30 09:40:54 2: eventTypes: loaded 1215 events from ./log/eventTypes.txt
2015.08.30 09:40:54 3: Opening CSM device /dev/ttyAMA0
2015.08.30 09:40:54 3: Setting CSM serial parameters to 38400,8,N,1
2015.08.30 09:40:54 3: CSM device opened
2015.08.30 09:40:54 3: CSM: Possible commands: BbCFikAp*ZGMKUYRTVWXefmltux
2015.08.30 09:40:54 2: Switched CSM rfmode to HomeMatic
2015.08.30 09:40:55 1: reload: Error:Modul 10_CUL_HM deactivated:
Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232, <$fh> line 57.
Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6233, <$fh> line 57.
BEGIN not safe after errors--compilation aborted at ./FHEM/10_CUL_HM.pm line 6451, <$fh> line 57.
2015.08.30 09:40:55 0: Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232, <$fh> line 57.
Subroutine CUL_HM_Initialize redefined at ./FHEM/10_CUL_HM.pm line 131, <$fh> line 146.
Subroutine CUL_HM_updateConfig redefined at ./FHEM/10_CUL_HM.pm line 213, <$fh> line 146.
Subroutine CUL_HM_Define redefined at ./FHEM/10_CUL_HM.pm line 465, <$fh> line 146.
Subroutine CUL_HM_Undef redefined at ./FHEM/10_CUL_HM.pm line 520, <$fh> line 146.
Subroutine CUL_HM_Rename redefined at ./FHEM/10_CUL_HM.pm line 539, <$fh> line 146.
Subroutine CUL_HM_Attr redefined at ./FHEM/10_CUL_HM.pm line 576, <$fh> line 146.
Subroutine CUL_HM_AttrCheck redefined at ./FHEM/10_CUL_HM.pm line 860, <$fh> line 146.
Subroutine CUL_HM_prtInit redefined at ./FHEM/10_CUL_HM.pm line 882, <$fh> line 146.
Subroutine CUL_HM_hmInitMsg redefined at ./FHEM/10_CUL_HM.pm line 887, <$fh> line 146.
Subroutine CUL_HM_hmInitMsgUpdt redefined at ./FHEM/10_CUL_HM.pm line 924, <$fh> line 146.
Subroutine CUL_HM_Notify redefined at ./FHEM/10_CUL_HM.pm line 951, <$fh> line 146.
Subroutine CUL_HM_setupHMLAN redefined at ./FHEM/10_CUL_HM.pm line 964, <$fh> line 146.
Subroutine CUL_HM_Parse redefined at ./FHEM/10_CUL_HM.pm line 1001, <$fh> line 146.
Subroutine CUL_HM_parseCommon redefined at ./FHEM/10_CUL_HM.pm line 2639, <$fh> line 146.
Subroutine CUL_HM_m_setCh redefined at ./FHEM/10_CUL_HM.pm line 3137, <$fh> line 146.
Subroutine CUL_HM_queueUpdtCfg redefined at ./FHEM/10_CUL_HM.pm line 3148, <$fh> line 146.
Subroutine CUL_HM_parseSDteam redefined at ./FHEM/10_CUL_HM.pm line 3166, <$fh> line 146.
Subroutine CUL_HM_updtSDTeam redefined at ./FHEM/10_CUL_HM.pm line 3224, <$fh> line 146.
Subroutine CUL_HM_pushEvnts redefined at ./FHEM/10_CUL_HM.pm line 3245, <$fh> line 146.
Subroutine CUL_HM_Get redefined at ./FHEM/10_CUL_HM.pm line 3272, <$fh> line 146.
Subroutine CUL_HM_Set redefined at ./FHEM/10_CUL_HM.pm line 3540, <$fh> line 146.
Subroutine CUL_HM_valvePosUpdt redefined at ./FHEM/10_CUL_HM.pm line 5259, <$fh> line 146.
Subroutine CUL_HM_valvePosTmr redefined at ./FHEM/10_CUL_HM.pm line 5326, <$fh> line 146.
Subroutine CUL_HM_weather redefined at ./FHEM/10_CUL_HM.pm line 5358, <$fh> line 146.
Subroutine CUL_HM_infoUpdtDevData redefined at ./FHEM/10_CUL_HM.pm line 5367, <$fh> line 146.
Subroutine CUL_HM_getConfig redefined at ./FHEM/10_CUL_HM.pm line 5417, <$fh> line 146.
Subroutine CUL_HM_calcDisWmSet redefined at ./FHEM/10_CUL_HM.pm line 5480, <$fh> line 146.
Subroutine CUL_HM_calcDisWm redefined at ./FHEM/10_CUL_HM.pm line 5498, <$fh> line 146.
Subroutine CUL_HM_RemoveHMPair redefined at ./FHEM/10_CUL_HM.pm line 5543, <$fh> line 146.
Subroutine CUL_HM_pushConfig redefined at ./FHEM/10_CUL_HM.pm line 5553, <$fh> line 146.
Subroutine CUL_HM_PushCmdStack redefined at ./FHEM/10_CUL_HM.pm line 5633, <$fh> line 146.
Subroutine CUL_HM_ProcessCmdStack redefined at ./FHEM/10_CUL_HM.pm line 5647, <$fh> line 146.
Subroutine CUL_HM_respWaitSu redefined at ./FHEM/10_CUL_HM.pm line 5662, <$fh> line 146.
Subroutine CUL_HM_responseSetup redefined at ./FHEM/10_CUL_HM.pm line 5688, <$fh> line 146.
Subroutine CUL_HM_sndIfOpen redefined at ./FHEM/10_CUL_HM.pm line 5823, <$fh> line 146.
Subroutine CUL_HM_SndCmd redefined at ./FHEM/10_CUL_HM.pm line 5861, <$fh> line 146.
Subroutine CUL_HM_statCnt redefined at ./FHEM/10_CUL_HM.pm line 5936, <$fh> line 146.
Subroutine CUL_HM_statCntRfresh redefined at ./FHEM/10_CUL_HM.pm line 5967, <$fh> line 146.
Subroutine CUL_HM_respPendRm redefined at ./FHEM/10_CUL_HM.pm line 5984, <$fh> line 146.
Subroutine CUL_HM_respPendTout redefined at ./FHEM/10_CUL_HM.pm line 5999, <$fh> line 146.
Subroutine CUL_HM_respPendToutProlong redefined at ./FHEM/10_CUL_HM.pm line 6094, <$fh> line 146.
Subroutine CUL_HM_FWupdateSteps redefined at ./FHEM/10_CUL_HM.pm line 6100, <$fh> line 146.
Subroutine CUL_HM_FWupdateBTo redefined at ./FHEM/10_CUL_HM.pm line 6168, <$fh> line 146.
Subroutine CUL_HM_FWupdateEnd redefined at ./FHEM/10_CUL_HM.pm line 6180, <$fh> line 146.
Subroutine CUL_HM_FWupdateSpeed redefined at ./FHEM/10_CUL_HM.pm line 6202, <$fh> line 146.
Subroutine CUL_HM_FWupdateSim redefined at ./FHEM/10_CUL_HM.pm line 6213, <$fh> line 146.
2015.08.30 09:40:56 1: reload: Error:Modul 10_CUL_HM deactivated:
Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232, <$fh> line 146.
Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6233, <$fh> line 146.
BEGIN not safe after errors--compilation aborted at ./FHEM/10_CUL_HM.pm line 6451, <$fh> line 146.
2015.08.30 09:40:56 0: Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232, <$fh> line 146.
Subroutine CUL_HM_Initialize redefined at ./FHEM/10_CUL_HM.pm line 131, <$fh> line 163.
Subroutine CUL_HM_updateConfig redefined at ./FHEM/10_CUL_HM.pm line 213, <$fh> line 163.
Subroutine CUL_HM_Define redefined at ./FHEM/10_CUL_HM.pm line 465, <$fh> line 163.
Subroutine CUL_HM_Undef redefined at ./FHEM/10_CUL_HM.pm line 520, <$fh> line 163.
Subroutine CUL_HM_Rename redefined at ./FHEM/10_CUL_HM.pm line 539, <$fh> line 163.
Subroutine CUL_HM_Attr redefined at ./FHEM/10_CUL_HM.pm line 576, <$fh> line 163.
Subroutine CUL_HM_AttrCheck redefined at ./FHEM/10_CUL_HM.pm line 860, <$fh> line 163.
Subroutine CUL_HM_prtInit redefined at ./FHEM/10_CUL_HM.pm line 882, <$fh> line 163.
Subroutine CUL_HM_hmInitMsg redefined at ./FHEM/10_CUL_HM.pm line 887, <$fh> line 163.
Subroutine CUL_HM_hmInitMsgUpdt redefined at ./FHEM/10_CUL_HM.pm line 924, <$fh> line 163.
Subroutine CUL_HM_Notify redefined at ./FHEM/10_CUL_HM.pm line 951, <$fh> line 163.
Subroutine CUL_HM_setupHMLAN redefined at ./FHEM/10_CUL_HM.pm line 964, <$fh> line 163.
Subroutine CUL_HM_Parse redefined at ./FHEM/10_CUL_HM.pm line 1001, <$fh> line 163.
Subroutine CUL_HM_parseCommon redefined at ./FHEM/10_CUL_HM.pm line 2639, <$fh> line 163.
Subroutine CUL_HM_m_setCh redefined at ./FHEM/10_CUL_HM.pm line 3137, <$fh> line 163.
Subroutine CUL_HM_queueUpdtCfg redefined at ./FHEM/10_CUL_HM.pm line 3148, <$fh> line 163.
