FHEM - Hausautomations-Systeme => MAX => Thema gestartet von: masterpete23 am 12 Dezember 2015, 17:17:31
Titel: cul_max aculfw maxcube
Beitrag von: masterpete23 am 12 Dezember 2015, 17:17:31
habe meinen maxcube zum cun mit aculfw gemacht
nun kam beim pairen
2015.12.12 17:06:27 2: autocreate: define MAX_027419 MAX HeatingThermostat 027419
2015.12.12 17:06:27 2: autocreate: define FileLog_MAX_027419 FileLog ./log/MAX_027419-%Y.log MAX_027419
2015.12.12 17:06:28 2: autocreate: define MAX_07b0cf MAX HeatingThermostat 07b0cf
2015.12.12 17:06:28 2: autocreate: define FileLog_MAX_07b0cf FileLog ./log/MAX_07b0cf-%Y.log MAX_07b0cf
2015.12.12 17:09:54 1: PERL WARNING: Use of uninitialized value $f1 in addition (+) at ./FHEM/14_CUL_MAX.pm line 321.
2015.12.12 17:09:54 1: PERL WARNING: Use of uninitialized value $f3 in bitwise and (&) at ./FHEM/14_CUL_MAX.pm line 323.
2015.12.12 17:09:54 1: PERL WARNING: Use of uninitialized value $f4 in bitwise and (&) at ./FHEM/14_CUL_MAX.pm line 324.
2015.12.12 17:09:54 1: PERL WARNING: Use of uninitialized value $f5 in bitwise and (&) at ./FHEM/14_CUL_MAX.pm line 325.
2015.12.12 17:09:54 1: PERL WARNING: Use of uninitialized value $f4 in right bitshift (>>) at ./FHEM/14_CUL_MAX.pm line 326.
2015.12.12 17:09:54 1: PERL WARNING: Use of uninitialized value $f5 in right bitshift (>>) at ./FHEM/14_CUL_MAX.pm line 326.
2015.12.12 17:09:54 1: PERL WARNING: Use of uninitialized value $f3 in right bitshift (>>) at ./FHEM/14_CUL_MAX.pm line 327.
2015.12.12 17:09:54 1: PERL WARNING: Use of uninitialized value $f4 in right bitshift (>>) at ./FHEM/14_CUL_MAX.pm line 328.
2015.12.12 17:09:54 1: PERL WARNING: Use of uninitialized value $f5 in right bitshift (>>) at ./FHEM/14_CUL_MAX.pm line 329.
2015.12.12 17:09:54 1: PERL WARNING: Use of uninitialized value $day in concatenation (.) or string at ./FHEM/14_CUL_MAX.pm line 331.
Muss mich das stören?
# $Id: 14_CUL_MAX.pm 9233 2015-09-11 21:43:59Z mgehre $
Titel: Antw:cul_max aculfw maxcube
Beitrag von: masterpete23 am 12 Dezember 2015, 23:01:51
Niemand eine Idee? Bestimmt alle im Weihnachtsstress
Gesendet von meinem Huawei Honor 7
Beitrag von: Matthias Gehre am 13 Dezember 2015, 23:16:45
Da kam anscheinend ein TimeInformation Paket ohne Payload, aber die werden eh ignoriert. Ist also kein Problem.
Beitrag von: masterpete23 am 14 Dezember 2015, 07:31:16
ok.
Habe das Pairen hinbekommen.
Habe es vorher komplett resetten müssen.
Irgendwie habe ich das Gefühl das readings fehlen - kann ich die anfordern?
Beitrag von: Matthias Gehre am 15 Dezember 2015, 18:04:14
Das kann die MAX Hardware nicht. Kannst nur neue (bzw. die alte nochmal) Konfiguration setzten.
Beitrag von: masterpete23 am 15 Dezember 2015, 18:27:48
Also einfach attr oder mit set?
