kann mir vielelicht jemand sagen was ich falsch mache? Eigendlich habe ich an dem Homematic Geräte heute gar nicht gearbeitet?!
Hier mal der restart start Log:
Smartmatch is experimental at ./FHEM/99_MyUtils.pm line 165.
Smartmatch is experimental at ./FHEM/99_MyUtils.pm line 168.
2015.09.09 14:04:42 1: Including fhem.cfg
2015.09.09 14:04:42 3: telnetPort: port 7072 opened
2015.09.09 14:04:42 3: tPortLocal: port 7073 opened
2015.09.09 14:04:43 3: WEB: port 8083 opened
2015.09.09 14:04:43 3: WEB_SET: port 8085 opened
2015.09.09 14:04:43 2: eventTypes: loaded 5093 events from /opt/fhem/log/eventTypes.txt
Useless use of \E at ./FHEM/74_AMAD.pm line 326, <$fh> line 70.
2015.09.09 14:04:43 3: AMAD (Display_Flur) - defined with host 192.168.178.42 on port 192.168.178.42 and interval 180 (sec)
2015.09.09 14:04:44 1: HMLAN_Parse: hmusb new condition disconnected
2015.09.09 14:04:44 3: Opening hmusb device 127.0.0.1:1234
2015.09.09 14:04:44 3: hmusb device opened
2015.09.09 14:04:44 1: HMLAN_Parse: hmusb new condition init
2015.09.09 14:04:54 3: OWTHERM: Device 05_Aquarium_T1 defined.
2015.09.09 14:04:54 3: Opening FHEMduino device /dev/fhemduino
2015.09.09 14:04:54 3: Setting FHEMduino serial parameters to 9600,8,N,1
2015.09.09 14:04:54 3: FHEMduino device opened
2015.09.09 14:04:57 3: FHEMduino: Possible commands: VifdhtRq
2015.09.09 14:04:57 3: Define: EG_wz_LI_Vitrine FHEMduino_PT2262 FF0F00FFFF 324 0F F0
2015.09.09 14:04:57 3: Define hascode: {FF0F00FFFF}{EG_wz_LI_Vitrine}
2015.09.09 14:04:57 3: Define: EG_wz_LI_Frau FHEMduino_PT2262 FF0F0F0FFF 324 0F F0
2015.09.09 14:04:57 3: Define hascode: {FF0F0F0FFF}{EG_wz_LI_Frau}
2015.09.09 14:04:57 3: Define: Display_FLUR_power FHEMduino_PT2262 FF0F0FFF0F 324 0F F0
2015.09.09 14:04:57 3: Define hascode: {FF0F0FFF0F}{Display_FLUR_power}
2015.09.09 14:04:57 3: Define: EG_ez_LI_Sideboard FHEMduino_PT2262 FF0F0FF0FF 323 0F F0
2015.09.09 14:04:57 3: Define hascode: {FF0F0FF0FF}{EG_ez_LI_Sideboard}
2015.09.09 14:04:57 3: wetter_aschau: Defined with URL http://api.wunderground.com/weatherstation/WXCurrentObXML.asp?ID=IBAYERNA15 and interval 600
given is experimental at ./FHEM/59_PROPLANTA.pm line 515, <$fh> line 768.
when is experimental at ./FHEM/59_PROPLANTA.pm line 517, <$fh> line 768.
when is experimental at ./FHEM/59_PROPLANTA.pm line 521, <$fh> line 768.
2015.09.09 14:05:01 3: Opening my_callmonitor device 192.168.178.1:1012
2015.09.09 14:05:01 3: my_callmonitor device opened
2015.09.09 14:05:01 3: FB_CALLMONITOR (my_callmonitor) - loading cache file /opt/fhem/callmoncache.txt
2015.09.09 14:05:01 2: FB_CALLMONITOR (my_callmonitor) - read 56 contacts from Cache
Subroutine hex2bin redefined at ./FHEM/14_FHEMduino_FA20RF.pm line 321, <$fh> line 1585.