Subroutine CUL_HM_parseSDteam redefined at ./FHEM/10_CUL_HM.pm line 3166, <$fh> line 163.
Subroutine CUL_HM_updtSDTeam redefined at ./FHEM/10_CUL_HM.pm line 3224, <$fh> line 163.
Subroutine CUL_HM_pushEvnts redefined at ./FHEM/10_CUL_HM.pm line 3245, <$fh> line 163.
Subroutine CUL_HM_Get redefined at ./FHEM/10_CUL_HM.pm line 3272, <$fh> line 163.
Subroutine CUL_HM_Set redefined at ./FHEM/10_CUL_HM.pm line 3540, <$fh> line 163.
Subroutine CUL_HM_valvePosUpdt redefined at ./FHEM/10_CUL_HM.pm line 5259, <$fh> line 163.
Subroutine CUL_HM_valvePosTmr redefined at ./FHEM/10_CUL_HM.pm line 5326, <$fh> line 163.
Subroutine CUL_HM_weather redefined at ./FHEM/10_CUL_HM.pm line 5358, <$fh> line 163.
Subroutine CUL_HM_infoUpdtDevData redefined at ./FHEM/10_CUL_HM.pm line 5367, <$fh> line 163.
Subroutine CUL_HM_getConfig redefined at ./FHEM/10_CUL_HM.pm line 5417, <$fh> line 163.
Subroutine CUL_HM_calcDisWmSet redefined at ./FHEM/10_CUL_HM.pm line 5480, <$fh> line 163.
Subroutine CUL_HM_calcDisWm redefined at ./FHEM/10_CUL_HM.pm line 5498, <$fh> line 163.
Subroutine CUL_HM_RemoveHMPair redefined at ./FHEM/10_CUL_HM.pm line 5543, <$fh> line 163.
Subroutine CUL_HM_pushConfig redefined at ./FHEM/10_CUL_HM.pm line 5553, <$fh> line 163.
Subroutine CUL_HM_PushCmdStack redefined at ./FHEM/10_CUL_HM.pm line 5633, <$fh> line 163.
Subroutine CUL_HM_ProcessCmdStack redefined at ./FHEM/10_CUL_HM.pm line 5647, <$fh> line 163.
Subroutine CUL_HM_respWaitSu redefined at ./FHEM/10_CUL_HM.pm line 5662, <$fh> line 163.
Subroutine CUL_HM_responseSetup redefined at ./FHEM/10_CUL_HM.pm line 5688, <$fh> line 163.
Subroutine CUL_HM_sndIfOpen redefined at ./FHEM/10_CUL_HM.pm line 5823, <$fh> line 163.
Subroutine CUL_HM_SndCmd redefined at ./FHEM/10_CUL_HM.pm line 5861, <$fh> line 163.
Subroutine CUL_HM_statCnt redefined at ./FHEM/10_CUL_HM.pm line 5936, <$fh> line 163.
Subroutine CUL_HM_statCntRfresh redefined at ./FHEM/10_CUL_HM.pm line 5967, <$fh> line 163.
Subroutine CUL_HM_respPendRm redefined at ./FHEM/10_CUL_HM.pm line 5984, <$fh> line 163.
Subroutine CUL_HM_respPendTout redefined at ./FHEM/10_CUL_HM.pm line 5999, <$fh> line 163.
Subroutine CUL_HM_respPendToutProlong redefined at ./FHEM/10_CUL_HM.pm line 6094, <$fh> line 163.
Subroutine CUL_HM_FWupdateSteps redefined at ./FHEM/10_CUL_HM.pm line 6100, <$fh> line 163.
Subroutine CUL_HM_FWupdateBTo redefined at ./FHEM/10_CUL_HM.pm line 6168, <$fh> line 163.
Subroutine CUL_HM_FWupdateEnd redefined at ./FHEM/10_CUL_HM.pm line 6180, <$fh> line 163.
Subroutine CUL_HM_FWupdateSpeed redefined at ./FHEM/10_CUL_HM.pm line 6202, <$fh> line 163.
Subroutine CUL_HM_FWupdateSim redefined at ./FHEM/10_CUL_HM.pm line 6213, <$fh> line 163.
Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232, <$fh> line 163.
Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6233, <$fh> line 163.
BEGIN not safe after errors--compilation aborted at ./FHEM/10_CUL_HM.pm line 6451, <$fh> line 163.
2015.08.30 09:40:56 0: Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232, <$fh> line 163.
Subroutine CUL_HM_Initialize redefined at ./FHEM/10_CUL_HM.pm line 131, <$fh> line 166.
Subroutine CUL_HM_updateConfig redefined at ./FHEM/10_CUL_HM.pm line 213, <$fh> line 166.
Subroutine CUL_HM_Define redefined at ./FHEM/10_CUL_HM.pm line 465, <$fh> line 166.
Subroutine CUL_HM_Undef redefined at ./FHEM/10_CUL_HM.pm line 520, <$fh> line 166.
Subroutine CUL_HM_Rename redefined at ./FHEM/10_CUL_HM.pm line 539, <$fh> line 166.
Subroutine CUL_HM_Attr redefined at ./FHEM/10_CUL_HM.pm line 576, <$fh> line 166.
Subroutine CUL_HM_AttrCheck redefined at ./FHEM/10_CUL_HM.pm line 860, <$fh> line 166.
Subroutine CUL_HM_prtInit redefined at ./FHEM/10_CUL_HM.pm line 882, <$fh> line 166.
Subroutine CUL_HM_hmInitMsg redefined at ./FHEM/10_CUL_HM.pm line 887, <$fh> line 166.
Subroutine CUL_HM_hmInitMsgUpdt redefined at ./FHEM/10_CUL_HM.pm line 924, <$fh> line 166.
Subroutine CUL_HM_Notify redefined at ./FHEM/10_CUL_HM.pm line 951, <$fh> line 166.
Subroutine CUL_HM_setupHMLAN redefined at ./FHEM/10_CUL_HM.pm line 964, <$fh> line 166.
Subroutine CUL_HM_Parse redefined at ./FHEM/10_CUL_HM.pm line 1001, <$fh> line 166.
Subroutine CUL_HM_parseCommon redefined at ./FHEM/10_CUL_HM.pm line 2639, <$fh> line 166.
Subroutine CUL_HM_m_setCh redefined at ./FHEM/10_CUL_HM.pm line 3137, <$fh> line 166.
Subroutine CUL_HM_queueUpdtCfg redefined at ./FHEM/10_CUL_HM.pm line 3148, <$fh> line 166.
Subroutine CUL_HM_parseSDteam redefined at ./FHEM/10_CUL_HM.pm line 3166, <$fh> line 166.
Subroutine CUL_HM_updtSDTeam redefined at ./FHEM/10_CUL_HM.pm line 3224, <$fh> line 166.
Subroutine CUL_HM_pushEvnts redefined at ./FHEM/10_CUL_HM.pm line 3245, <$fh> line 166.
Subroutine CUL_HM_Get redefined at ./FHEM/10_CUL_HM.pm line 3272, <$fh> line 166.
Subroutine CUL_HM_Set redefined at ./FHEM/10_CUL_HM.pm line 3540, <$fh> line 166.
Subroutine CUL_HM_valvePosUpdt redefined at ./FHEM/10_CUL_HM.pm line 5259, <$fh> line 166.
Subroutine CUL_HM_valvePosTmr redefined at ./FHEM/10_CUL_HM.pm line 5326, <$fh> line 166.
Subroutine CUL_HM_weather redefined at ./FHEM/10_CUL_HM.pm line 5358, <$fh> line 166.
Subroutine CUL_HM_infoUpdtDevData redefined at ./FHEM/10_CUL_HM.pm line 5367, <$fh> line 166.
Subroutine CUL_HM_getConfig redefined at ./FHEM/10_CUL_HM.pm line 5417, <$fh> line 166.
Subroutine CUL_HM_calcDisWmSet redefined at ./FHEM/10_CUL_HM.pm line 5480, <$fh> line 166.
Subroutine CUL_HM_calcDisWm redefined at ./FHEM/10_CUL_HM.pm line 5498, <$fh> line 166.
Subroutine CUL_HM_RemoveHMPair redefined at ./FHEM/10_CUL_HM.pm line 5543, <$fh> line 166.
Subroutine CUL_HM_pushConfig redefined at ./FHEM/10_CUL_HM.pm line 5553, <$fh> line 166.
Subroutine CUL_HM_PushCmdStack redefined at ./FHEM/10_CUL_HM.pm line 5633, <$fh> line 166.
Subroutine CUL_HM_ProcessCmdStack redefined at ./FHEM/10_CUL_HM.pm line 5647, <$fh> line 166.
Subroutine CUL_HM_respWaitSu redefined at ./FHEM/10_CUL_HM.pm line 5662, <$fh> line 166.
Subroutine CUL_HM_responseSetup redefined at ./FHEM/10_CUL_HM.pm line 5688, <$fh> line 166.
Subroutine CUL_HM_sndIfOpen redefined at ./FHEM/10_CUL_HM.pm line 5823, <$fh> line 166.
Subroutine CUL_HM_SndCmd redefined at ./FHEM/10_CUL_HM.pm line 5861, <$fh> line 166.
Subroutine CUL_HM_statCnt redefined at ./FHEM/10_CUL_HM.pm line 5936, <$fh> line 166.
Subroutine CUL_HM_statCntRfresh redefined at ./FHEM/10_CUL_HM.pm line 5967, <$fh> line 166.
Subroutine CUL_HM_respPendRm redefined at ./FHEM/10_CUL_HM.pm line 5984, <$fh> line 166.
