Hi.
I'm using MAX values, a MAX cube and heating profile for my temperature settings. It generally works well but I sometimes find that a valve has a desired temperature which is different to the heating_control setting. I can't understand why. This is what I do:
define HeatMaster Heating_Control MasterWallTemp en 12345|04:00|19.5 12345|07:00|16 12345|19:00|19.5 12345|22:00|16 67|07:00|19.5 67|09:30|16 67|16:00|19.5 67|23:00|16
define HeatStudy Heating_Control StudyWallTemp en 12345|15:30|19 12345|22:30|12 25|09:00|18 67|09:00|19 67|11:00|16 67|15:00|19 67|22:00|12
define HeatPlayroom Heating_Control Playroom en 12345|15:00|15 12345|18:00|12 67|12:00|19 67|20:00|12
Can anyone help?
Thanks
Homer
Hi Homer,
are you using only the manual mode of the valves ?
If you are using the auto mode, be aware that the valve internal week-profile is also active.
John
Hi John,
Thanks for the suggestion. All of my valves are set to manual. However, I do wonder if something like their internal settings is causing a problem. I've changed all valves to now be 17degrees 24 hours a day. It'll keep checking to see if 17 every gets set as the desired temperature. My FHEM profile doesn't ever have this value.
Thanks
Homer
Hi Homer,
what about the quality of transmission.
Take a look to the RSSI-Value of the valves.
John