2015.09.09 14:05:02 3: FHEM2FHEM opening FHEM_Keller at 192.168.178.45:7072
2015.09.09 14:05:02 3: FHEM2FHEM device opened (FHEM_Keller)
2015.09.09 14:05:02 1: Including /opt/fhem/log/fhem.save
2015.09.09 14:05:04 1: statefile: Undefined value 13264
2015.09.09 14:05:04 3: Device EG_TH added to ActionDetector with 012:00 time
2015.09.09 14:05:04 3: Device EG_ez_TK_mi added to ActionDetector with 028:00 time
2015.09.09 14:05:04 3: Device EG_fl_RT_tuer added to ActionDetector with 000:10 time
2015.09.09 14:05:04 3: Device EG_wc_FK_mi added to ActionDetector with 028:00 time
2015.09.09 14:05:04 3: Device EG_wz_RT_links added to ActionDetector with 000:10 time
2015.09.09 14:05:04 3: Device EG_wz_RT_rechts added to ActionDetector with 000:10 time
2015.09.09 14:05:04 3: Device EG_wz_TC added to ActionDetector with 000:10 time
2015.09.09 14:05:04 3: Device GT_ga_BM_gartenlicht added to ActionDetector with 000:10 time
2015.09.09 14:05:04 3: Device OC3 added to ActionDetector with 000:10 time
2015.09.09 14:05:04 3: Device OG_TH added to ActionDetector with 012:00 time
2015.09.09 14:05:04 3: Device OG_az_FK_dach added to ActionDetector with 028:00 time
2015.09.09 14:05:05 3: Device OG_bz_FK_dach added to ActionDetector with 028:00 time
2015.09.09 14:05:05 3: Device OG_bz_RT_links added to ActionDetector with 000:10 time
2015.09.09 14:05:05 3: Device OG_bz_RT_rechts added to ActionDetector with 000:10 time
2015.09.09 14:05:05 3: Device Waesche added to ActionDetector with 000:10 time
2015.09.09 14:05:05 3: Opening FIRMATA device /dev/firmata
2015.09.09 14:05:05 3: Setting FIRMATA serial parameters to 57600,8,N,1
2015.09.09 14:05:05 3: FIRMATA device opened
2015.09.09 14:05:07 3: querying Firmata Firmware Version
2015.09.09 14:05:08 3: querying Firmata Firmware Version
2015.09.09 14:05:08 3: Firmata Firmware Version: ConfigurableFirmata.ino V_2_06
2015.09.09 14:05:09 1: OWX: 1-Wire bus Temperatur: interface Firmata detected in FIRMATA
2015.09.09 14:05:09 1: usb create starting
2015.09.09 14:05:10 1: usb create end
2015.09.09 14:05:11 3: mailcheck: connected to w009a9dc.kasserver.com
2015.09.09 14:05:11 3: mailcheck: logged in to system@horenkamp.net
2015.09.09 14:05:13 2: Error messages while initializing FHEM: statefile: Undefined value 13264
2015.09.09 14:05:13 0: Featurelevel: 5.6
2015.09.09 14:05:13 0: Server started with 277 defined entities (version $Id: fhem.pl 9195 2015-09-03 07:23:40Z rudolfkoenig $, os linux, user fhem, pid 26564)
2015.09.09 14:05:13 3: CUL_HM set EG_ez_RO_mi_SW_01 statusRequest
2015.09.09 14:05:13 1: HMLAN_Parse: hmusb new condition Warning-HighLoad
2015.09.09 14:05:14 3: CUL_HM set EG_ez_RO_mi_SW_02 statusRequest
2015.09.09 14:05:15 1: HMLAN_Parse: hmusb new condition ok
2015.09.09 14:05:15 3: CUL_HM set EG_ez_RO_mi_HOCH statusRequest
2015.09.09 14:05:16 3: CUL_HM set EG_ez_RO_mi_RUNTER statusRequest
2015.09.09 14:05:17 3: CUL_HM set EG_ku_RO_mi_SW_01 statusRequest
2015.09.09 14:05:18 3: CUL_HM set EG_ku_RO_mi_SW_02 statusRequest
2015.09.09 14:05:19 1: OWX: 1-Wire devices found on bus Temperatur (05_Aquarium_T1)
2015.09.09 14:05:19 3: CUL_HM set EG_ku_RO_mi_RUNTER statusRequest
2015.09.09 14:05:20 3: CUL_HM set EG_ku_RO_mi_HOCH statusRequest
2015.09.09 14:05:21 3: CUL_HM set EG_wc_RO_mi_SW_01 statusRequest
2015.09.09 14:05:22 3: CUL_HM set EG_wc_RO_mi_SW_02 statusRequest
2015.09.09 14:05:23 3: CUL_HM set EG_wc_RO_mi_HOCH statusRequest
2015.09.09 14:05:24 3: CUL_HM set EG_wc_RO_mi_RUNTER statusRequest
2015.09.09 14:05:25 3: CUL_HM set EG_wz_RO_li_SW_01 statusRequest
2015.09.09 14:05:26 3: CUL_HM set EG_wz_RO_li_SW_02 statusRequest
2015.09.09 14:05:27 3: CUL_HM set EG_wz_RO_li_HOCH statusRequest
2015.09.09 14:05:28 3: CUL_HM set EG_wz_RO_li_RUNTER statusRequest
2015.09.09 14:05:29 3: CUL_HM set EG_wz_RO_re_SW_01 statusRequest
2015.09.09 14:05:30 3: CUL_HM set EG_wz_RO_re_SW_02 statusRequest
2015.09.09 14:05:31 3: CUL_HM set EG_wz_RO_re_HOCH statusRequest
2015.09.09 14:05:33 3: CUL_HM set EG_wz_RO_re_RUNTER statusRequest
2015.09.09 14:05:34 3: CUL_HM set OG_kz_RO_mi_SW_01 statusRequest
2015.09.09 14:05:35 3: CUL_HM set OG_kz_RO_mi_SW_02 statusRequest
2015.09.09 14:05:35 1: HMLAN_Parse: hmusb new condition Warning-HighLoad
2015.09.09 14:05:36 3: CUL_HM set OG_kz_RO_mi_RUNTER statusRequest
2015.09.09 14:05:37 3: CUL_HM set OG_kz_RO_mi_HOCH statusRequest
2015.09.09 14:05:38 3: CUL_HM set OG_sz_RO_mi_SW_01 statusRequest
2015.09.09 14:05:39 3: CUL_HM set OG_sz_RO_mi_SW_02 statusRequest
2015.09.09 14:05:40 3: CUL_HM set OG_sz_RO_mi_HOCH statusRequest
2015.09.09 14:05:41 3: CUL_HM set OG_sz_RO_mi_RUNTER statusRequest
2015.09.09 14:05:42 3: CUL_HM set Waesche_Sw statusRequest
2015.09.09 14:05:43 3: CUL_HM set Waesche_Pwr statusRequest
Zitatkann mir vielelicht jemand sagen was ich falsch mache?