Subroutine CUL_HM_respPendTout redefined at ./FHEM/10_CUL_HM.pm line 5999, <$fh> line 166.
Subroutine CUL_HM_respPendToutProlong redefined at ./FHEM/10_CUL_HM.pm line 6094, <$fh> line 166.
Subroutine CUL_HM_FWupdateSteps redefined at ./FHEM/10_CUL_HM.pm line 6100, <$fh> line 166.
Subroutine CUL_HM_FWupdateBTo redefined at ./FHEM/10_CUL_HM.pm line 6168, <$fh> line 166.
Subroutine CUL_HM_FWupdateEnd redefined at ./FHEM/10_CUL_HM.pm line 6180, <$fh> line 166.
Subroutine CUL_HM_FWupdateSpeed redefined at ./FHEM/10_CUL_HM.pm line 6202, <$fh> line 166.
Subroutine CUL_HM_FWupdateSim redefined at ./FHEM/10_CUL_HM.pm line 6213, <$fh> line 166.
2015.08.30 09:40:57 1: reload: Error:Modul 10_CUL_HM deactivated:
Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232, <$fh> line 166.
Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6233, <$fh> line 166.
BEGIN not safe after errors--compilation aborted at ./FHEM/10_CUL_HM.pm line 6451, <$fh> line 166.
2015.08.30 09:40:57 0: Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232, <$fh> line 166.
Subroutine CUL_HM_Initialize redefined at ./FHEM/10_CUL_HM.pm line 131, <$fh> line 169.
Subroutine CUL_HM_updateConfig redefined at ./FHEM/10_CUL_HM.pm line 213, <$fh> line 169.
Subroutine CUL_HM_Define redefined at ./FHEM/10_CUL_HM.pm line 465, <$fh> line 169.
Subroutine CUL_HM_Undef redefined at ./FHEM/10_CUL_HM.pm line 520, <$fh> line 169.
Subroutine CUL_HM_Rename redefined at ./FHEM/10_CUL_HM.pm line 539, <$fh> line 169.
Subroutine CUL_HM_Attr redefined at ./FHEM/10_CUL_HM.pm line 576, <$fh> line 169.
Subroutine CUL_HM_AttrCheck redefined at ./FHEM/10_CUL_HM.pm line 860, <$fh> line 169.
Subroutine CUL_HM_prtInit redefined at ./FHEM/10_CUL_HM.pm line 882, <$fh> line 169.
Subroutine CUL_HM_hmInitMsg redefined at ./FHEM/10_CUL_HM.pm line 887, <$fh> line 169.
Subroutine CUL_HM_hmInitMsgUpdt redefined at ./FHEM/10_CUL_HM.pm line 924, <$fh> line 169.
Subroutine CUL_HM_Notify redefined at ./FHEM/10_CUL_HM.pm line 951, <$fh> line 169.
Subroutine CUL_HM_setupHMLAN redefined at ./FHEM/10_CUL_HM.pm line 964, <$fh> line 169.
Subroutine CUL_HM_Parse redefined at ./FHEM/10_CUL_HM.pm line 1001, <$fh> line 169.
Subroutine CUL_HM_parseCommon redefined at ./FHEM/10_CUL_HM.pm line 2639, <$fh> line 169.
Subroutine CUL_HM_m_setCh redefined at ./FHEM/10_CUL_HM.pm line 3137, <$fh> line 169.
Subroutine CUL_HM_queueUpdtCfg redefined at ./FHEM/10_CUL_HM.pm line 3148, <$fh> line 169.
Subroutine CUL_HM_parseSDteam redefined at ./FHEM/10_CUL_HM.pm line 3166, <$fh> line 169.
Subroutine CUL_HM_updtSDTeam redefined at ./FHEM/10_CUL_HM.pm line 3224, <$fh> line 169.
Subroutine CUL_HM_pushEvnts redefined at ./FHEM/10_CUL_HM.pm line 3245, <$fh> line 169.
Subroutine CUL_HM_Get redefined at ./FHEM/10_CUL_HM.pm line 3272, <$fh> line 169.
Subroutine CUL_HM_Set redefined at ./FHEM/10_CUL_HM.pm line 3540, <$fh> line 169.
Subroutine CUL_HM_valvePosUpdt redefined at ./FHEM/10_CUL_HM.pm line 5259, <$fh> line 169.
Subroutine CUL_HM_valvePosTmr redefined at ./FHEM/10_CUL_HM.pm line 5326, <$fh> line 169.
Subroutine CUL_HM_weather redefined at ./FHEM/10_CUL_HM.pm line 5358, <$fh> line 169.
Subroutine CUL_HM_infoUpdtDevData redefined at ./FHEM/10_CUL_HM.pm line 5367, <$fh> line 169.
Subroutine CUL_HM_getConfig redefined at ./FHEM/10_CUL_HM.pm line 5417, <$fh> line 169.
Subroutine CUL_HM_calcDisWmSet redefined at ./FHEM/10_CUL_HM.pm line 5480, <$fh> line 169.
Subroutine CUL_HM_calcDisWm redefined at ./FHEM/10_CUL_HM.pm line 5498, <$fh> line 169.
Subroutine CUL_HM_RemoveHMPair redefined at ./FHEM/10_CUL_HM.pm line 5543, <$fh> line 169.
Subroutine CUL_HM_pushConfig redefined at ./FHEM/10_CUL_HM.pm line 5553, <$fh> line 169.
Subroutine CUL_HM_PushCmdStack redefined at ./FHEM/10_CUL_HM.pm line 5633, <$fh> line 169.
Subroutine CUL_HM_ProcessCmdStack redefined at ./FHEM/10_CUL_HM.pm line 5647, <$fh> line 169.
Subroutine CUL_HM_respWaitSu redefined at ./FHEM/10_CUL_HM.pm line 5662, <$fh> line 169.
Subroutine CUL_HM_responseSetup redefined at ./FHEM/10_CUL_HM.pm line 5688, <$fh> line 169.
Subroutine CUL_HM_sndIfOpen redefined at ./FHEM/10_CUL_HM.pm line 5823, <$fh> line 169.
Subroutine CUL_HM_SndCmd redefined at ./FHEM/10_CUL_HM.pm line 5861, <$fh> line 169.
Subroutine CUL_HM_statCnt redefined at ./FHEM/10_CUL_HM.pm line 5936, <$fh> line 169.
Subroutine CUL_HM_statCntRfresh redefined at ./FHEM/10_CUL_HM.pm line 5967, <$fh> line 169.
Subroutine CUL_HM_respPendRm redefined at ./FHEM/10_CUL_HM.pm line 5984, <$fh> line 169.
Subroutine CUL_HM_respPendTout redefined at ./FHEM/10_CUL_HM.pm line 5999, <$fh> line 169.
Subroutine CUL_HM_respPendToutProlong redefined at ./FHEM/10_CUL_HM.pm line 6094, <$fh> line 169.
Subroutine CUL_HM_FWupdateSteps redefined at ./FHEM/10_CUL_HM.pm line 6100, <$fh> line 169.
Subroutine CUL_HM_FWupdateBTo redefined at ./FHEM/10_CUL_HM.pm line 6168, <$fh> line 169.
Subroutine CUL_HM_FWupdateEnd redefined at ./FHEM/10_CUL_HM.pm line 6180, <$fh> line 169.
Subroutine CUL_HM_FWupdateSpeed redefined at ./FHEM/10_CUL_HM.pm line 6202, <$fh> line 169.
Subroutine CUL_HM_FWupdateSim redefined at ./FHEM/10_CUL_HM.pm line 6213, <$fh> line 169.
Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232, <$fh> line 169.
Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6233, <$fh> line 169.
BEGIN not safe after errors--compilation aborted at ./FHEM/10_CUL_HM.pm line 6451, <$fh> line 169.
2015.08.30 09:40:57 0: Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232, <$fh> line 169.
Subroutine CUL_HM_Initialize redefined at ./FHEM/10_CUL_HM.pm line 131, <$fh> line 173.
Subroutine CUL_HM_updateConfig redefined at ./FHEM/10_CUL_HM.pm line 213, <$fh> line 173.
Subroutine CUL_HM_Define redefined at ./FHEM/10_CUL_HM.pm line 465, <$fh> line 173.
Subroutine CUL_HM_Undef redefined at ./FHEM/10_CUL_HM.pm line 520, <$fh> line 173.
Subroutine CUL_HM_Rename redefined at ./FHEM/10_CUL_HM.pm line 539, <$fh> line 173.
Subroutine CUL_HM_Attr redefined at ./FHEM/10_CUL_HM.pm line 576, <$fh> line 173.
Subroutine CUL_HM_AttrCheck redefined at ./FHEM/10_CUL_HM.pm line 860, <$fh> line 173.
Subroutine CUL_HM_prtInit redefined at ./FHEM/10_CUL_HM.pm line 882, <$fh> line 173.
Subroutine CUL_HM_hmInitMsg redefined at ./FHEM/10_CUL_HM.pm line 887, <$fh> line 173.
Subroutine CUL_HM_hmInitMsgUpdt redefined at ./FHEM/10_CUL_HM.pm line 924, <$fh> line 173.
Subroutine CUL_HM_Notify redefined at ./FHEM/10_CUL_HM.pm line 951, <$fh> line 173.
Subroutine CUL_HM_setupHMLAN redefined at ./FHEM/10_CUL_HM.pm line 964, <$fh> line 173.
Subroutine CUL_HM_Parse redefined at ./FHEM/10_CUL_HM.pm line 1001, <$fh> line 173.
Subroutine CUL_HM_parseCommon redefined at ./FHEM/10_CUL_HM.pm line 2639, <$fh> line 173.
