FHEM - Entwicklung => FHEM Code changes => Thema gestartet von: System am 09 November 2015, 15:00:01
Titel: 98_GAEBUS.pm : add support if ebusd returns a list of semicolon separated values. now several readings can be defined to hold the values
Beitrag von: System am 09 November 2015, 15:00:01
98_GAEBUS.pm : add support if ebusd returns a list of semicolon separated values. now several readings can be defined to hold the valuesView Changes
Source: 98_GAEBUS.pm : add support if ebusd returns a list of semicolon separated values. now several readings can be defined to hold the values (http://sourceforge.net/p/fhem/code/9836/)