was genau meinst du?
ZitatEigendlich habe ich an dem Homematic Geräte heute gar nicht gearbeitet?!
was meinst du wohl. was hier passiert?
2015.09.09 14:05:20 3: CUL_HM set EG_ku_RO_mi_HOCH statusRequestschau dir die load in hmlan internals an. oder hminfo msgstat oder protoevents.
frank hat eigentlich schon alles gesagt.
Aber die automatischen Statusrequests sollten nicht hierzu fuehren:
Fhem sollte bei batchLevel aufhoeren, neue Nachrichten zu senden.
Ich vermute eine alte Firmware auf dem HM-CFG-USB (< 0.967) und/oder einen alten hmland (<0.100). Am besten beides auf die aktuellen Versionen (0.967/0.101) aktualisieren.
Viele Gruesse
Michael
stimmt, die aktuelle load ist dann immer 0%. ;)
da müsste martin eigentlich eine warnmeldung einbauen. wenn condition highload oder overload und die aktuelle load=0% => "warning: io load error".
HM-CFG-USB = 0.967
hmland = 101
Also daran sollte es nicht liegen. Ich werde es mal weiter beobachten. Bis jetzt kein HighLoad mehr. Trotzdem verstehe ich das nicht. Ich habe das immer wieder mal...
Zitatschau dir die load in hmlan internals an. oder hminfo msgstat oder protoevents.
wo sind die infos?
Hallo Frank,
sorry irgendwie unter gegangen:
msg statistics
receive hour :| 00| 01| 02| 03| 04| 05| 06| 07| 08| 09| 10| 11| 12| 13| 14| 15| 16| 17| 18| 19| 20| 21| 22| 23
hmusb :|263|258|258|255|260|258|259|450|329|348| 0| 0| 0| 0|299|255|288|272|267|265|256|254|259|260
send hour :| 00| 01| 02| 03| 04| 05| 06| 07| 08| 09| 10| 11| 12| 13| 14| 15| 16| 17| 18| 19| 20| 21| 22| 23
hmusb :| 10| 10| 8| 8| 18| 6| 7|217| 85|184| 0| 0| 0| 0| 80| 14| 57| 22| 24| 23| 12| 6| 10| 8
receive day :| Mon| Tue| Wed| Thu| Fri| Sat| Sun|# tdy
hmusb :| 0| 0| 0|2675| 0| 0| 0|#5613
send day :| Mon| Tue| Wed| Thu| Fri| Sat| Sun|# tdy
hmusb :| 0| 0| 0| 256| 0| 0| 0|# 809
protoEvents done:
name :State |CmdPend |Snd |Resnd #CmdDel |ResndFail |Nack |IOerr
EG_TH : - | - | - | - # - | - | - | -
EG_ez_RO_mi : done | - |12: |1: #12 | - | - |4:
EG_ez_TK_mi : - | - | - | - # - | - | - | -
EG_fl_BM_display : done | - |22: | - # - | - | - | -
EG_fl_RT_tuer : - | - | - | - # - | - | - | -
EG_ku_RO_mi : done | - |11: | - #9 | - | - |3:
EG_wc_FK_mi : - | - | - | - # - | - | - | -
EG_wc_RO_mi : done | - |10: |1: #6 | - | - |2:
EG_wz_RO_li : done | - |9: |1: #3 | - | - |1:
EG_wz_RO_re : done | - |8: | - # - | - | - | -
EG_wz_RT_links : - | - | - | - # - | - | - | -
EG_wz_RT_rechts : - | - | - | - # - | - | - | -
EG_wz_TC : - | - | - | - # - | - | - | -
GT_ga_BM_gartenlicht : done | - |8: | - # - | - | - | -
GT_ga_RS_modul : - | - | - | - # - | - | - | -
OC3 : - | - | - | - # - | - | - | -
OG_TH : - | - | - | - # - | - | - | -
OG_az_FK_dach : - | - | - | - # - | - | - | -
OG_bz_FK_dach : - | - | - | - # - | - | - | -
OG_bz_RT_links : - | - | - | - # - | - | - | -
OG_bz_RT_rechts : - | - | - | - # - | - | - | -
OG_kz_RO_mi : done | - |8: | - # - | - | - | -
OG_sz_RO_mi : done | - |8: | - # - | - | - | -
Waesche : done | - |183: | - # - | - | - | -
vccu : - | - | - | - # - | - | - | -
sum 0 |0 |279 |3 #30 |0 |0 |10
CUL_HM queue length:0
requests pending
autoReadReg :
recent : none
status request :
autoReadReg wakeup : EG_ez_TK_mi EG_wc_FK_mi
status request wakeup:
autoReadTest :
IODevs:hmusb:opened pending=0 condition:ok
da siehst du doch sehr schön, dass an dein device "waesche" 183 msgs gesendet wurden (protoevents). die tabelle wird, glaube ich nach reset gelöscht. unter msgstat ist dieser wert quasi 1:1 (184) in der aktuellen stunde (09) bei hmusb send zu finden. zwischen 7 und 8 uhr sind auch verhältnismässig viele msgs in einer stunde gesendet worden (217).
