bei mir werden verschiedene Fensterkontakte (optisch sowie magnetisch) regelmäßig als "unknown" angezeigt, obwohl sie technisch einwandfrei funktionieren.
Hier mal die Lists:
DEF 3FAA4F
IODev hmusb
NAME WZ.Fensterkontakt.Terrasse
NR 35
NTFY_ORDER 50-WZ.Fensterkontakt.Terrasse
STATE closed
TYPE CUL_HM
Readings:
2016-02-10 00:06:53 Activity unknown
2015-12-26 12:23:27 CommandAccepted yes
2015-12-26 12:23:26 D-firmware 2.4
2015-12-26 12:23:26 D-serialNr MEQ1137390
2016-02-08 17:57:57 PairedTo 0x198202
2015-12-26 12:23:48 R-cyclicInfoMsg off
2015-12-26 12:23:49 R-eventDlyTime 0 s
2015-12-26 12:23:48 R-pairCentral 0x198202
2015-12-26 12:23:48 R-sabotageMsg on
2015-12-26 12:23:49 R-sign off
2016-02-08 17:57:57 RegL_00. 02:01 09:00 0A:19 0B:82 0C:02 10:01 14:06 00:00
2016-02-08 17:57:58 RegL_01. 08:00 20:60 21:00 22:64 30:06 00:00
2015-12-26 12:23:39 alive yes
2016-02-08 17:58:33 battery ok
2016-02-08 17:58:33 contact closed (to hmusb)
2015-12-26 12:23:39 recentStateType info
2015-12-26 12:23:39 sabotageError off
2016-02-08 17:58:33 state closed
2016-02-08 17:58:33 trigDst_198202 noConfig
2016-02-08 17:58:33 trigger_cnt 64
Helper:
HM_CMDNR 1
mId 00B1
rxType 28
Expert:
def 1
det 0
raw 1
tpl 0
Io:
newChn +3FAA4F,00,00,00
prefIO
rxt 2
vccu
p:
3FAA4F
00
00
00
Mrssi:
mNo
Prt:
bErr 0
sProc 0
Q:
qReqConf
qReqStat
Role:
chn 1
dev 1
Rssi:
Shadowreg:
IODev hmusb
actCycle 030:00
actStatus unknown
alias Terrasse
autoReadReg 4_reqStatus
devStateIcon open:fts_window_1w_open@red tilted:fts_window_1w_tilt@red closed:fts_window_1w@green
expert 2_full
firmware 2.4
group Sicherheit
icon fts_door_tilt
model HM-SEC-SC-2
peerIDs 00000000,
room CUL_HM,Übersicht
serialNr MEQ1137390
subType threeStateSensor
CHANGED
DEF 000000
IODev
NAME Cul_HM
NR 37
NTFY_ORDER 50-Cul_HM
STATE alive:4 dead:0 unkn:1 off:0
TYPE CUL_HM
Readings:
2016-02-10 10:06:54 state alive:4 dead:0 unkn:1 off:0
2016-02-10 10:06:54 status_Bewegungsmelder1 alive
2016-02-10 10:06:54 status_WC.Fensterkontakt alive
2016-02-10 10:06:54 status_WZ.Fensterkontakt.Kueche alive
2016-02-10 10:06:54 status_WZ.Fensterkontakt.Seite alive
2016-02-10 10:06:54 status_WZ.Fensterkontakt.Terrasse unknown
Helper:
HM_CMDNR 1
actCycle 600
peers 2FDCE0,3C8258,3FA959,3FAA4F,3FBCB8
2fdce0:
start 2016-02-09 15:12:46
3c8258:
start 2016-02-09 18:36:43
3fa959:
3faa4f:
3fbcb8:
start 2016-02-09 18:36:53
Io:
newChn +000000,00,00,00
prefIO
rxt 0
vccu
p:
000000
00
00
00
Mrssi:
mNo
Prt:
bErr 0
sProc 0
Q:
qReqConf
qReqStat
Role:
Shadowreg:
actAutoTry 1_on
event-on-change-reading .*
model ActionDetector
room CUL_HM
Wie man sieht habe ich actCycle auf 30 Std gesetzt und obwohl das letzte Öffnen/Schließen und damit auch die letzte Rückmeldung bei weitem noch keine 30 Stunden her ist, wird der Kontakt als "unknown" angezeigt.
Das passiert regelmäßig mit unterschiedlichen Kontakten, einen Zusammenhang kann ich bis jetzt nicht erkennen.
Hat jemand einen Tipp?
Danke!
EDIT
Hier noch meine RSSI-Werte, wobei ich auch gerne mal wüsste, was besonders gute und was eher schlechte Werte sind. Hab da wenig Vergleichswerte gefunden bisher...
rssi done:
Device receive from last avg min_max count
Bewegungsmelder1 hmusb Bewegungsmelder1 -60.0 -67.3 -80.0< -60.0 216
WC.Fensterkontakt hmusb WC.Fensterkontakt -69.0 -72.8 -87.0< -66.0 28
WZ.Fensterkontakt.Kueche hmusb WZ.Fensterkontakt.Kueche -74.0 -71.0 -74.0< -68.0 2
WZ.Fensterkontakt.Seite hmusb WZ.Fensterkontakt.Seite -62.0 -63.6 -67.0< -62.0 9
WZ.Rollo.Kueche WZ.Rollo.Kueche hmusb -60.0 -61.5 -63.0< -60.0 2
WZ.Rollo.Kueche hmusb WZ.Rollo.Kueche -60.0 -60.3 -64.0< -58.0 9
WZ.Rollo.Seitentuer WZ.Rollo.Seitentuer hmusb -47.0 -47.0 -47.0< -47.0 3
WZ.Rollo.Seitentuer hmusb WZ.Rollo.Seitentuer -50.0 -49.8 -51.0< -49.0 5
WZ.Rollo.Terrasse WZ.Rollo.Terrasse hmusb -78.0 -70.7 -78.0< -63.0 3
WZ.Rollo.Terrasse hmusb WZ.Rollo.Terrasse -66.0 -66.2 -70.0< -64.0 5
WZ.Rollo.Terrasse_aussen WZ.Rollo.Terrasse_aussen hmusb -49.0 -49.7 -50.0< -49.0 3
WZ.Rollo.Terrasse_aussen hmusb WZ.Rollo.Terrasse_aussen -55.0 -53.7 -55.0< -52.0 7
unknown kommt eigentlich nur nach restart, und müsste dann bei dir spätestens nach 30 std dead oder alive werden. demnach hast du wahrscheinlich öfter restarts. und vielleicht noch schlechten funk, da der letzte status schon 2 tage alt ist, obwohl du das gegenteil behauptest.
mit cyclicInfoMsg=on kannst du zusätzlich eine zyklische statusmeldung des fk generieren lassen, etwa alle 24 std.
Hi und danke für die Antwort.
Die RSSI-Werte habe ich angehängt, deuten kann ich die aber nicht. Sind die gut/schlecht?
Mist, du hast Recht, ich habe mich im "Kontakt" geirrt, danke für den Hinweis... Bei dem hier kann es tatsächlich schon ein paar Tage her sein, dass ich ihn manuell betätigt hatte. Nichtsdestotrotz funktionieren alle Kontakte ungeachtet ihrer Stati ohne Einschränkung. Es ist auch nicht immer der gleiche betroffen, sondern verschiedene (teilweise sind die Kontakte im gleichen Raum zum HM-CFG-USB).
cyclicInfoMsg on hab ich mal gesetzt und werde es weiter beobachten.
