Hallo, ich betreibe mehrere Temperatursensoren der Technoline Reihe an einem Jeelink CUL.
Bei einem Sensor springt die Temperatur seit einiger Zeit immer zwischen zwei Werten, siehe log.
2016-04-03_16:25:01 LaCrosse_08 temperature: 18.9
2016-04-03_16:25:01 LaCrosse_08 temperature: 20.9
2016-04-03_16:25:05 LaCrosse_08 temperature: 18.9
2016-04-03_16:25:05 LaCrosse_08 temperature: 20.9
2016-04-03_16:25:13 LaCrosse_08 temperature: 18.9
2016-04-03_16:25:13 LaCrosse_08 temperature: 20.9
2016-04-03_16:25:17 LaCrosse_08 temperature: 18.9
2016-04-03_16:25:17 LaCrosse_08 temperature: 20.9
2016-04-03_16:25:21 LaCrosse_08 temperature: 18.9
2016-04-03_16:25:21 LaCrosse_08 temperature: 20.9
2016-04-03_16:25:25 LaCrosse_08 temperature: 18.9
2016-04-03_16:25:25 LaCrosse_08 temperature: 20.9
2016-04-03_16:25:29 LaCrosse_08 temperature: 18.9
2016-04-03_16:25:29 LaCrosse_08 temperature: 20.9
2016-04-03_16:25:33 LaCrosse_08 temperature: 18.9
2016-04-03_16:25:33 LaCrosse_08 temperature: 20.9
2016-04-03_16:25:37 LaCrosse_08 temperature: 18.9
2016-04-03_16:25:38 LaCrosse_08 temperature: 20.9
2016-04-03_16:25:41 LaCrosse_08 temperature: 18.9
2016-04-03_16:25:42 LaCrosse_08 temperature: 20.9
2016-04-03_16:25:45 LaCrosse_08 temperature: 18.9
2016-04-03_16:25:46 LaCrosse_08 temperature: 20.9
2016-04-03_16:25:49 LaCrosse_08 temperature: 19
2016-04-03_16:25:50 LaCrosse_08 temperature: 20.9
2016-04-03_16:25:54 LaCrosse_08 temperature: 19
2016-04-03_16:25:54 LaCrosse_08 temperature: 20.9
2016-04-03_16:25:58 LaCrosse_08 temperature: 19
2016-04-03_16:25:58 LaCrosse_08 temperature: 20.9
2016-04-03_16:26:02 LaCrosse_08 temperature: 19
2016-04-03_16:26:02 LaCrosse_08 temperature: 20.9
2016-04-03_16:26:06 LaCrosse_08 temperature: 19
2016-04-03_16:26:06 LaCrosse_08 temperature: 20.9
2016-04-03_16:26:10 LaCrosse_08 temperature: 19
2016-04-03_16:26:18 LaCrosse_08 temperature: 20.9
2016-04-03_16:26:22 LaCrosse_08 temperature: 19
2016-04-03_16:26:22 LaCrosse_08 temperature: 20.9
2016-04-03_16:26:26 LaCrosse_08 temperature: 19
2016-04-03_16:26:26 LaCrosse_08 temperature: 20.9
2016-04-03_16:26:30 LaCrosse_08 temperature: 19
2016-04-03_16:26:30 LaCrosse_08 temperature: 20.9
2016-04-03_16:26:34 LaCrosse_08 temperature: 19
2016-04-03_16:26:38 LaCrosse_08 temperature: 20.9
2016-04-03_16:26:42 LaCrosse_08 temperature: 19
2016-04-03_16:26:43 LaCrosse_08 temperature: 20.8
2016-04-03_16:26:46 LaCrosse_08 temperature: 19
2016-04-03_16:26:47 LaCrosse_08 temperature: 20.8
2016-04-03_16:26:54 LaCrosse_08 temperature: 19
2016-04-03_16:26:55 LaCrosse_08 temperature: 20.8
2016-04-03_16:26:59 LaCrosse_08 temperature: 19
2016-04-03_16:26:59 LaCrosse_08 temperature: 20.8
2016-04-03_16:27:03 LaCrosse_08 temperature: 19
Hat jemand eine Idee warum das so ist?
Was ist ein JeeLink CUL?
Ich vermute, dass zwei Sensoren die gleiche ID (08) haben.
http://www.fhemwiki.de/wiki/JeeLink
Das ist ein JeeLink. Und ein CUL ist ein CUL. Drum habe ich mich gefragt, was ein "JeeLink CUL" wohl sein könnte.
ID's geprüft, alle sind unterschiedlich.
Ich meinte damit, dass zwei Sensoren (die Hardware) mit dieser ID senden.
Was für Sensoren sind es denn?
Wie bereits geschrieben ist es ein TX 37 IT von Technoline
Ahh, klar, im Titel :)
Schau mal hier: https://forum.fhem.de/index.php?topic=34337.0
Du hast vermutlich mehrere Sensoren mit gleicher ID, bist nicht der Erste.
Steht auf den Sensoren eine ID drauf?
Nein, auch das wurde geprüft. Nur der eine Sensor hat die Adresse 08.
Kommen an dem LaCrosse device in FHEM noch Daten an, wenn Du nur aus diesem einen Sensor die Batterien raus nimmst?
Das war ein entscheidender Tipp, es kommen weiterhin Daten.
Das ganze hat vor nachvollziehbar vor 25 Tagen begonnen.
Wahrscheinlich hat an diesem Tag ein Nachbar auch ein TX 37 in Betrieb genommen.
Kann man die ID verändern?
Vielen Dank für Eure Unterstützung.
Den Verdacht hatte ich auch schon.
Ich glaube nein.