ich vermute, du hast eine energiemesssteckdose, um das ende des waschens zu erkennen. heute bereits 2x gewaschen? du musst die steckdose anders einstellen, sodass weniger messwerte gesendet werden. fhem muss alle msgs beantworten.
ausserdem wartet fhem auf deine fensterkontakte (?).
die melden sich aber wahrscheinlich nicht von selbst. hminfo configcheck wird dir sagen was da los ist. wahrscheinlich mal getconfig machen und anschliessend sichern.
was ist mit der aktuellen load vom hmusb? poste ein list.
Ja auf den Fesnterkontakt wird gewartet. Den muss ich noch betätigen.
2x Gewaschen, das kann hinkommen meine Frau ist heute zuhause ;D
Wie muss ich den anderes einstellen?!
Hier der List vom hmusb, ich denke den willst du haben?!
DEF 127.0.0.1:1234
DeviceName 127.0.0.1:1234
FD 14
IFmodel USB
NAME hmusb
NR 77
NTFY_ORDER 50-hmusb
PARTIAL
RAWMSG E3BB343,0000,316293E0,FF,FFC9,80A45F3BB3432516B781DBDA0001B3003A092701
RSSI -55
STATE opened
TYPE HMLAN
XmitOpen 1
assignedIDsCnt 24
hmusb_MSGCNT 1072
hmusb_TIME 2015-09-10 10:09:59
msgKeepAlive dlyMax:37.144 bufferMin:-32
msgLoadCurrent 17
msgLoadHistory 5min steps: 2/1/1/-1/-1/0/-1/-1/-17/1/0/0
owner 2516B7
owner_CCU vccu
uptime 009 230:09:03.968
Readings:
2015-09-10 07:35:28 D-HMIdAssigned 2516B7
2015-09-10 07:35:28 D-HMIdOriginal 1EBE46
2015-09-10 07:35:28 D-firmware 0.967
2015-09-10 07:35:28 D-serialNr JEQ0701139
2015-09-10 08:25:14 Xmit-Events ok:1 init:1 ERROR-Overload:10 Warning-HighLoad:10 disconnected:1
2015-09-10 08:25:14 cond ok
2015-08-30 12:12:11 hmTrfHour %
2015-09-10 10:09:50 loadLvl low
2015-09-10 08:20:16 prot_ERROR-Overload last
2015-09-10 08:20:13 prot_Warning-HighLoad last
2015-09-10 07:35:12 prot_disconnected last
2015-09-10 07:35:12 prot_init last
2015-07-26 22:05:28 prot_keepAlive last
2015-09-10 08:25:14 prot_ok last
2015-07-29 12:57:51 prot_timeout last
2015-09-10 08:25:14 state opened
Helper:
assIdCnt 24
assIdRep 24
info 03C7,JEQ0701139,1EBE46,2516B7
setTime 44002
Cnd:
0 1
2 10
253 1
255 1
4 10
Ids:
23fc63:
name GT_ga_RS_modul
268f15:
name EG_wc_FK_mi
276a71:
name OG_bz_FK_dach
276e61:
name OG_az_FK_dach
278cfc:
chn 01
flg 0
msg
name EG_fl_BM_display
to 1441869543.36961
28a1de:
chn 04
flg 0
msg
name OG_sz_RO_mi
to 1441866336.37863
28a1ea:
chn 04
flg 0
msg
name EG_wz_RO_re
to 1441866327.84011
28a275:
chn 04
flg 0
msg
name OG_kz_RO_mi
to 1441866331.95403
28a281:
chn 02
flg 0
msg
name EG_wz_RO_li
to 1441866923.03467
28a47c:
chn 04
flg 0
msg
name EG_ez_RO_mi
to 1441867524.27525
28a511:
chn 02
flg 0
msg
name EG_ku_RO_mi
to 1441867823.37978
28a51a:
chn 04
flg 0
msg
name EG_wc_RO_mi
to 1441866622.91884
2d1ec4:
name EG_ez_TK_mi
34283e:
chn 01
flg 0
msg
name GT_ga_BM_gartenlicht
to 1441869052.8708
3541bf:
name EG_fl_RT_tuer
354a30:
name EG_wz_RT_rechts
354a31:
name OG_bz_RT_links
354a33:
name OG_bz_RT_rechts
354a37:
name EG_wz_RT_links
3745fe:
name OG_TH
374600:
name EG_TH
3746f1:
name OC3
388b09:
name EG_wz_TC
3bb343:
chn 01
flg 0
msg
name Waesche
to 1441866337.40793
K:
BufMin -32
DlyMax 37.144
Next 1441872615.17166
Start 1441872590.17166
Loadlvl:
bl 40
a:
99
90
40
0
H:
0 low
40 batchLevel
90 high
99 suspended
Log:
all 0
sys 0
ids:
ARRAY(0x2d1e498)
Q:
HMcndN 0
answerPend 0
hmLanQlen 1
keepAliveRec 1
keepAliveRpt 0
loadLast 16
loadNo 1
scnt 5
apIDs:
Ref:
hmtL 828534827
kTs 0
hmId 2516B7
hmLanQlen 1_min
loadLevel 0:low,40:batchLevel,90:high,99:suspended
wdTimer 25
oh ha... , seit dem letzten restart bereits 10x overload. der letzte 08:20. da war die wäsche wohl fertig.
