FHEM => Anfängerfragen => Thema gestartet von: Kharim am 07 Januar 2016, 11:04:52
Titel: SYSMON Fehler?
Beitrag von: Kharim am 07 Januar 2016, 11:04:52
Hallo Zusammen,
mein Log ist immer wieder voll dieser Einträge:
2016.01.07 06:55:45 1: PERL WARNING: Use of uninitialized value in int at ./FHEM/42_SYSMON.pm line 3569.
    invalid subsection length 101056566, max allowed 32
    ignoring unknown subsection with type 5 length 32
sh: error while loading shared libraries: libc.so.6: cannot open shared object file: No such file or directory
2016.01.07 06:55:45 1: PERL WARNING: Use of uninitialized value in int at ./FHEM/42_SYSMON.pm line 3460.
free: error while loading shared libraries: libc.so.6: cannot open shared object file: No such file or directory
2016.01.07 06:55:45 1: PERL WARNING: Use of uninitialized value $val in concatenation (.) or string at ./FHEM/42_SYSMON.pm line 1462.
2016.01.07 06:55:45 1: PERL WARNING: Use of uninitialized value $val in numeric gt (>) at ./FHEM/42_SYSMON.pm line 1465.
2016.01.07 06:55:45 1: PERL WARNING: Use of uninitialized value $val in numeric lt (<) at ./FHEM/42_SYSMON.pm line 1466.
2016.01.07 06:55:45 1: PERL WARNING: Use of uninitialized value $val in addition (+) at ./FHEM/42_SYSMON.pm line 1467.
2016.01.07 06:55:45 1: PERL WARNING: Use of uninitialized value in int at ./FHEM/42_SYSMON.pm line 3579.
2016.01.07 06:56:48 1: PERL WARNING: Use of uninitialized value in int at ./FHEM/42_SYSMON.pm line 3438.
uptime: error while loading shared libraries: libc.so.6: cannot open shared object file: No such file or directory
2016.01.07 06:56:48 1: PERL WARNING: Use of uninitialized value in int at ./FHEM/42_SYSMON.pm line 3569.
2016.01.07 06:56:48 1: PERL WARNING: Use of uninitialized value in int at ./FHEM/42_SYSMON.pm line 3460.
2016.01.07 06:56:48 1: PERL WARNING: Use of uninitialized value $val in concatenation (.) or string at ./FHEM/42_SYSMON.pm line 1462.
2016.01.07 06:56:48 1: PERL WARNING: Use of uninitialized value $val in numeric gt (>) at ./FHEM/42_SYSMON.pm line 1465.
2016.01.07 06:56:48 1: PERL WARNING: Use of uninitialized value $val in numeric lt (<) at ./FHEM/42_SYSMON.pm line 1466.
2016.01.07 06:56:48 1: PERL WARNING: Use of uninitialized value $val in addition (+) at ./FHEM/42_SYSMON.pm line 1467.
2016.01.07 06:56:48 1: PERL WARNING: Use of uninitialized value in int at ./FHEM/42_SYSMON.pm line 3579.
2016.01.07 06:57:51 1: PERL WARNING: Use of uninitialized value in int at ./FHEM/42_SYSMON.pm line 3438.
2016.01.07 06:57:51 1: PERL WARNING: Use of uninitialized value in int at ./FHEM/42_SYSMON.pm line 3569.
2016.01.07 06:57:51 1: PERL WARNING: Use of uninitialized value in int at ./FHEM/42_SYSMON.pm line 3460.
2016.01.07 06:57:51 1: PERL WARNING: Use of uninitialized value $val in concatenation (.) or string at ./FHEM/42_SYSMON.pm line 1462.
2016.01.07 06:57:51 1: PERL WARNING: Use of uninitialized value $val in numeric gt (>) at ./FHEM/42_SYSMON.pm line 1465.
2016.01.07 06:57:51 1: PERL WARNING: Use of uninitialized value $val in numeric lt (<) at ./FHEM/42_SYSMON.pm line 1466.
2016.01.07 06:57:51 1: PERL WARNING: Use of uninitialized value $val in addition (+) at ./FHEM/42_SYSMON.pm line 1467.
2016.01.07 06:57:51 1: PERL WARNING: Use of uninitialized value in int at ./FHEM/42_SYSMON.pm line 3579.
2016.01.07 06:58:54 1: PERL WARNING: Use of uninitialized value in int at ./FHEM/42_SYSMON.pm line 3438.
2016.01.07 06:58:54 1: PERL WARNING: Use of uninitialized value in int at ./FHEM/42_SYSMON.pm line 3569.
2016.01.07 06:58:54 1: PERL WARNING: Use of uninitialized value in int at ./FHEM/42_SYSMON.pm line 3460.
2016.01.07 06:58:54 1: PERL WARNING: Use of uninitialized value $val in concatenation (.) or string at ./FHEM/42_SYSMON.pm line 1462.
2016.01.07 06:58:54 1: PERL WARNING: Use of uninitialized value $val in numeric gt (>) at ./FHEM/42_SYSMON.pm line 1465.
2016.01.07 06:58:54 1: PERL WARNING: Use of uninitialized value $val in numeric lt (<) at ./FHEM/42_SYSMON.pm line 1466.
2016.01.07 06:58:54 1: PERL WARNING: Use of uninitialized value $val in addition (+) at ./FHEM/42_SYSMON.pm line 1467.
2016.01.07 06:58:54 1: PERL WARNING: Use of uninitialized value in int at ./FHEM/42_SYSMON.pm line 3579.
2016.01.07 06:59:57 1: PERL WARNING: Use of uninitialized value in int at ./FHEM/42_SYSMON.pm line 3438.
2016.01.07 06:59:57 1: PERL WARNING: Use of uninitialized value in int at ./FHEM/42_SYSMON.pm line 3569.
2016.01.07 06:59:57 1: PERL WARNING: Use of uninitialized value in int at ./FHEM/42_SYSMON.pm line 3460.
2016.01.07 06:59:57 1: PERL WARNING: Use of uninitialized value $val in concatenation (.) or string at ./FHEM/42_SYSMON.pm line 1462.
2016.01.07 06:59:57 1: PERL WARNING: Use of uninitialized value $val in numeric gt (>) at ./FHEM/42_SYSMON.pm line 1465.
2016.01.07 06:59:57 1: PERL WARNING: Use of uninitialized value $val in numeric lt (<) at ./FHEM/42_SYSMON.pm line 1466.
2016.01.07 06:59:57 1: PERL WARNING: Use of uninitialized value $val in addition (+) at ./FHEM/42_SYSMON.pm line 1467.
2016.01.07 06:59:57 1: PERL WARNING: Use of uninitialized value in int at ./FHEM/42_SYSMON.pm line 3579.
2016.01.07 07:01:00 1: PERL WARNING: Use of uninitialized value in int at ./FHEM/42_SYSMON.pm line 3438.
2
Kann damit jemand etwas Anfangen?
P.S.: letztes FHEM Update ist ca 1 Woche her, also aktuell. Linux genauso.
Danke,
Kharim