Subroutine CUL_HM_m_setCh redefined at ./FHEM/10_CUL_HM.pm line 3137, <$fh> line 173.
Subroutine CUL_HM_queueUpdtCfg redefined at ./FHEM/10_CUL_HM.pm line 3148, <$fh> line 173.
Subroutine CUL_HM_parseSDteam redefined at ./FHEM/10_CUL_HM.pm line 3166, <$fh> line 173.
Subroutine CUL_HM_updtSDTeam redefined at ./FHEM/10_CUL_HM.pm line 3224, <$fh> line 173.
Subroutine CUL_HM_pushEvnts redefined at ./FHEM/10_CUL_HM.pm line 3245, <$fh> line 173.
Subroutine CUL_HM_Get redefined at ./FHEM/10_CUL_HM.pm line 3272, <$fh> line 173.
Subroutine CUL_HM_Set redefined at ./FHEM/10_CUL_HM.pm line 3540, <$fh> line 173.
Subroutine CUL_HM_valvePosUpdt redefined at ./FHEM/10_CUL_HM.pm line 5259, <$fh> line 173.
Subroutine CUL_HM_valvePosTmr redefined at ./FHEM/10_CUL_HM.pm line 5326, <$fh> line 173.
Subroutine CUL_HM_weather redefined at ./FHEM/10_CUL_HM.pm line 5358, <$fh> line 173.
Subroutine CUL_HM_infoUpdtDevData redefined at ./FHEM/10_CUL_HM.pm line 5367, <$fh> line 173.
Subroutine CUL_HM_getConfig redefined at ./FHEM/10_CUL_HM.pm line 5417, <$fh> line 173.
Subroutine CUL_HM_calcDisWmSet redefined at ./FHEM/10_CUL_HM.pm line 5480, <$fh> line 173.
Subroutine CUL_HM_calcDisWm redefined at ./FHEM/10_CUL_HM.pm line 5498, <$fh> line 173.
Subroutine CUL_HM_RemoveHMPair redefined at ./FHEM/10_CUL_HM.pm line 5543, <$fh> line 173.
Subroutine CUL_HM_pushConfig redefined at ./FHEM/10_CUL_HM.pm line 5553, <$fh> line 173.
Subroutine CUL_HM_PushCmdStack redefined at ./FHEM/10_CUL_HM.pm line 5633, <$fh> line 173.
Subroutine CUL_HM_ProcessCmdStack redefined at ./FHEM/10_CUL_HM.pm line 5647, <$fh> line 173.
Subroutine CUL_HM_respWaitSu redefined at ./FHEM/10_CUL_HM.pm line 5662, <$fh> line 173.
Subroutine CUL_HM_responseSetup redefined at ./FHEM/10_CUL_HM.pm line 5688, <$fh> line 173.
Subroutine CUL_HM_sndIfOpen redefined at ./FHEM/10_CUL_HM.pm line 5823, <$fh> line 173.
Subroutine CUL_HM_SndCmd redefined at ./FHEM/10_CUL_HM.pm line 5861, <$fh> line 173.
Subroutine CUL_HM_statCnt redefined at ./FHEM/10_CUL_HM.pm line 5936, <$fh> line 173.
Subroutine CUL_HM_statCntRfresh redefined at ./FHEM/10_CUL_HM.pm line 5967, <$fh> line 173.
Subroutine CUL_HM_respPendRm redefined at ./FHEM/10_CUL_HM.pm line 5984, <$fh> line 173.
Subroutine CUL_HM_respPendTout redefined at ./FHEM/10_CUL_HM.pm line 5999, <$fh> line 173.
Subroutine CUL_HM_respPendToutProlong redefined at ./FHEM/10_CUL_HM.pm line 6094, <$fh> line 173.
Subroutine CUL_HM_FWupdateSteps redefined at ./FHEM/10_CUL_HM.pm line 6100, <$fh> line 173.
Subroutine CUL_HM_FWupdateBTo redefined at ./FHEM/10_CUL_HM.pm line 6168, <$fh> line 173.
Subroutine CUL_HM_FWupdateEnd redefined at ./FHEM/10_CUL_HM.pm line 6180, <$fh> line 173.
Subroutine CUL_HM_FWupdateSpeed redefined at ./FHEM/10_CUL_HM.pm line 6202, <$fh> line 173.
Subroutine CUL_HM_FWupdateSim redefined at ./FHEM/10_CUL_HM.pm line 6213, <$fh> line 173.
2015.08.30 09:40:58 1: reload: Error:Modul 10_CUL_HM deactivated:
Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232, <$fh> line 173.
Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6233, <$fh> line 173.
BEGIN not safe after errors--compilation aborted at ./FHEM/10_CUL_HM.pm line 6451, <$fh> line 173.
2015.08.30 09:40:58 0: Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232, <$fh> line 173.
Subroutine CUL_HM_Initialize redefined at ./FHEM/10_CUL_HM.pm line 131, <$fh> line 178.
Subroutine CUL_HM_updateConfig redefined at ./FHEM/10_CUL_HM.pm line 213, <$fh> line 178.
Subroutine CUL_HM_Define redefined at ./FHEM/10_CUL_HM.pm line 465, <$fh> line 178.
Subroutine CUL_HM_Undef redefined at ./FHEM/10_CUL_HM.pm line 520, <$fh> line 178.
Subroutine CUL_HM_Rename redefined at ./FHEM/10_CUL_HM.pm line 539, <$fh> line 178.
Subroutine CUL_HM_Attr redefined at ./FHEM/10_CUL_HM.pm line 576, <$fh> line 178.
Subroutine CUL_HM_AttrCheck redefined at ./FHEM/10_CUL_HM.pm line 860, <$fh> line 178.
Subroutine CUL_HM_prtInit redefined at ./FHEM/10_CUL_HM.pm line 882, <$fh> line 178.
Subroutine CUL_HM_hmInitMsg redefined at ./FHEM/10_CUL_HM.pm line 887, <$fh> line 178.
Subroutine CUL_HM_hmInitMsgUpdt redefined at ./FHEM/10_CUL_HM.pm line 924, <$fh> line 178.
Subroutine CUL_HM_Notify redefined at ./FHEM/10_CUL_HM.pm line 951, <$fh> line 178.
Subroutine CUL_HM_setupHMLAN redefined at ./FHEM/10_CUL_HM.pm line 964, <$fh> line 178.
Subroutine CUL_HM_Parse redefined at ./FHEM/10_CUL_HM.pm line 1001, <$fh> line 178.
Subroutine CUL_HM_parseCommon redefined at ./FHEM/10_CUL_HM.pm line 2639, <$fh> line 178.
Subroutine CUL_HM_m_setCh redefined at ./FHEM/10_CUL_HM.pm line 3137, <$fh> line 178.
Subroutine CUL_HM_queueUpdtCfg redefined at ./FHEM/10_CUL_HM.pm line 3148, <$fh> line 178.
Subroutine CUL_HM_parseSDteam redefined at ./FHEM/10_CUL_HM.pm line 3166, <$fh> line 178.
Subroutine CUL_HM_updtSDTeam redefined at ./FHEM/10_CUL_HM.pm line 3224, <$fh> line 178.
Subroutine CUL_HM_pushEvnts redefined at ./FHEM/10_CUL_HM.pm line 3245, <$fh> line 178.
Subroutine CUL_HM_Get redefined at ./FHEM/10_CUL_HM.pm line 3272, <$fh> line 178.
Subroutine CUL_HM_Set redefined at ./FHEM/10_CUL_HM.pm line 3540, <$fh> line 178.
Subroutine CUL_HM_valvePosUpdt redefined at ./FHEM/10_CUL_HM.pm line 5259, <$fh> line 178.
Subroutine CUL_HM_valvePosTmr redefined at ./FHEM/10_CUL_HM.pm line 5326, <$fh> line 178.
Subroutine CUL_HM_weather redefined at ./FHEM/10_CUL_HM.pm line 5358, <$fh> line 178.
Subroutine CUL_HM_infoUpdtDevData redefined at ./FHEM/10_CUL_HM.pm line 5367, <$fh> line 178.
Subroutine CUL_HM_getConfig redefined at ./FHEM/10_CUL_HM.pm line 5417, <$fh> line 178.
Subroutine CUL_HM_calcDisWmSet redefined at ./FHEM/10_CUL_HM.pm line 5480, <$fh> line 178.
Subroutine CUL_HM_calcDisWm redefined at ./FHEM/10_CUL_HM.pm line 5498, <$fh> line 178.
Subroutine CUL_HM_RemoveHMPair redefined at ./FHEM/10_CUL_HM.pm line 5543, <$fh> line 178.
Subroutine CUL_HM_pushConfig redefined at ./FHEM/10_CUL_HM.pm line 5553, <$fh> line 178.
Subroutine CUL_HM_PushCmdStack redefined at ./FHEM/10_CUL_HM.pm line 5633, <$fh> line 178.
Subroutine CUL_HM_ProcessCmdStack redefined at ./FHEM/10_CUL_HM.pm line 5647, <$fh> line 178.
Subroutine CUL_HM_respWaitSu redefined at ./FHEM/10_CUL_HM.pm line 5662, <$fh> line 178.
Subroutine CUL_HM_responseSetup redefined at ./FHEM/10_CUL_HM.pm line 5688, <$fh> line 178.
Subroutine CUL_HM_sndIfOpen redefined at ./FHEM/10_CUL_HM.pm line 5823, <$fh> line 178.
Subroutine CUL_HM_SndCmd redefined at ./FHEM/10_CUL_HM.pm line 5861, <$fh> line 178.