2015-08-30 12:12:11 hmTrfHour % du hast wohl ein at für die msgloadest definiert. das solltest du mal auf die aktuellen verhältnisse (msgLoadCurrent) anpassen. ;)
msgLoadCurrent 17
msgLoadHistory 5min steps: 2/1/1/-1/-1/0/-1/-1/-17/1/0/0ZitatWie muss ich den anderes einstellen?!
poste alle lists der steckdose und sage was deine kriterien zur erkennung sind.
Die Hutschinenmessung habe ich noch nicht lange. Ich habe auf die schnelle für meine Frau den Codeschnipsel genommen.
http://forum.fhem.de/index.php/topic,39498.0.html
Funktioniert auch gut.
*edit*
ich habe mich an dem Plot versucht:
http://www.fhemwiki.de/wiki/HM-CFG-LAN:_%C3%9Cberwachung_der_1%25-Regel
Aber auch mit der Änderung msgLoadCurrent funktiniert es irgendwie nicht...
DEF 3BB343
IODev hmusb
LASTInputDev hmusb
MSGCNT 5
NAME Waesche
NR 617
NTFY_ORDER 50-Waesche
STATE CMDs_done
TYPE CUL_HM
channel_01 Waesche_Sw
channel_02 Waesche_Pwr
channel_03 Waesche_SenPwr
channel_04 Waesche_SenI
channel_05 Waesche_SenU
channel_06 Waesche_SenF
hmusb_MSGCNT 5
hmusb_RAWMSG E3BB343,0000,317A78E3,FF,FFC7,5C845E3BB34300000081DD9E0000A400350905FE
hmusb_RSSI -57
hmusb_TIME 2015-09-10 10:36:05
lastMsg No:5C - t:5E s:3BB343 d:000000 81DD9E0000A400350905FE
protLastRcv 2015-09-10 10:36:05
protSnd 4 last_at:2015-09-10 10:35:02
protState CMDs_done
rssi_at_hmusb min:-57 max:-56 avg:-56.6 lst:-57 cnt:5
rssi_hmusb avg:-59 max:-59 min:-59 cnt:1 lst:-59
Readings:
2015-09-10 10:34:24 Activity alive
2015-08-29 19:47:10 CommandAccepted yes
2015-08-28 10:25:20 D-firmware 2.5
2015-08-28 10:25:20 D-serialNr MEQ0421050
2015-08-29 09:06:34 PairedTo 0x2516B7
2015-08-28 13:35:41 R-intKeyVisib visib
2015-08-28 10:25:25 R-localResDis off
2015-08-28 10:25:25 R-pairCentral 0x2516B7
2015-08-29 09:06:34 RegL_00: 02:81 0A:25 0B:16 0C:B7 15:FF 18:00 00:00
2015-09-10 10:35:02 state CMDs_done
Helper:
HM_CMDNR 92
cSnd 012516B73BB343010E,012516B73BB343020E
mId 00EA
rxType 1
Io:
newChn +3BB343,00,00,00
nextSend 1441874165.42588
rxt 0
vccu vccu
p:
3BB343
00
00
00
prefIO:
hmusb
Mrssi:
mNo 5C
Io:
hmusb -55
Prt:
bErr 0
sProc 0
Rspwait:
Q:
qReqConf
qReqStat
Role:
dev 1
Rssi:
At_hmusb:
avg -56.6
cnt 5
lst -57
max -56
min -57
Hmusb:
avg -59
cnt 1
lst -59
max -59
min -59
IODev hmusb
IOgrp vccu:hmusb
actCycle 000:10
actStatus alive
autoReadReg 4_reqStatus
expert 2_full
firmware 2.5
model HM-ES-PMSw1-DR
room CUL_HM
serialNr MEQ0421050
subType powerMeter
webCmd getConfig:clear msgEvents
DEF 3BB34301
NAME Waesche_Sw
NR 619
NTFY_ORDER 50-Waesche_Sw
STATE on
TYPE CUL_HM
chanNo 01
device Waesche
peerList self01,self05,
Readings:
2015-08-29 19:41:43 R-powerUpAction off
2015-08-28 13:35:50 R-self01-lgActionType jmpToTarget
2015-08-28 13:35:50 R-self01-lgCtDlyOff geLo
2015-08-28 13:35:50 R-self01-lgCtDlyOn geLo
2015-08-28 13:35:50 R-self01-lgCtOff geLo
2015-08-28 13:35:50 R-self01-lgCtOn geLo
2015-08-28 13:35:50 R-self01-lgCtValHi 100
2015-08-28 13:35:50 R-self01-lgCtValLo 50
2015-08-28 13:35:50 R-self01-lgMultiExec on
