FHEM => Anfängerfragen => Thema gestartet von: LaserBrenner am 10 Januar 2016, 09:00:25
Titel: komische meldung nach dblog einrichtung
Beitrag von: LaserBrenner am 10 Januar 2016, 09:00:25
Moin alle zusammen,
seit dem ich die sqlite Datenbank in betrieb habe bekomme ich eine komische Meldung.
2016.01.08 11:07:01 3: Connecting to database SQLite:dbname=fhem.db with user
2016.01.08 11:07:01 3: Connection to db SQLite:dbname=fhem.db established for pid 5064
2016.01.08 11:07:01 3: Alpha2: Defined with URL http://2.240.203.239:10070/data/dynamic.xml and interval 600
2016.01.08 11:07:01 1: Including ./log/fhem.save
2016.01.08 11:07:01 3: initialUsbCheck return value: This command is not yet supported on windows
2016.01.08 11:07:01 2: SecurityCheck:  WEB,WEBphone,WEBtablet has no basicAuth attribute. telnetPort has no password/globalpassword attribute.  Restart FHEM for a new check if the problem is fixed, or set the global attribute motd to none to supress this message.
2016.01.08 11:07:01 0: Featurelevel: 5.7
2016.01.08 11:07:01 0: Server started with 33 defined entities (version $Id: fhem.pl 9893 2015-11-15 08:43:05Z rudolfkoenig $, os MSWin32, user Administrator, pid 5064)
DBD::SQLite::db STORE failed: handle 2 is owned by thread 362fe4 not current thread 4acaf4c (handles can't be shared between threads and your driver may need a CLONE method added) at fhem.pl line 4402.
DBD::SQLite::db STORE failed: handle 2 is owned by thread 362fe4 not current thread 5a0768c (handles can't be shared between threads and your driver may need a CLONE method added) at fhem.pl line 4402.
könnt ihr was mit der Meldung "DBD::SQLite::db STORE failed: handle ..." anfangen?
Matthias