Subroutine CUL_HM_statCnt redefined at ./FHEM/10_CUL_HM.pm line 5936, <$fh> line 178.
Subroutine CUL_HM_statCntRfresh redefined at ./FHEM/10_CUL_HM.pm line 5967, <$fh> line 178.
Subroutine CUL_HM_respPendRm redefined at ./FHEM/10_CUL_HM.pm line 5984, <$fh> line 178.
Subroutine CUL_HM_respPendTout redefined at ./FHEM/10_CUL_HM.pm line 5999, <$fh> line 178.
Subroutine CUL_HM_respPendToutProlong redefined at ./FHEM/10_CUL_HM.pm line 6094, <$fh> line 178.
Subroutine CUL_HM_FWupdateSteps redefined at ./FHEM/10_CUL_HM.pm line 6100, <$fh> line 178.
Subroutine CUL_HM_FWupdateBTo redefined at ./FHEM/10_CUL_HM.pm line 6168, <$fh> line 178.
Subroutine CUL_HM_FWupdateEnd redefined at ./FHEM/10_CUL_HM.pm line 6180, <$fh> line 178.
Subroutine CUL_HM_FWupdateSpeed redefined at ./FHEM/10_CUL_HM.pm line 6202, <$fh> line 178.
Subroutine CUL_HM_FWupdateSim redefined at ./FHEM/10_CUL_HM.pm line 6213, <$fh> line 178.
Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232, <$fh> line 178.
Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6233, <$fh> line 178.
BEGIN not safe after errors--compilation aborted at ./FHEM/10_CUL_HM.pm line 6451, <$fh> line 178.
2015.08.30 09:40:58 0: Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232, <$fh> line 178.
Subroutine CUL_HM_Initialize redefined at ./FHEM/10_CUL_HM.pm line 131, <$fh> line 181.
Subroutine CUL_HM_updateConfig redefined at ./FHEM/10_CUL_HM.pm line 213, <$fh> line 181.
Subroutine CUL_HM_Define redefined at ./FHEM/10_CUL_HM.pm line 465, <$fh> line 181.
Subroutine CUL_HM_Undef redefined at ./FHEM/10_CUL_HM.pm line 520, <$fh> line 181.
Subroutine CUL_HM_Rename redefined at ./FHEM/10_CUL_HM.pm line 539, <$fh> line 181.
Subroutine CUL_HM_Attr redefined at ./FHEM/10_CUL_HM.pm line 576, <$fh> line 181.
Subroutine CUL_HM_AttrCheck redefined at ./FHEM/10_CUL_HM.pm line 860, <$fh> line 181.
Subroutine CUL_HM_prtInit redefined at ./FHEM/10_CUL_HM.pm line 882, <$fh> line 181.
Subroutine CUL_HM_hmInitMsg redefined at ./FHEM/10_CUL_HM.pm line 887, <$fh> line 181.
Subroutine CUL_HM_hmInitMsgUpdt redefined at ./FHEM/10_CUL_HM.pm line 924, <$fh> line 181.
Subroutine CUL_HM_Notify redefined at ./FHEM/10_CUL_HM.pm line 951, <$fh> line 181.
Subroutine CUL_HM_setupHMLAN redefined at ./FHEM/10_CUL_HM.pm line 964, <$fh> line 181.
Subroutine CUL_HM_Parse redefined at ./FHEM/10_CUL_HM.pm line 1001, <$fh> line 181.
Subroutine CUL_HM_parseCommon redefined at ./FHEM/10_CUL_HM.pm line 2639, <$fh> line 181.
Subroutine CUL_HM_m_setCh redefined at ./FHEM/10_CUL_HM.pm line 3137, <$fh> line 181.
Subroutine CUL_HM_queueUpdtCfg redefined at ./FHEM/10_CUL_HM.pm line 3148, <$fh> line 181.
Subroutine CUL_HM_parseSDteam redefined at ./FHEM/10_CUL_HM.pm line 3166, <$fh> line 181.
Subroutine CUL_HM_updtSDTeam redefined at ./FHEM/10_CUL_HM.pm line 3224, <$fh> line 181.
Subroutine CUL_HM_pushEvnts redefined at ./FHEM/10_CUL_HM.pm line 3245, <$fh> line 181.
Subroutine CUL_HM_Get redefined at ./FHEM/10_CUL_HM.pm line 3272, <$fh> line 181.
Subroutine CUL_HM_Set redefined at ./FHEM/10_CUL_HM.pm line 3540, <$fh> line 181.
Subroutine CUL_HM_valvePosUpdt redefined at ./FHEM/10_CUL_HM.pm line 5259, <$fh> line 181.
Subroutine CUL_HM_valvePosTmr redefined at ./FHEM/10_CUL_HM.pm line 5326, <$fh> line 181.
Subroutine CUL_HM_weather redefined at ./FHEM/10_CUL_HM.pm line 5358, <$fh> line 181.
Subroutine CUL_HM_infoUpdtDevData redefined at ./FHEM/10_CUL_HM.pm line 5367, <$fh> line 181.
Subroutine CUL_HM_getConfig redefined at ./FHEM/10_CUL_HM.pm line 5417, <$fh> line 181.
Subroutine CUL_HM_calcDisWmSet redefined at ./FHEM/10_CUL_HM.pm line 5480, <$fh> line 181.
Subroutine CUL_HM_calcDisWm redefined at ./FHEM/10_CUL_HM.pm line 5498, <$fh> line 181.
Subroutine CUL_HM_RemoveHMPair redefined at ./FHEM/10_CUL_HM.pm line 5543, <$fh> line 181.
Subroutine CUL_HM_pushConfig redefined at ./FHEM/10_CUL_HM.pm line 5553, <$fh> line 181.
Subroutine CUL_HM_PushCmdStack redefined at ./FHEM/10_CUL_HM.pm line 5633, <$fh> line 181.
Subroutine CUL_HM_ProcessCmdStack redefined at ./FHEM/10_CUL_HM.pm line 5647, <$fh> line 181.
Subroutine CUL_HM_respWaitSu redefined at ./FHEM/10_CUL_HM.pm line 5662, <$fh> line 181.
Subroutine CUL_HM_responseSetup redefined at ./FHEM/10_CUL_HM.pm line 5688, <$fh> line 181.
Subroutine CUL_HM_sndIfOpen redefined at ./FHEM/10_CUL_HM.pm line 5823, <$fh> line 181.
Subroutine CUL_HM_SndCmd redefined at ./FHEM/10_CUL_HM.pm line 5861, <$fh> line 181.
Subroutine CUL_HM_statCnt redefined at ./FHEM/10_CUL_HM.pm line 5936, <$fh> line 181.
Subroutine CUL_HM_statCntRfresh redefined at ./FHEM/10_CUL_HM.pm line 5967, <$fh> line 181.
Subroutine CUL_HM_respPendRm redefined at ./FHEM/10_CUL_HM.pm line 5984, <$fh> line 181.
Subroutine CUL_HM_respPendTout redefined at ./FHEM/10_CUL_HM.pm line 5999, <$fh> line 181.
Subroutine CUL_HM_respPendToutProlong redefined at ./FHEM/10_CUL_HM.pm line 6094, <$fh> line 181.
Subroutine CUL_HM_FWupdateSteps redefined at ./FHEM/10_CUL_HM.pm line 6100, <$fh> line 181.
Subroutine CUL_HM_FWupdateBTo redefined at ./FHEM/10_CUL_HM.pm line 6168, <$fh> line 181.
Subroutine CUL_HM_FWupdateEnd redefined at ./FHEM/10_CUL_HM.pm line 6180, <$fh> line 181.
Subroutine CUL_HM_FWupdateSpeed redefined at ./FHEM/10_CUL_HM.pm line 6202, <$fh> line 181.
Subroutine CUL_HM_FWupdateSim redefined at ./FHEM/10_CUL_HM.pm line 6213, <$fh> line 181.
2015.08.30 09:40:59 1: reload: Error:Modul 10_CUL_HM deactivated:
Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232, <$fh> line 181.
Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6233, <$fh> line 181.
BEGIN not safe after errors--compilation aborted at ./FHEM/10_CUL_HM.pm line 6451, <$fh> line 181.
2015.08.30 09:40:59 0: Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232, <$fh> line 181.
Subroutine CUL_HM_Initialize redefined at ./FHEM/10_CUL_HM.pm line 131, <$fh> line 184.
Subroutine CUL_HM_updateConfig redefined at ./FHEM/10_CUL_HM.pm line 213, <$fh> line 184.
Subroutine CUL_HM_Define redefined at ./FHEM/10_CUL_HM.pm line 465, <$fh> line 184.
Subroutine CUL_HM_Undef redefined at ./FHEM/10_CUL_HM.pm line 520, <$fh> line 184.
Subroutine CUL_HM_Rename redefined at ./FHEM/10_CUL_HM.pm line 539, <$fh> line 184.
Subroutine CUL_HM_Attr redefined at ./FHEM/10_CUL_HM.pm line 576, <$fh> line 184.
Subroutine CUL_HM_AttrCheck redefined at ./FHEM/10_CUL_HM.pm line 860, <$fh> line 184.
Subroutine CUL_HM_prtInit redefined at ./FHEM/10_CUL_HM.pm line 882, <$fh> line 184.
Subroutine CUL_HM_hmInitMsg redefined at ./FHEM/10_CUL_HM.pm line 887, <$fh> line 184.
Subroutine CUL_HM_hmInitMsgUpdt redefined at ./FHEM/10_CUL_HM.pm line 924, <$fh> line 184.
Subroutine CUL_HM_Notify redefined at ./FHEM/10_CUL_HM.pm line 951, <$fh> line 184.
