FHEM - Hausautomations-Systeme => ZWave => Thema gestartet von: soletti am 20 Januar 2016, 08:29:57
Titel: Popp KFOB-C - verschlüsselt oder nicht?
Beitrag von: soletti am 20 Januar 2016, 08:29:57
Mein KFOB-C ist includiert und über notify kann ich auf Events reagieren.
Ziel war eine 'secure Inclusion', ich bin aber nicht sicher, ob das gelungen ist.
Hier ein 'list KFOBC':
list KFOBC
   CFGFN
   DEF        cccdb181 21
   IODev      ZWDongle_1
   LASTInputDev ZWDongle_1
   MSGCNT     136
   NAME       KFOBC
   NR         399
   STATE      associationRequest 5
   TYPE       ZWave
   ZWDongle_1_MSGCNT 136
   ZWDongle_1_RAWMSG 00040015055b03c20004
   ZWDongle_1_TIME 2016-01-20 08:10:48
   homeId     cccdb181
   isWakeUp   1
   lastMsgSent 1453268873.83576
   nodeIdHex  15
   secStatus  1
   Readings:
     2016-01-20 06:47:53   CMD             ZW_APPLICATION_UPDATE
     2016-01-17 10:44:55   SECURITY        INITIALIZING (starting secure inclusion)
     2016-01-20 06:44:23   assocGroup_1    Max 10 Nodes ZWDongle_1
     2016-01-17 11:10:58   assocGroup_2    Max 10 Nodes
     2016-01-17 11:10:58   assocGroup_3    Max 10 Nodes
     2016-01-17 11:10:58   assocGroup_4    Max 10 Nodes
     2016-01-17 11:10:58   assocGroup_5    Max 10 Nodes
     2016-01-20 06:43:48   assocGroups     5
     2016-01-20 06:47:54   battery         48 %
     2016-01-20 08:10:48   cSceneSet       4
     2016-01-17 11:18:19   configButton1And3PairMode Separately
     2016-01-17 11:18:20   configButton2And4PairMode Separately
     2016-01-17 11:19:49   configCommandToControlGroupA CentralSceneToGatewayDefault
     2016-01-17 10:57:41   configCommandToControlGroupB CentralSceneToGatewayDefault
     2016-01-17 10:57:38   configCommandToControlGroupC CentralSceneToGatewayDefault
     2016-01-17 11:01:48   configCommandToControlGroupD CentralSceneToGatewayDefault
     2016-01-17 10:57:38   configInvertButtons NoDefault
     2016-01-17 11:50:13   configSendTheFollowingSwitchAll21 SwitchOnAndOff
     2016-01-17 10:57:38   configSendUnsolicitedBatteryReportOn30 ToSameNodeAsWakeUpNotification1
     2016-01-17 11:50:12   group_01        scene 00 duration 00
     2016-01-17 10:57:37   mcaSupportedGroupings 5
     2016-01-17 10:50:13   model           Popp Popp KFOB-C Remote Control
     2016-01-17 10:50:13   modelConfig     zwave.me/popp_kfob-c.xml
     2016-01-17 10:50:13   modelId         0154-0100-0103
     2016-01-17 10:55:11   powerlvl        current 0 remain 0
     2016-01-17 10:55:11   powerlvlTest    node 0 status 0 frameAck 0
     2016-01-17 11:10:58   state           associationRequest 5
     2016-01-20 06:47:55   transmit        OK
     2016-01-17 10:55:11   version         Lib 2 Prot 3.99 App 1.1 HW 1 FWCounter 0
     2016-01-20 06:47:54   wakeup          notification
     2016-01-17 10:55:10   wakeupIntervalCapabilitiesReport min 240 max 15728400 default 604672 step 240
     2016-01-20 06:47:55   wakeupReport    interval 86400 target 1
     2016-01-17 10:53:28   zwavePlusInfo    version:01 role:PortableController node:Z-Wave+Node installerIcon:0b00 userIcon:0b00
   IODev      ZWDongle_1
   classes    ZWAVEPLUS_INFO MULTI_CMD POWERLEVEL SECURITY VERSION MANUFACTURER_SPECIFIC CONFIGURATION ASSOCIATION SCENE_CONTROLLER_CONF MULTI_CHANNEL_ASSOCIATION BATTERY WAKE_UP DEVICE_RESET_LOCALLY ASSOCIATION_GRP_INFO CENTRAL_SCENE MARK BASIC CENTRAL_SCENE SWITCH_MULTILEVEL SWITCH_ALL SCENE_ACTIVATION MULTI_CHANNEL
   room       ZWave
   verbose    5
Unsicher bin ich durch:
*) Reading 'SECURITY ... INITIALIZING (starting secure inclusion)' sieht für mich so aus, als ob es nicht abgeschlossen wurde
*) in den Attributen ist kein secure_classes vorhanden
Im Gegensatz dazu würde ich aus 'secStatus  1' auf funktionierende Verschlüsselung schliessen ....
Vielen Dank für Hinweise zur Klärung meiner Frage!
schöne Grüße
   soletti
Titel: Antw:Popp KFOB-C - verschlüsselt oder nicht?
Beitrag von: A.Harrenberg am 20 Januar 2016, 09:32:39
Hi Soletti,
das Ding läuft bei Dir momentan OHNE Security...
Reading SECURITY muss auf "ENABLED" sein damit das funktioniert. Das ist irgendwas während der Inklusion hängengeblieben, daher nur der Status INITIALIZING. das "secStatus 1" ist nur eine Art interner "Zähler" für die einzelnen Schritte die bei der Inklusion durchlaufen werden.
Ist Dein FHEM aktuell? Vor kurzem sind da noch ein paar Änderungen eingeflossen die den Ablauf etwas verbessern sollten.
Bitte noch mal exkludieren und neu inkludieren, Logfile mit Verbose = 5, msecLog = 1 etc. (siehe ZWave Wiki: http://www.fhemwiki.de/wiki/Z-Wave#Welche_Infos_sollten_Anfragen_im_ZWave-Forum_enthalten.3F (http://www.fhemwiki.de/wiki/Z-Wave#Welche_Infos_sollten_Anfragen_im_ZWave-Forum_enthalten.3F)).
Andreas.
Beitrag von: soletti am 20 Januar 2016, 22:15:55
Hallo Andreas,
Danke für Deine Hinweise.
Ja, FHEM aktualisiere ich ständig - habe gesehen, dass es gerade für den KFOB-C neue xml Files gegeben hat, ebenso die neuen Möglichkeiten bei AddNode. Super - gerade zum richtigen Zeitpunkt - mein Gerät war bereits bestellt. :-D
Ich werde mich in den nächsten Tagen damit weiter beschäftigen und dann berichten!
(Heute fall ich nur mehr müde ins Bett)
schöne Grüße
   soletti