2015-08-28 13:35:50 R-self01-lgOffDly 0 s
2015-08-28 13:35:50 R-self01-lgOffTime unused
2015-08-28 13:35:50 R-self01-lgOffTimeMode absolut
2015-08-28 13:35:50 R-self01-lgOnDly 0 s
2015-08-28 13:35:50 R-self01-lgOnTime unused
2015-08-28 13:35:50 R-self01-lgOnTimeMode absolut
2015-08-29 19:41:45 R-self01-lgSwJtDlyOff on
2015-08-29 19:41:45 R-self01-lgSwJtDlyOn on
2015-08-29 19:43:29 R-self01-lgSwJtOff dlyOn
2015-08-29 19:43:29 R-self01-lgSwJtOn on
2015-08-28 13:35:50 R-self01-shActionType jmpToTarget
2015-08-28 13:35:50 R-self01-shCtDlyOff geLo
2015-08-28 13:35:50 R-self01-shCtDlyOn geLo
2015-08-28 13:35:50 R-self01-shCtOff geLo
2015-08-28 13:35:50 R-self01-shCtOn geLo
2015-08-28 13:35:50 R-self01-shCtValHi 100
2015-08-28 13:35:50 R-self01-shCtValLo 50
2015-08-28 13:35:50 R-self01-shOffDly 0 s
2015-08-28 13:35:50 R-self01-shOffTime unused
2015-08-28 13:35:50 R-self01-shOffTimeMode absolut
2015-08-28 13:35:50 R-self01-shOnDly 0 s
2015-08-28 13:35:50 R-self01-shOnTime unused
2015-08-28 13:35:50 R-self01-shOnTimeMode absolut
2015-08-29 19:43:46 R-self01-shSwJtDlyOff on
2015-08-29 19:43:46 R-self01-shSwJtDlyOn on
2015-08-29 19:44:00 R-self01-shSwJtOff dlyOn
2015-08-29 19:44:00 R-self01-shSwJtOn on
2015-08-29 19:41:46 R-self05-lgActionType jmpToTarget
2015-08-29 19:41:46 R-self05-lgCtDlyOff geLo
2015-08-29 19:41:46 R-self05-lgCtDlyOn geLo
2015-08-29 19:41:46 R-self05-lgCtOff geLo
2015-08-29 19:41:46 R-self05-lgCtOn geLo
2015-08-29 19:41:46 R-self05-lgCtValHi 100
2015-08-29 19:41:46 R-self05-lgCtValLo 50
2015-08-29 19:41:46 R-self05-lgMultiExec on
2015-08-29 19:41:46 R-self05-lgOffDly 0 s
2015-08-29 19:41:46 R-self05-lgOffTime unused
2015-08-29 19:41:46 R-self05-lgOffTimeMode absolut
2015-08-29 19:41:46 R-self05-lgOnDly 0 s
2015-08-29 19:41:46 R-self05-lgOnTime unused
2015-08-29 19:41:46 R-self05-lgOnTimeMode absolut
2015-08-29 19:44:17 R-self05-lgSwJtDlyOff on
2015-08-29 19:44:17 R-self05-lgSwJtDlyOn on
2015-08-29 19:44:33 R-self05-lgSwJtOff dlyOn
2015-08-29 19:44:33 R-self05-lgSwJtOn on
2015-08-29 19:41:46 R-self05-shActionType jmpToTarget
2015-08-29 19:41:46 R-self05-shCtDlyOff geLo
2015-08-29 19:41:46 R-self05-shCtDlyOn geLo
2015-08-29 19:41:46 R-self05-shCtOff geLo
2015-08-29 19:41:46 R-self05-shCtOn geLo
2015-08-29 19:41:46 R-self05-shCtValHi 100
2015-08-29 19:41:46 R-self05-shCtValLo 50
2015-08-29 19:41:46 R-self05-shOffDly 0 s
2015-08-29 19:41:46 R-self05-shOffTime unused
2015-08-29 19:41:46 R-self05-shOffTimeMode absolut
2015-08-29 19:41:46 R-self05-shOnDly 0 s
2015-08-29 19:41:46 R-self05-shOnTime unused
2015-08-29 19:41:46 R-self05-shOnTimeMode absolut
2015-08-29 19:44:47 R-self05-shSwJtDlyOff on
2015-08-29 19:44:47 R-self05-shSwJtDlyOn on
2015-08-29 19:45:12 R-self05-shSwJtOff dlyOn
2015-08-29 19:45:12 R-self05-shSwJtOn on
2015-08-29 08:36:37 R-sign off
2015-08-29 08:36:37 R-statusInfoMinDly 2 s
2015-08-29 08:36:37 R-statusInfoRandom 1 s
2015-08-29 08:36:37 R-transmitTryMax 6