Subroutine CUL_HM_setupHMLAN redefined at ./FHEM/10_CUL_HM.pm line 964, <$fh> line 184.
Subroutine CUL_HM_Parse redefined at ./FHEM/10_CUL_HM.pm line 1001, <$fh> line 184.
Subroutine CUL_HM_parseCommon redefined at ./FHEM/10_CUL_HM.pm line 2639, <$fh> line 184.
Subroutine CUL_HM_m_setCh redefined at ./FHEM/10_CUL_HM.pm line 3137, <$fh> line 184.
Subroutine CUL_HM_queueUpdtCfg redefined at ./FHEM/10_CUL_HM.pm line 3148, <$fh> line 184.
Subroutine CUL_HM_parseSDteam redefined at ./FHEM/10_CUL_HM.pm line 3166, <$fh> line 184.
Subroutine CUL_HM_updtSDTeam redefined at ./FHEM/10_CUL_HM.pm line 3224, <$fh> line 184.
Subroutine CUL_HM_pushEvnts redefined at ./FHEM/10_CUL_HM.pm line 3245, <$fh> line 184.
Subroutine CUL_HM_Get redefined at ./FHEM/10_CUL_HM.pm line 3272, <$fh> line 184.
Subroutine CUL_HM_Set redefined at ./FHEM/10_CUL_HM.pm line 3540, <$fh> line 184.
Subroutine CUL_HM_valvePosUpdt redefined at ./FHEM/10_CUL_HM.pm line 5259, <$fh> line 184.
Subroutine CUL_HM_valvePosTmr redefined at ./FHEM/10_CUL_HM.pm line 5326, <$fh> line 184.
Subroutine CUL_HM_weather redefined at ./FHEM/10_CUL_HM.pm line 5358, <$fh> line 184.
Subroutine CUL_HM_infoUpdtDevData redefined at ./FHEM/10_CUL_HM.pm line 5367, <$fh> line 184.
Subroutine CUL_HM_getConfig redefined at ./FHEM/10_CUL_HM.pm line 5417, <$fh> line 184.
Subroutine CUL_HM_calcDisWmSet redefined at ./FHEM/10_CUL_HM.pm line 5480, <$fh> line 184.
Subroutine CUL_HM_calcDisWm redefined at ./FHEM/10_CUL_HM.pm line 5498, <$fh> line 184.
Subroutine CUL_HM_RemoveHMPair redefined at ./FHEM/10_CUL_HM.pm line 5543, <$fh> line 184.
Subroutine CUL_HM_pushConfig redefined at ./FHEM/10_CUL_HM.pm line 5553, <$fh> line 184.
Subroutine CUL_HM_PushCmdStack redefined at ./FHEM/10_CUL_HM.pm line 5633, <$fh> line 184.
Subroutine CUL_HM_ProcessCmdStack redefined at ./FHEM/10_CUL_HM.pm line 5647, <$fh> line 184.
Subroutine CUL_HM_respWaitSu redefined at ./FHEM/10_CUL_HM.pm line 5662, <$fh> line 184.
Subroutine CUL_HM_responseSetup redefined at ./FHEM/10_CUL_HM.pm line 5688, <$fh> line 184.
Subroutine CUL_HM_sndIfOpen redefined at ./FHEM/10_CUL_HM.pm line 5823, <$fh> line 184.
Subroutine CUL_HM_SndCmd redefined at ./FHEM/10_CUL_HM.pm line 5861, <$fh> line 184.
Subroutine CUL_HM_statCnt redefined at ./FHEM/10_CUL_HM.pm line 5936, <$fh> line 184.
Subroutine CUL_HM_statCntRfresh redefined at ./FHEM/10_CUL_HM.pm line 5967, <$fh> line 184.
Subroutine CUL_HM_respPendRm redefined at ./FHEM/10_CUL_HM.pm line 5984, <$fh> line 184.
Subroutine CUL_HM_respPendTout redefined at ./FHEM/10_CUL_HM.pm line 5999, <$fh> line 184.
Subroutine CUL_HM_respPendToutProlong redefined at ./FHEM/10_CUL_HM.pm line 6094, <$fh> line 184.
Subroutine CUL_HM_FWupdateSteps redefined at ./FHEM/10_CUL_HM.pm line 6100, <$fh> line 184.
Subroutine CUL_HM_FWupdateBTo redefined at ./FHEM/10_CUL_HM.pm line 6168, <$fh> line 184.
Subroutine CUL_HM_FWupdateEnd redefined at ./FHEM/10_CUL_HM.pm line 6180, <$fh> line 184.
Subroutine CUL_HM_FWupdateSpeed redefined at ./FHEM/10_CUL_HM.pm line 6202, <$fh> line 184.
Subroutine CUL_HM_FWupdateSim redefined at ./FHEM/10_CUL_HM.pm line 6213, <$fh> line 184.
Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232, <$fh> line 184.
Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6233, <$fh> line 184.
BEGIN not safe after errors--compilation aborted at ./FHEM/10_CUL_HM.pm line 6451, <$fh> line 184.
2015.08.30 09:40:59 0: Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232, <$fh> line 184.
Subroutine CUL_HM_Initialize redefined at ./FHEM/10_CUL_HM.pm line 131, <$fh> line 202.
Subroutine CUL_HM_updateConfig redefined at ./FHEM/10_CUL_HM.pm line 213, <$fh> line 202.
Subroutine CUL_HM_Define redefined at ./FHEM/10_CUL_HM.pm line 465, <$fh> line 202.
Subroutine CUL_HM_Undef redefined at ./FHEM/10_CUL_HM.pm line 520, <$fh> line 202.
Subroutine CUL_HM_Rename redefined at ./FHEM/10_CUL_HM.pm line 539, <$fh> line 202.
Subroutine CUL_HM_Attr redefined at ./FHEM/10_CUL_HM.pm line 576, <$fh> line 202.
Subroutine CUL_HM_AttrCheck redefined at ./FHEM/10_CUL_HM.pm line 860, <$fh> line 202.
Subroutine CUL_HM_prtInit redefined at ./FHEM/10_CUL_HM.pm line 882, <$fh> line 202.
Subroutine CUL_HM_hmInitMsg redefined at ./FHEM/10_CUL_HM.pm line 887, <$fh> line 202.
Subroutine CUL_HM_hmInitMsgUpdt redefined at ./FHEM/10_CUL_HM.pm line 924, <$fh> line 202.
Subroutine CUL_HM_Notify redefined at ./FHEM/10_CUL_HM.pm line 951, <$fh> line 202.
Subroutine CUL_HM_setupHMLAN redefined at ./FHEM/10_CUL_HM.pm line 964, <$fh> line 202.
Subroutine CUL_HM_Parse redefined at ./FHEM/10_CUL_HM.pm line 1001, <$fh> line 202.
Subroutine CUL_HM_parseCommon redefined at ./FHEM/10_CUL_HM.pm line 2639, <$fh> line 202.
Subroutine CUL_HM_m_setCh redefined at ./FHEM/10_CUL_HM.pm line 3137, <$fh> line 202.
Subroutine CUL_HM_queueUpdtCfg redefined at ./FHEM/10_CUL_HM.pm line 3148, <$fh> line 202.
Subroutine CUL_HM_parseSDteam redefined at ./FHEM/10_CUL_HM.pm line 3166, <$fh> line 202.
Subroutine CUL_HM_updtSDTeam redefined at ./FHEM/10_CUL_HM.pm line 3224, <$fh> line 202.
Subroutine CUL_HM_pushEvnts redefined at ./FHEM/10_CUL_HM.pm line 3245, <$fh> line 202.
Subroutine CUL_HM_Get redefined at ./FHEM/10_CUL_HM.pm line 3272, <$fh> line 202.
Subroutine CUL_HM_Set redefined at ./FHEM/10_CUL_HM.pm line 3540, <$fh> line 202.
Subroutine CUL_HM_valvePosUpdt redefined at ./FHEM/10_CUL_HM.pm line 5259, <$fh> line 202.
Subroutine CUL_HM_valvePosTmr redefined at ./FHEM/10_CUL_HM.pm line 5326, <$fh> line 202.
Subroutine CUL_HM_weather redefined at ./FHEM/10_CUL_HM.pm line 5358, <$fh> line 202.
Subroutine CUL_HM_infoUpdtDevData redefined at ./FHEM/10_CUL_HM.pm line 5367, <$fh> line 202.
Subroutine CUL_HM_getConfig redefined at ./FHEM/10_CUL_HM.pm line 5417, <$fh> line 202.
Subroutine CUL_HM_calcDisWmSet redefined at ./FHEM/10_CUL_HM.pm line 5480, <$fh> line 202.
Subroutine CUL_HM_calcDisWm redefined at ./FHEM/10_CUL_HM.pm line 5498, <$fh> line 202.
Subroutine CUL_HM_RemoveHMPair redefined at ./FHEM/10_CUL_HM.pm line 5543, <$fh> line 202.
Subroutine CUL_HM_pushConfig redefined at ./FHEM/10_CUL_HM.pm line 5553, <$fh> line 202.
Subroutine CUL_HM_PushCmdStack redefined at ./FHEM/10_CUL_HM.pm line 5633, <$fh> line 202.
Subroutine CUL_HM_ProcessCmdStack redefined at ./FHEM/10_CUL_HM.pm line 5647, <$fh> line 202.
Subroutine CUL_HM_respWaitSu redefined at ./FHEM/10_CUL_HM.pm line 5662, <$fh> line 202.
Subroutine CUL_HM_responseSetup redefined at ./FHEM/10_CUL_HM.pm line 5688, <$fh> line 202.
