Hallo, ich brauche bitte Eure Hilfe bei der Entschlüsselung nach diesem Device, das mir ständig ins Logfile schreibt.
Wie kann man heraus finden um was es sich handelt?
2016.02.14 07:20:32 3: CUL_0: Unknown code A0FCD86103C593B0000000AA8E0901040::-91.5:CUL_0, help me!
2016.02.14 07:23:21 3: CUL_0: Unknown code A0FCE86103C593B0000000AA8E0901040::-91.5:CUL_0, help me!
2016.02.14 07:25:56 3: CUL_0: Unknown code A0FCF86103C593B0000000AA8E0901040::-92:CUL_0, help me!
2016.02.14 07:28:16 3: CUL_0: Unknown code A0FD086103C593B0000000AA8E0901040::-90:CUL_0, help me!
2016.02.14 07:30:22 3: CUL_0: Unknown code A0FD186103C593B0000000AA8E0901040::-93:CUL_0, help me!
2016.02.14 07:33:17 3: CUL_0: Unknown code A0FD286103C593B0000000AA8E0901040::-92.5:CUL_0, help me!
2016.02.14 07:35:58 3: CUL_0: Unknown code A0FD386103C593B0000000AA8E0901040::-91.5:CUL_0, help me!
2016.02.14 07:38:25 3: CUL_0: Unknown code A0FD486103C593B0000000AA8E0901040::-92:CUL_0, help me!
2016.02.14 07:40:37 3: CUL_0: Unknown code A0FD586103C593B0000000AA8E0901040::-90.5:CUL_0, help me!
2016.02.14 07:43:39 3: CUL_0: Unknown code A0FD686103C593B0000000AA8E0901040::-91:CUL_0, help me!
2016.02.14 07:46:26 3: CUL_0: Unknown code A0FD786103C593B0000000AA8E0901040::-90.5:CUL_0, help me!
2016.02.14 07:48:59 3: CUL_0: Unknown code A0FD886103C593B0000000AA8E0901040::-91.5:CUL_0, help me!
2016.02.14 07:51:18 3: CUL_0: Unknown code A0FD986103C593B0000000AA8E0901040::-91.5:CUL_0, help me!
2016.02.14 07:53:22 3: CUL_0: Unknown code A0FDA86103C593B0000000AA8E0901040::-90.5:CUL_0, help me!
2016.02.14 07:56:15 3: CUL_0: Unknown code A0FDB86103C593B0000000AA8E0901040::-91:CUL_0, help me!
2016.02.14 07:58:55 3: CUL_0: Unknown code A0FDC86103C593B0000000AA8DF901040::-90.5:CUL_0, help me!
2016.02.14 08:01:19 3: CUL_0: Unknown code A0FDD86103C593B0000000AA8DF901040::-92:CUL_0, help me!
2016.02.14 08:03:30 3: CUL_0: Unknown code A0FDE86103C593B0000000AA8DF901040::-91:CUL_0, help me!
2016.02.14 08:06:30 3: CUL_0: Unknown code A0FDF86103C593B0000000AA8DF901040::-91.5:CUL_0, help me!
2016.02.14 08:09:15 3: CUL_0: Unknown code A0FE086103C593B0000000AA8DF901040::-91.5:CUL_0, help me!
2016.02.14 08:14:03 3: CUL_0: Unknown code A0FE286103C593B0000000AA8DF901040::-92.5:CUL_0, help me!
2016.02.14 08:16:05 3: CUL_0: Unknown code A0FE386103C593B0000000AA8DF901040::-92:CUL_0, help me!
2016.02.14 08:18:57 3: CUL_0: Unknown code A0FE486103C593B0000000AA8DF901040::-93.5:CUL_0, help me!
2016.02.14 08:21:35 3: CUL_0: Unknown code A0FE586103C593B0000000AA8DF901040::-92:CUL_0, help me!
2016.02.14 08:23:58 3: CUL_0: Unknown code A0FE686103C593B0000000AA8DF901040::-92.5:CUL_0, help me!