2015-08-29 19:45:10 RegL_01: 08:00 30:06 56:00 57:24 93:20 94:45 00:00
2015-08-29 19:45:11 RegL_03:self01 02:00 03:00 04:32 05:64 06:00 07:FF 08:00 09:FF 0A:01 0B:13 0C:33 82:00 83:00 84:32 85:64 86:00 87:FF 88:00 89:FF 8A:21 8B:13 8C:33 00:00
2015-08-29 19:45:12 RegL_03:self05 02:00 03:00 04:32 05:64 06:00 07:FF 08:00 09:FF 0A:01 0B:13 0C:33 82:00 83:00 84:32 85:64 86:00 87:FF 88:00 89:FF 8A:21 8B:13 8C:33 00:00
2015-09-10 10:35:01 deviceMsg on (to vccu)
2015-09-10 10:35:01 level 100
2015-09-10 10:35:01 pct 100
2015-09-10 10:34:24 peerList self01,self05,
2015-09-10 10:35:01 recentStateType info
2015-09-10 10:35:01 state on
2015-09-10 10:35:01 timedOn off
Helper:
Role:
chn 1
prs 1
peerIDs 00000000,3BB34301,3BB34305,
DEF 3BB34302
NAME Waesche_Pwr
NR 620
NTFY_ORDER 50-Waesche_Pwr
STATE 12227
TYPE CUL_HM
chanNo 02
device Waesche
Readings:
2015-08-28 10:25:26 R-averaging 1 s
2015-08-28 10:25:26 R-sign off
2015-08-28 10:25:26 R-txMinDly 8 s
2015-08-28 10:25:26 R-txThrCur 100 mA
2015-08-28 10:25:26 R-txThrFrq 1 Hz
2015-08-28 10:25:26 R-txThrPwr 100 W
2015-08-28 10:25:26 R-txThrVlt 10 V
2015-08-29 09:06:36 RegL_01: 08:00 7A:01 7B:08 7C:00 7D:27 7E:10 7F:00 80:64 81:00 82:64 83:64 00:00
2015-09-10 10:36:05 boot off
2015-09-10 10:36:05 current 53
2015-09-10 10:36:05 eState E: 12227 P: 1.64 I: 53 U: 230.9 f: 49.98
2015-09-10 10:36:05 energy 12227
2015-09-10 10:36:05 energyCalc 13688
2015-08-31 20:05:46 energyOffset 1461
2015-09-10 10:36:05 frequency 49.98
2015-09-10 10:36:05 power 1.64
2015-09-10 10:36:05 state 12227
2015-09-10 10:36:05 voltage 230.9
Helper:
Role:
chn 1
DEF 3BB34303
NAME Waesche_SenPwr
NR 621
NTFY_ORDER 50-Waesche_SenPwr
STATE 1.64
TYPE CUL_HM
chanNo 03
device Waesche
Readings:
2015-08-28 10:25:27 R-cndTxCycAbove off
2015-08-28 10:25:27 R-cndTxCycBelow off
2015-08-28 10:25:27 R-cndTxDecAbove 200
2015-08-28 10:25:27 R-cndTxDecBelow 0
2015-08-28 10:25:27 R-cndTxFalling off
2015-08-28 10:25:27 R-cndTxRising off
2015-08-28 10:25:27 R-ledOnTime 0.5 s
2015-08-28 10:25:27 R-sign off
2015-08-28 10:25:27 R-transmitTryMax 6
2015-08-28 10:25:27 R-txThrHiPwr 200 W
2015-08-28 10:25:27 R-txThrLoPwr 100 W
2015-08-29 09:06:37 RegL_01: 08:00 22:64 30:06 84:00 85:C8 86:00 87:00 88:00 89:4E 8A:20 8B:00 8C:00 8D:27 8E:10 00:00
2015-09-10 10:38:05 state 1.64
Helper:
Role:
chn 1
peerIDs 00000000,
DEF 3BB34304
NAME Waesche_SenI
NR 622
NTFY_ORDER 50-Waesche_SenI
STATE 53
TYPE CUL_HM
chanNo 04
device Waesche
Readings:
2015-08-28 10:25:29 R-cndTxCycAbove off
2015-08-28 10:25:29 R-cndTxCycBelow off
2015-08-28 10:25:29 R-cndTxDecAbove 200
2015-08-28 10:25:29 R-cndTxDecBelow 0
2015-08-28 10:25:29 R-cndTxFalling off
2015-08-28 10:25:29 R-cndTxRising off
2015-08-28 10:25:29 R-ledOnTime 0.5 s
2015-08-28 10:25:29 R-sign off
2015-08-28 10:25:29 R-transmitTryMax 6
2015-08-28 10:25:29 R-txThrHiCur 2000 mA
2015-08-28 10:25:29 R-txThrLoCur 1000 mA
2015-08-29 09:06:38 RegL_01: 08:00 22:64 30:06 84:00 85:C8 86:00 87:00 88:00 89:07 8A:D0 8B:00 8C:00 8D:03 8E:E8 00:00