Subroutine CUL_HM_sndIfOpen redefined at ./FHEM/10_CUL_HM.pm line 5823, <$fh> line 202.
Subroutine CUL_HM_SndCmd redefined at ./FHEM/10_CUL_HM.pm line 5861, <$fh> line 202.
Subroutine CUL_HM_statCnt redefined at ./FHEM/10_CUL_HM.pm line 5936, <$fh> line 202.
Subroutine CUL_HM_statCntRfresh redefined at ./FHEM/10_CUL_HM.pm line 5967, <$fh> line 202.
Subroutine CUL_HM_respPendRm redefined at ./FHEM/10_CUL_HM.pm line 5984, <$fh> line 202.
Subroutine CUL_HM_respPendTout redefined at ./FHEM/10_CUL_HM.pm line 5999, <$fh> line 202.
Subroutine CUL_HM_respPendToutProlong redefined at ./FHEM/10_CUL_HM.pm line 6094, <$fh> line 202.
Subroutine CUL_HM_FWupdateSteps redefined at ./FHEM/10_CUL_HM.pm line 6100, <$fh> line 202.
Subroutine CUL_HM_FWupdateBTo redefined at ./FHEM/10_CUL_HM.pm line 6168, <$fh> line 202.
Subroutine CUL_HM_FWupdateEnd redefined at ./FHEM/10_CUL_HM.pm line 6180, <$fh> line 202.
Subroutine CUL_HM_FWupdateSpeed redefined at ./FHEM/10_CUL_HM.pm line 6202, <$fh> line 202.
Subroutine CUL_HM_FWupdateSim redefined at ./FHEM/10_CUL_HM.pm line 6213, <$fh> line 202.
2015.08.30 09:41:00 1: reload: Error:Modul 10_CUL_HM deactivated:
Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232, <$fh> line 202.
Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6233, <$fh> line 202.
BEGIN not safe after errors--compilation aborted at ./FHEM/10_CUL_HM.pm line 6451, <$fh> line 202.
2015.08.30 09:41:00 0: Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232, <$fh> line 202.
Subroutine CUL_HM_Initialize redefined at ./FHEM/10_CUL_HM.pm line 131, <$fh> line 205.
Subroutine CUL_HM_updateConfig redefined at ./FHEM/10_CUL_HM.pm line 213, <$fh> line 205.
Subroutine CUL_HM_Define redefined at ./FHEM/10_CUL_HM.pm line 465, <$fh> line 205.
Subroutine CUL_HM_Undef redefined at ./FHEM/10_CUL_HM.pm line 520, <$fh> line 205.
Subroutine CUL_HM_Rename redefined at ./FHEM/10_CUL_HM.pm line 539, <$fh> line 205.
Subroutine CUL_HM_Attr redefined at ./FHEM/10_CUL_HM.pm line 576, <$fh> line 205.
Subroutine CUL_HM_AttrCheck redefined at ./FHEM/10_CUL_HM.pm line 860, <$fh> line 205.
Subroutine CUL_HM_prtInit redefined at ./FHEM/10_CUL_HM.pm line 882, <$fh> line 205.
Subroutine CUL_HM_hmInitMsg redefined at ./FHEM/10_CUL_HM.pm line 887, <$fh> line 205.
Subroutine CUL_HM_hmInitMsgUpdt redefined at ./FHEM/10_CUL_HM.pm line 924, <$fh> line 205.
Subroutine CUL_HM_Notify redefined at ./FHEM/10_CUL_HM.pm line 951, <$fh> line 205.
Subroutine CUL_HM_setupHMLAN redefined at ./FHEM/10_CUL_HM.pm line 964, <$fh> line 205.
Subroutine CUL_HM_Parse redefined at ./FHEM/10_CUL_HM.pm line 1001, <$fh> line 205.
Subroutine CUL_HM_parseCommon redefined at ./FHEM/10_CUL_HM.pm line 2639, <$fh> line 205.
Subroutine CUL_HM_m_setCh redefined at ./FHEM/10_CUL_HM.pm line 3137, <$fh> line 205.
Subroutine CUL_HM_queueUpdtCfg redefined at ./FHEM/10_CUL_HM.pm line 3148, <$fh> line 205.
Subroutine CUL_HM_parseSDteam redefined at ./FHEM/10_CUL_HM.pm line 3166, <$fh> line 205.
Subroutine CUL_HM_updtSDTeam redefined at ./FHEM/10_CUL_HM.pm line 3224, <$fh> line 205.
Subroutine CUL_HM_pushEvnts redefined at ./FHEM/10_CUL_HM.pm line 3245, <$fh> line 205.
Subroutine CUL_HM_Get redefined at ./FHEM/10_CUL_HM.pm line 3272, <$fh> line 205.
Subroutine CUL_HM_Set redefined at ./FHEM/10_CUL_HM.pm line 3540, <$fh> line 205.
Subroutine CUL_HM_valvePosUpdt redefined at ./FHEM/10_CUL_HM.pm line 5259, <$fh> line 205.
Subroutine CUL_HM_valvePosTmr redefined at ./FHEM/10_CUL_HM.pm line 5326, <$fh> line 205.
Subroutine CUL_HM_weather redefined at ./FHEM/10_CUL_HM.pm line 5358, <$fh> line 205.
Subroutine CUL_HM_infoUpdtDevData redefined at ./FHEM/10_CUL_HM.pm line 5367, <$fh> line 205.
Subroutine CUL_HM_getConfig redefined at ./FHEM/10_CUL_HM.pm line 5417, <$fh> line 205.
Subroutine CUL_HM_calcDisWmSet redefined at ./FHEM/10_CUL_HM.pm line 5480, <$fh> line 205.
Subroutine CUL_HM_calcDisWm redefined at ./FHEM/10_CUL_HM.pm line 5498, <$fh> line 205.
Subroutine CUL_HM_RemoveHMPair redefined at ./FHEM/10_CUL_HM.pm line 5543, <$fh> line 205.
Subroutine CUL_HM_pushConfig redefined at ./FHEM/10_CUL_HM.pm line 5553, <$fh> line 205.
Subroutine CUL_HM_PushCmdStack redefined at ./FHEM/10_CUL_HM.pm line 5633, <$fh> line 205.
Subroutine CUL_HM_ProcessCmdStack redefined at ./FHEM/10_CUL_HM.pm line 5647, <$fh> line 205.
Subroutine CUL_HM_respWaitSu redefined at ./FHEM/10_CUL_HM.pm line 5662, <$fh> line 205.
Subroutine CUL_HM_responseSetup redefined at ./FHEM/10_CUL_HM.pm line 5688, <$fh> line 205.
Subroutine CUL_HM_sndIfOpen redefined at ./FHEM/10_CUL_HM.pm line 5823, <$fh> line 205.
Subroutine CUL_HM_SndCmd redefined at ./FHEM/10_CUL_HM.pm line 5861, <$fh> line 205.
Subroutine CUL_HM_statCnt redefined at ./FHEM/10_CUL_HM.pm line 5936, <$fh> line 205.
Subroutine CUL_HM_statCntRfresh redefined at ./FHEM/10_CUL_HM.pm line 5967, <$fh> line 205.
Subroutine CUL_HM_respPendRm redefined at ./FHEM/10_CUL_HM.pm line 5984, <$fh> line 205.
Subroutine CUL_HM_respPendTout redefined at ./FHEM/10_CUL_HM.pm line 5999, <$fh> line 205.
Subroutine CUL_HM_respPendToutProlong redefined at ./FHEM/10_CUL_HM.pm line 6094, <$fh> line 205.
Subroutine CUL_HM_FWupdateSteps redefined at ./FHEM/10_CUL_HM.pm line 6100, <$fh> line 205.
Subroutine CUL_HM_FWupdateBTo redefined at ./FHEM/10_CUL_HM.pm line 6168, <$fh> line 205.
Subroutine CUL_HM_FWupdateEnd redefined at ./FHEM/10_CUL_HM.pm line 6180, <$fh> line 205.
Subroutine CUL_HM_FWupdateSpeed redefined at ./FHEM/10_CUL_HM.pm line 6202, <$fh> line 205.
Subroutine CUL_HM_FWupdateSim redefined at ./FHEM/10_CUL_HM.pm line 6213, <$fh> line 205.
Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232, <$fh> line 205.
Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6233, <$fh> line 205.
BEGIN not safe after errors--compilation aborted at ./FHEM/10_CUL_HM.pm line 6451, <$fh> line 205.
2015.08.30 09:41:00 0: Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232, <$fh> line 205.
Subroutine CUL_HM_Initialize redefined at ./FHEM/10_CUL_HM.pm line 131, <$fh> line 211.
Subroutine CUL_HM_updateConfig redefined at ./FHEM/10_CUL_HM.pm line 213, <$fh> line 211.
Subroutine CUL_HM_Define redefined at ./FHEM/10_CUL_HM.pm line 465, <$fh> line 211.
Subroutine CUL_HM_Undef redefined at ./FHEM/10_CUL_HM.pm line 520, <$fh> line 211.
Subroutine CUL_HM_Rename redefined at ./FHEM/10_CUL_HM.pm line 539, <$fh> line 211.
Subroutine CUL_HM_Attr redefined at ./FHEM/10_CUL_HM.pm line 576, <$fh> line 211.
Subroutine CUL_HM_AttrCheck redefined at ./FHEM/10_CUL_HM.pm line 860, <$fh> line 211.
Subroutine CUL_HM_prtInit redefined at ./FHEM/10_CUL_HM.pm line 882, <$fh> line 211.
Subroutine CUL_HM_hmInitMsg redefined at ./FHEM/10_CUL_HM.pm line 887, <$fh> line 211.