2016.02.14 08:26:06 3: CUL_0: Unknown code A0FE786103C593B0000000AA8DF901040::-90:CUL_0, help me!
2016.02.14 08:29:04 3: CUL_0: Unknown code A0FE886103C593B0000000AA8DF901040::-90.5:CUL_0, help me!
2016.02.14 08:31:48 3: CUL_0: Unknown code A0FE986103C593B0000000AA8DF901040::-90.5:CUL_0, help me!
2016.02.14 08:34:17 3: CUL_0: Unknown code A0FEA86103C593B0000000AA8DF901040::-91:CUL_0, help me!
2016.02.14 08:36:32 3: CUL_0: Unknown code A0FEB86103C593B0000000AA8E0901040::-89:CUL_0, help me!
2016.02.14 08:38:33 3: CUL_0: Unknown code A0FEC86103C593B0000000AA8DF901040::-91:CUL_0, help me!
2016.02.14 08:41:23 3: CUL_0: Unknown code A0FED86103C593B0000000AA8E0901040::-92:CUL_0, help me!
2016.02.14 08:43:58 3: CUL_0: Unknown code A0FEE86103C593B0000000AA8E0901040::-89.5:CUL_0, help me!
2016.02.14 08:48:26 3: CUL_0: Unknown code A0FF086103C593B0000000AA8E0901040::-91:CUL_0, help me!
2016.02.14 08:54:04 3: CUL_0: Unknown code A0FF286103C593B0000000AA8E0901040::-91.5:CUL_0, help me!
2016.02.14 08:58:45 3: CUL_0: Unknown code A0FF486103C593B0000000AA8E0901040::-90:CUL_0, help me!
2016.02.14 09:01:48 3: CUL_0: Unknown code A0FF586103C593B0000000AA8DF901040::-90.5:CUL_0, help me!
2016.02.14 09:04:36 3: CUL_0: Unknown code A0FF686103C593B0000000AA8E0901040::-91:CUL_0, help me!
Tippe auch ein Device aus der Nachbarschaft...
Fhem hat diese Nachrichten nicht verarbeitet, meist die Nachbarschaft.
Eine vccu konsumiert die messages und legt readings an. Mit defignunknown, also definiere-unbekannte-devices-und-setze-sie-auf-ignore kannst du gelegentlich kontrollieren und aufräumen.
Oder ein eigenes Gerät was angeschaltet aber noch nicht gepairt ist?
A0FE986103C593B0000000AA8DF901040 bedeutet doch: Ich kenne keine Zentrale - oder?
Danke Die für den Hinweis, den ich versucht habe umzusetzen. Leider bin ich nicht dahinter gekommen wie denn der Befehl genau aussehen muss. Ich erhalte immer ein "Command unknown" zurück. Kannst Du mir bitte mit der Syntax helfen?
VG Andy
Welchen Befehl hast Du den eingegeben ?
Hast Du schon mal hier geschaut ?
http://www.fhemwiki.de/wiki/Virtueller_Controller_VCCU (http://www.fhemwiki.de/wiki/Virtueller_Controller_VCCU)
Ich habs mit set defIgnUnknown und dem Wert aus dem Log versucht, das habe ich in der Referenz gefunden, aber wie gesagt so geht das nicht.
Meine Installation läuft seit einiger Zeit auf einem Raspi, das war schon eine Anstrengung für mich, das dort hinzukriegen. Wenn ich Deinen Tip richtig verstehe muss ich die VCCU jetzt nachträglich installieren, dann würde das funktionieren?
VG Andy
defIgnUnknown ist ein Befehl der vccu, die Du noch nicht angelegt hast.
Mit set <NAME_DEINER_VCCU> defIgnUnknown sollten die gefundenen Nachbar-Devices dann ignoriert werden.
http://forum.fhem.de/index.php/topic,43933.msg358478.html#msg358478 (http://forum.fhem.de/index.php/topic,43933.msg358478.html#msg358478)
Danke für die Hilfe, ich lese mich mal ein! :)
