... habe begonnen ein SQL Script zu schreiben ... Das Ergebnis wird dann hier gepostet
bin fertig!
das ganze besteht aus 3 Files:
File 1: "./calc_statistics_for_1_month.postgres.sql" - Berechnet für 1 Monat
\i 'calc_statistics_functions.postgres.sql'
\set VERBOSITY terse
begin work;
SELECT updateStat1Month('2015-12-01 00:00:00 CET');
commit work;File 2: "./calc_statistics_for_1_day.postgres.sql" - Berechnet für 1 Tag
begin work;
SELECT updateStat1day('2015-11-20 00:00:00 CET');
commit work;File 3: "./calc_statistics_functions.postgres.sql" - Kernfunktionalität der Berechnung
CREATE OR REPLACE FUNCTION updateStat1day(timestamp with time zone) RETURNS void AS
$BODY$
DECLARE
startTimestamp timestamp;
endTimestamp timestamp;
r history%rowtype;
countDelete integer;
countInsert integer;
BEGIN
-- Startzeitpunkt ist immer Mitternacht - Endzeitpunkt Mitternacht am nächsten Tag
startTimestamp := date_trunc('day', $1);
endTimestamp := startTimestamp + interval '1 day';
-- alte Statistiken löschen
raise notice 'day % deleting old statistics', startTimestamp;
countDelete := '-1';
delete from history
where timestamp >= startTimestamp
and timestamp < endTimestamp
and reading like 'stat%Last';
if FOUND then
get diagnostics countDelete = ROW_COUNT;
end if;
raise notice 'day % deleted %', startTimestamp, countDelete;
raise notice 'day % selecting-inserting new (Timerange: % - %)', startTimestamp, startTimestamp, endTimestamp;
countInsert := '0';
FOR r IN select max( timestamp ) as timestamp,
device,
min(type) as type ,
'' as event ,
('stat' || upper(substring(reading from 1 for 1)) || substring(reading from 2) || 'DayAvgLast') as reading ,
trunc(avg( cast(value as numeric )),2) as value ,
'' as unit
from history
and (value ~ '^([0-9]+[.]?[0-9]*|[.][0-9]+)$') = 't'
and reading not like 'stat%'
group by device, reading, date_trunc('day', timestamp)
LOOP
-- build new statistics entry
r.event := r.reading || ': ' || r.value;
r.unit = '';
insert into history values (r.timestamp, r.device, r.type, r.event, r.reading, r.value, r.unit);
raise notice 'insert %|%|%|%', r.timestamp, r.device, r.reading, r.value;
countInsert := countInsert + 1;
END LOOP;
raise notice 'day % % new entries', startTimestamp, countInsert;
RETURN;
EXCEPTION
WHEN division_by_zero THEN
RAISE NOTICE 'caught division_by_zero';
END;
$BODY$
LANGUAGE 'plpgsql' ;
CREATE OR REPLACE FUNCTION updateStat1Month(timestamp with time zone) RETURNS void AS
$BODY$
DECLARE
startTimestamp2 timestamp;
BEGIN
startTimestamp := date_trunc('month', $1);
startTimestamp2 := startTimestamp;
endTimestamp := startTimestamp + interval '1 month' - interval '1 day';
raise notice 'Started Month % at: % (End: %)', startTimestamp, timeofday(), endTimestamp;
loop
raise notice '--------------------------------- new day -----------------------------------------------------------------';
raise notice 'NOW: %', timeofday();
raise notice 'Started Day %', startTimestamp2;
PERFORM updateStat1day(startTimestamp2);
raise notice 'Finished Day %', startTimestamp2;
startTimestamp2 := startTimestamp2 + interval '1 day';
exit when startTimestamp2 > endTimestamp;
end loop;
raise notice 'Finished Month % at: %', startTimestamp, timeofday();
RETURN;
EXCEPTION
END;
$BODY$
Aufruf der Scripte (Datenbank-Schema "fhemDB"; Unix-User unter dem Postgres läuft "postgres"):
Scriptinhalt anpassen (Timestamp auf den gewünschten Tag/Monat ändern)
Berechnung für 1 Tag:
sudo -u postgres psql -d fhemDB -a -f ./calc_statistics_for_1_day.postgres.sql 2>&1 | tee ./statRecalc.logBerechnung für 1 Monat:
sudo -u postgres psql -d fhemDB -a -f ./calc_statistics_for_1_month.postgres.sql 2>&1 | tee ./statRecalc.logTagesberechnung ist immer von 00:00:00 - 23:59:59,999999
Monatsberechnung ist immer vom jeweiligen 1. bis zum monatsletzten.
meine Sytemumgebung:
- Cubietruck mit Igor-Image
- /-Partition auf externe SSD ausgelagert
- DB-Log schreibt in einen Postgres SQL-Server 9.3
- Devices in Modulen die im DBLOG landen
CUL_HM : 51 (real ca 20 Endgeräte - viele haben mehrere Devices)
EC3000 : 5
SYSMON : 1 - DB wird durch die 5 EC-Devices "geflutet" - jedes erstellt im 5 Sekunden-Takt einen neuen Wert
Laufzeit (ca 190.000 - 320.000 Werte in DB pro Tag - 7.400.000 pro Monat):
- 1 Tag: ca 50 s
- 1 Monat: ca 7 Minuten
was ich damit mache:
-) einmalig Monatsweise die Statistiken in der DB nachrechnen lassen (calc_statistics_for_1_month.postgres.sql)
-) laufend per Cron-job kurz nach Mitternacht die Vortagesstatistiken berechnen lassen (calc_statistics_for_1_day.postgres.sql)
Verbesserungsvorschläge sind willkommen und werden hier eingearbeitet.
Implementierung als Cron folgt in ein paar Tagen.
Übernahme ins Wiki kann gerne erfolgen!