Subroutine CUL_HM_hmInitMsgUpdt redefined at ./FHEM/10_CUL_HM.pm line 924, <$fh> line 211.
Subroutine CUL_HM_Notify redefined at ./FHEM/10_CUL_HM.pm line 951, <$fh> line 211.
Subroutine CUL_HM_setupHMLAN redefined at ./FHEM/10_CUL_HM.pm line 964, <$fh> line 211.
Subroutine CUL_HM_Parse redefined at ./FHEM/10_CUL_HM.pm line 1001, <$fh> line 211.
Subroutine CUL_HM_parseCommon redefined at ./FHEM/10_CUL_HM.pm line 2639, <$fh> line 211.
Subroutine CUL_HM_m_setCh redefined at ./FHEM/10_CUL_HM.pm line 3137, <$fh> line 211.
Subroutine CUL_HM_queueUpdtCfg redefined at ./FHEM/10_CUL_HM.pm line 3148, <$fh> line 211.
Subroutine CUL_HM_parseSDteam redefined at ./FHEM/10_CUL_HM.pm line 3166, <$fh> line 211.
Subroutine CUL_HM_updtSDTeam redefined at ./FHEM/10_CUL_HM.pm line 3224, <$fh> line 211.
Subroutine CUL_HM_pushEvnts redefined at ./FHEM/10_CUL_HM.pm line 3245, <$fh> line 211.
Subroutine CUL_HM_Get redefined at ./FHEM/10_CUL_HM.pm line 3272, <$fh> line 211.
Subroutine CUL_HM_Set redefined at ./FHEM/10_CUL_HM.pm line 3540, <$fh> line 211.
Subroutine CUL_HM_valvePosUpdt redefined at ./FHEM/10_CUL_HM.pm line 5259, <$fh> line 211.
Subroutine CUL_HM_valvePosTmr redefined at ./FHEM/10_CUL_HM.pm line 5326, <$fh> line 211.
Subroutine CUL_HM_weather redefined at ./FHEM/10_CUL_HM.pm line 5358, <$fh> line 211.
Subroutine CUL_HM_infoUpdtDevData redefined at ./FHEM/10_CUL_HM.pm line 5367, <$fh> line 211.
Subroutine CUL_HM_getConfig redefined at ./FHEM/10_CUL_HM.pm line 5417, <$fh> line 211.
Subroutine CUL_HM_calcDisWmSet redefined at ./FHEM/10_CUL_HM.pm line 5480, <$fh> line 211.
Subroutine CUL_HM_calcDisWm redefined at ./FHEM/10_CUL_HM.pm line 5498, <$fh> line 211.
Subroutine CUL_HM_RemoveHMPair redefined at ./FHEM/10_CUL_HM.pm line 5543, <$fh> line 211.
Subroutine CUL_HM_pushConfig redefined at ./FHEM/10_CUL_HM.pm line 5553, <$fh> line 211.
Subroutine CUL_HM_PushCmdStack redefined at ./FHEM/10_CUL_HM.pm line 5633, <$fh> line 211.
Subroutine CUL_HM_ProcessCmdStack redefined at ./FHEM/10_CUL_HM.pm line 5647, <$fh> line 211.
Subroutine CUL_HM_respWaitSu redefined at ./FHEM/10_CUL_HM.pm line 5662, <$fh> line 211.
Subroutine CUL_HM_responseSetup redefined at ./FHEM/10_CUL_HM.pm line 5688, <$fh> line 211.
Subroutine CUL_HM_sndIfOpen redefined at ./FHEM/10_CUL_HM.pm line 5823, <$fh> line 211.
Subroutine CUL_HM_SndCmd redefined at ./FHEM/10_CUL_HM.pm line 5861, <$fh> line 211.
Subroutine CUL_HM_statCnt redefined at ./FHEM/10_CUL_HM.pm line 5936, <$fh> line 211.
Subroutine CUL_HM_statCntRfresh redefined at ./FHEM/10_CUL_HM.pm line 5967, <$fh> line 211.
Subroutine CUL_HM_respPendRm redefined at ./FHEM/10_CUL_HM.pm line 5984, <$fh> line 211.
Subroutine CUL_HM_respPendTout redefined at ./FHEM/10_CUL_HM.pm line 5999, <$fh> line 211.
Subroutine CUL_HM_respPendToutProlong redefined at ./FHEM/10_CUL_HM.pm line 6094, <$fh> line 211.
Subroutine CUL_HM_FWupdateSteps redefined at ./FHEM/10_CUL_HM.pm line 6100, <$fh> line 211.
Subroutine CUL_HM_FWupdateBTo redefined at ./FHEM/10_CUL_HM.pm line 6168, <$fh> line 211.
Subroutine CUL_HM_FWupdateEnd redefined at ./FHEM/10_CUL_HM.pm line 6180, <$fh> line 211.
Subroutine CUL_HM_FWupdateSpeed redefined at ./FHEM/10_CUL_HM.pm line 6202, <$fh> line 211.
Subroutine CUL_HM_FWupdateSim redefined at ./FHEM/10_CUL_HM.pm line 6213, <$fh> line 211.
2015.08.30 09:41:01 1: reload: Error:Modul 10_CUL_HM deactivated:
Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232, <$fh> line 211.
Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6233, <$fh> line 211.
BEGIN not safe after errors--compilation aborted at ./FHEM/10_CUL_HM.pm line 6451, <$fh> line 211.
2015.08.30 09:41:01 0: Global symbol "$nAttr" requires explicit package name at ./FHEM/10_CUL_HM.pm line 6232, <$fh> line 211.
Subroutine CUL_HM_Initialize redefined at ./FHEM/10_CUL_HM.pm line 131, <$fh> line 215.
Subroutine CUL_HM_updateConfig redefined at ./FHEM/10_CUL_HM.pm line 213, <$fh> line 215.
Subroutine CUL_HM_Define redefined at ./FHEM/10_CUL_HM.pm line 465, <$fh> line 215.
Subroutine CUL_HM_Undef redefined at ./FHEM/10_CUL_HM.pm line 520, <$fh> line 215.
Subroutine CUL_HM_Rename redefined at ./FHEM/10_CUL_HM.pm line 539, <$fh> line 215.
Subroutine CUL_HM_Attr redefined at ./FHEM/10_CUL_HM.pm line 576, <$fh> line 215.
Subroutine CUL_HM_AttrCheck redefined at ./FHEM/10_CUL_HM.pm line 860, <$fh> line 215.
Subroutine CUL_HM_prtInit redefined at ./FHEM/10_CUL_HM.pm line 882, <$fh> line 215.
Subroutine CUL_HM_hmInitMsg redefined at ./FHEM/10_CUL_HM.pm line 887, <$fh> line 215.
Subroutine CUL_HM_hmInitMsgUpdt redefined at ./FHEM/10_CUL_HM.pm line 924, <$fh> line 215.
Subroutine CUL_HM_Notify redefined at ./FHEM/10_CUL_HM.pm line 951, <$fh> line 215.
Subroutine CUL_HM_setupHMLAN redefined at ./FHEM/10_CUL_HM.pm line 964, <$fh> line 215.
Subroutine CUL_HM_Parse redefined at ./FHEM/10_CUL_HM.pm line 1001, <$fh> line 215.
Subroutine CUL_HM_parseCommon redefined at ./FHEM/10_CUL_HM.pm line 2639, <$fh> line 215.
Subroutine CUL_HM_m_setCh redefined at ./FHEM/10_CUL_HM.pm line 3137, <$fh> line 215.
Subroutine CUL_HM_queueUpdtCfg redefined at ./FHEM/10_CUL_HM.pm line 3148, <$fh> line 215.
Subroutine CUL_HM_parseSDteam redefined at ./FHEM/10_CUL_HM.pm line 3166, <$fh> line 215.
Subroutine CUL_HM_updtSDTeam redefined at ./FHEM/10_CUL_HM.pm line 3224, <$fh> line 215.
Subroutine CUL_HM_pushEvnts redefined at ./FHEM/10_CUL_HM.pm line 3245, <$fh> line 215.
Subroutine CUL_HM_Get redefined at ./FHEM/10_CUL_HM.pm line 3272, <$fh> line 215.
Subroutine CUL_HM_Set redefined at ./FHEM/10_CUL_HM.pm line 3540, <$fh> line 215.
Subroutine CUL_HM_valvePosUpdt redefined at ./FHEM/10_CUL_HM.pm line 5259, <$fh> line 215.
Subroutine CUL_HM_valvePosTmr redefined at ./FHEM/10_CUL_HM.pm line 5326, <$fh> line 215.
Subroutine CUL_HM_weather redefined at ./FHEM/10_CUL_HM.pm line 5358, <$fh> line 215.
Subroutine CUL_HM_infoUpdtDevData redefined at ./FHEM/10_CUL_HM.pm line 5367, <$fh> line 215.
Subroutine CUL_HM_getConfig redefined at ./FHEM/10_CUL_HM.pm line 5417, <$fh> line 215.
Subroutine CUL_HM_calcDisWmSet redefined at ./FHEM/10_CUL_HM.pm line 5480, <$fh> line 215.
usw
Titel: Antw:Fehler nach Update vom 30.08.15 10_CUL_HM.pm
Beitrag von: ChiliApple am 30 August 2015, 15:03:29
bei mir das Selbe, es funkt das Meiste nicht mehr, musste für´s 1. Backup zurückspielen
Beitrag von: franky08 am 30 August 2015, 15:33:01
Da gibt es schon mindestens 4 Threads dazu:
z.B.
http://forum.fhem.de/index.php/topic,40531.0.html
Frank