2015-09-10 10:38:05 state 53
Helper:
Role:
chn 1
peerIDs 00000000,
DEF 3BB34305
NAME Waesche_SenU
NR 623
NTFY_ORDER 50-Waesche_SenU
STATE 231.4
TYPE CUL_HM
chanNo 05
device Waesche
Readings:
2015-08-29 19:45:49 R-cndTxCycAbove off
2015-08-29 19:45:49 R-cndTxCycBelow off
2015-08-28 10:25:30 R-cndTxDecAbove 200
2015-08-28 10:25:30 R-cndTxDecBelow 0
2015-08-29 19:45:49 R-cndTxFalling off
2015-08-29 19:45:49 R-cndTxRising on
2015-08-28 10:25:30 R-ledOnTime 0.5 s
2015-08-28 10:25:30 R-sign off
2015-08-28 10:25:30 R-transmitTryMax 6
2015-08-29 19:46:24 R-txThrHiVlt 200 V
2015-08-29 19:47:14 R-txThrLoVlt 180 V
2015-08-29 19:47:14 RegL_01: 08:00 22:64 30:06 84:02 85:C8 86:00 87:00 88:00 89:07 8A:D0 8B:00 8C:00 8D:07 8E:08 00:00
2015-09-10 10:38:05 state 231.4
Helper:
Role:
chn 1
peerIDs 00000000,
DEF 3BB34306
NAME Waesche_SenF
NR 624
NTFY_ORDER 50-Waesche_SenF
STATE 49.99
TYPE CUL_HM
chanNo 06
device Waesche
Readings:
2015-08-28 10:25:32 R-cndTxCycAbove off
2015-08-28 10:25:32 R-cndTxCycBelow off
2015-08-28 10:25:32 R-cndTxDecAbove 200
2015-08-28 10:25:32 R-cndTxDecBelow 0
2015-08-28 10:25:32 R-cndTxFalling off
2015-08-28 10:25:32 R-cndTxRising off
2015-08-28 10:25:32 R-ledOnTime 0.5 s
2015-08-28 10:25:32 R-sign off
2015-08-28 10:25:32 R-transmitTryMax 6
2015-08-28 10:25:32 R-txThrHiFrq 50.2 Hz
2015-08-28 10:25:32 R-txThrLoFrq 49.8 Hz
2015-08-29 09:06:41 RegL_01: 08:00 22:64 30:06 84:00 85:C8 86:00 87:00 88:00 89:13 8A:9C 8B:00 8C:00 8D:13 8E:74 00:00
2015-09-10 10:38:05 state 49.99
Helper:
Role:
chn 1
peerIDs 00000000,
ich wollte die daten wissen, die für deine waschmaschine nötig sind. nutzt du leistung oder strom? welche schwellwerte nutzt du für fertig und waschen etc...
wenn dich nur die leistung interessiert, setze auf jedenfall erstmal diese register in chn2:
txThrCur => unused
txThrFrq => unused
txThrVlt => unused
Na gut das werde ich jetzt mal machen. Aber das ist doch nicht die Lösung. Ich habe das ding um auch die Spannung den Strom und die Frequens zu wissen.
Da muss es doch noch eine andere Lösung für geben?
ZitatAber das ist doch nicht die Lösung. Ich habe das ding um auch die Spannung den Strom und die Frequens zu wissen.
das bedeutet doch nicht, dass du keine messwerte mehr bekommst! setze dich mal mit den möglichkeiten deiner steckdose auseinander, anstatt solche kommentare zu äussern.
du bekommst sogar noch messwerte, wenn auch noch txThrPwr=unused gesetzt ist. sogar von allen 5 messgrössen. in diesem fall dann aber nur alle 2-3 min. das ist dann die grösst mögliche reduzierung. mit
txThrPwr 100 Werhälst du
zusätzlich, zu den sowieso schon alle 2-3 min gesendeten daten, messdaten, sobald sich pwr um 100w geändert hat. und jeder datensatz der gesendet wird enthält immer alle 5 messgrössen.
ZitatDa muss es doch noch eine andere Lösung für geben?
nicht so oft waschen. :)
ah, jetzt habe ich das verstanden. Danke dir Frank
Jetzt schauen wir mal ob es besser wird.
