ich verwende folgende Routine:
sub
Abfalltermine ($)
my ($Ereignis) = @_;
my @Ereignisarray = split(/.*:\s/,$Ereignis);
my $Ereignisteil1 = $Ereignisarray[1];
my @uids=split(/;/,$Ereignisteil1);
my $t = time;
my $dtPapier = '';
my $dtGelberSack = '';
my $dtRest = '';
my $dtBio = '';
my $dtBeda = '';
foreach my $uid (@uids) {
my $Kalendertext = fhem("get Abfall summary $uid");
if ($Kalendertext =~ /Papiertonne/) {
my $dt = fhem("get Abfall start $uid");
my @SplitDt = split(/ /,$dt);
my @SplitDate = split(/\./,$SplitDt[0]);
my $eventDate = timelocal(0,0,0,$SplitDate[0],$SplitDate[1]-1,$SplitDate[2]);
if ($dtPapier eq '' || ($eventDate < $dtPapier && $eventDate > $t))
$dtPapier = $eventDate;
Log(3, $dtPapier);
if ($Kalendertext =~ /Gelber Sack/) {
if ($dtGelberSack eq '' || ($eventDate < $dtGelberSack && $eventDate > $t))
$dtGelberSack = $eventDate;
if ($Kalendertext =~ /Restmüll/) {
if ($dtRest eq '' || ($eventDate < $dtRest && $eventDate > $t))
$dtRest = $eventDate;
if ($Kalendertext =~ /Bio/) {
if ($dtBio eq '' || ($eventDate < $dtBio && $eventDate > $t))
$dtBio = $eventDate;
if ($Kalendertext =~ /Pater Beda/) {
if ($dtBeda eq '' || ($eventDate < $dtBeda && $eventDate > $t))
$dtBeda = $eventDate;
my $dayDiff = floor(($dtPapier - $t) / 60 / 60 / 24 + 1);
if ($dayDiff >= 0) {
fhem("set Papiertonne $dayDiff");
my $dayDiff = floor(($dtGelberSack - $t) / 60 / 60 / 24 + 1);
fhem("set GelberSack $dayDiff");
my $dayDiff = floor(($dtRest - $t) / 60 / 60 / 24 + 1);
fhem("set Restmuell $dayDiff");
my $dayDiff = floor(($dtBio - $t) / 60 / 60 / 24 + 1);
fhem("set Bio $dayDiff");
my $dayDiff = floor(($dtBeda - $t) / 60 / 60 / 24 + 1);
fhem("set Pater_Beda $dayDiff");
Im Log kommt folgende Fehlermeldung:
"my" variable $dayDiff masks earlier declaration in same scope at ./FHEM/99_MyUtils.pm line 86.
"my" variable $dayDiff masks earlier declaration in same scope at ./FHEM/99_MyUtils.pm line 90.
"my" variable $dayDiff masks earlier declaration in same scope at ./FHEM/99_MyUtils.pm line 94.
"my" variable $dayDiff masks earlier declaration in same scope at ./FHEM/99_MyUtils.pm line 98.
2015.09.20 11:06:56 1: Including fhem.cfg
Subroutine myUtils_Initialize redefined at ./FHEM/99_MyUtils.pm line 10, <$fh> line 8.
"my" variable $dayDiff masks earlier declaration in same scope at ./FHEM/99_MyUtils.pm line 86, <$fh> line 8.
"my" variable $dayDiff masks earlier declaration in same scope at ./FHEM/99_MyUtils.pm line 90, <$fh> line 8.
"my" variable $dayDiff masks earlier declaration in same scope at ./FHEM/99_MyUtils.pm line 94, <$fh> line 8.
"my" variable $dayDiff masks earlier declaration in same scope at ./FHEM/99_MyUtils.pm line 98, <$fh> line 8.
Es scheint zwar nur eine Warnung zu sein, denn alles wird richtige verarbeitet. Leider komme ich mit Perl immer noch nicht so klar, dass ich dei Meldung unterdrücken kann.
Wie kann ich hier Abhilfe schaffen.
Danke für Eure Hilfe
Es genügt eine Variable einmal mittels my... zu definieren. Da du dayDiff aber 5 mal definierst, bekommst du auch dafür 4 Warnungen. Passieren tut ja nix, da du dayDiff sofort nach der (neu)Deklaration verwendest und somit auf die ursprünglichen Werte nicht mehr angewiesen bist...
Lass einfach bei den übrigen Berechnungen das my am Anfang weg, oder lege dayDiff gleich oben als Variable an, so wie es die anderen ja auch sind.
Cheers,
budy
Habe ich ja jetzt gemacht:
sub
Abfalltermine ($)
my $t = time;
my $dtPapier = '';
my $dtRest = '';
my $dtBio = '';
my $dayDiff = 0;
my $dtBeda = '';
Log(3, $dtPapier);
Stimmt das jezt so ?
Sollte so sein.
