FHEM - Entwicklung => FHEM Code changes => Thema gestartet von: System am 04 Dezember 2015, 18:00:04
Titel: 93_PWMR.pm : new reading desired-temp-used (desired-temp used in calculation e.g. when window is set to state open)
Beitrag von: System am 04 Dezember 2015, 18:00:04
93_PWMR.pm : new reading desired-temp-used (desired-temp used in calculation e.g. when window is set to state open)                           modification of definition in web gui will now also consider parameters changed by attributesView Changes
Source: 93_PWMR.pm : new reading desired-temp-used (desired-temp used in calculation e.g. when window is set to state open) (http://sourceforge.net/p/fhem/code/10082/)
