FHEM => Anfängerfragen => Thema gestartet von: FHEMAN am 13 April 2016, 11:29:50
Titel: Mein FHEM ist tot - wie gehe ich vor?
Beitrag von: FHEMAN am 13 April 2016, 11:29:50
gestern Abend war noch alles wunderbar. Heute Nacht bekam ich 3 merkwürdige Neustarts per Mail übermittelt. Und heute früh hat mein Haus jeden Komfort verloren.
Was kann ich nun tun, außer:
2016.04.13 08:04:12 1: Including fhem.cfg
2016.04.13 08:04:12 3: telnetPort: port 7072 opened
2016.04.13 08:04:13 3: WEB: port 8083 opened
2016.04.13 08:04:15 2: eventTypes: loaded 5637 events from ./log/eventTypes.txt
2016.04.13 08:04:16 3: Opening CUL0 device /dev/ttyACM0
2016.04.13 08:04:16 3: Setting CUL0 serial parameters to 9600,8,N,1
2016.04.13 08:04:16 3: CUL0 device opened
2016.04.13 08:04:16 3: CUL0: Possible commands: BbCFiAZEGMKUYRTVWXefmltux
2016.04.13 08:04:16 2: Switched CUL0 rfmode to HomeMatic
2016.04.13 08:05:00 3: FHEM2FHEM opening Fritzremote at 192.168.2.1:7072
2016.04.13 08:05:00 3: Can't connect to 192.168.2.1:7072: Connection refused
2016.04.13 08:05:00 3: Opening Fritzbox_Callmonitor device 192.168.2.1:1012
2016.04.13 08:05:00 3: Fritzbox_Callmonitor device opened
2016.04.13 08:05:02 3: RoombaStat: Defined with URL http://192.168.2.110/roomba.xml and interval 180
2016.04.13 08:05:02 3: RoombaStat: the attribute readingsName2 should no longer be used. Please use reading01Name syntax instead
2016.04.13 08:05:02 3: RoombaStat: For most old attributes you can specify enableControlSet and then set device upgradeAttributes to automatically modify the configuration
2016.04.13 08:05:02 3: RoombaStat: the attribute readingsName3 should no longer be used. Please use reading01Name syntax instead
2016.04.13 08:05:02 3: RoombaStat: the attribute readingsName4 should no longer be used. Please use reading01Name syntax instead
2016.04.13 08:05:02 3: RoombaStat: the attribute readingsRegex2 should no longer be used. Please use reading01Regex syntax instead
2016.04.13 08:05:02 3: RoombaStat: the attribute readingsRegex3 should no longer be used. Please use reading01Regex syntax instead
2016.04.13 08:05:02 3: RoombaStat: the attribute readingsRegex4 should no longer be used. Please use reading01Regex syntax instead
2016.04.13 08:05:05 1: Including ./log/fhem.save
2016.04.13 08:05:07 3: Device ... added to ActionDetector with 000:10 time
2016.04.13 08:05:10 3: Device ... added to ActionDetector with 000:10 time
2016.04.13 08:05:10 1: FHEM global: System INITIALIZED
2016.04.13 08:40:35 1: Including fhem.cfg
2016.04.13 08:40:35 1: telnetPort: Can't open server port at 7072: Address already in use. Exiting.
Wo setze ich jetzt am besten an?
Seit gestern haben wir massive Probleme mit dem Internet. Kann das damit zusammenhängen?
Ronny
Titel: Antw:Mein FHEM ist tot - wie gehe ich vor?
Beitrag von: franky08 am 13 April 2016, 11:45:05
Was passiert nach einem kompletten reboot des Systems? Auf was für einer Plattform läuft dein fhem?
Frank
Beitrag von: Rince am 13 April 2016, 11:46:58
ZitatSeit gestern haben wir massive Probleme mit dem Internet. Kann das damit zusammenhängen?
Ja.
Kann es durchaus. Wenn du irgendwelche Module einsetzt, die durch Pings oder Abfragen Daten aus dem Internet ziehen, und bei einer nicht-Antwort fhem blockieren.
Schwierig wird imho rauszufinden, welches Modul hier bockt.
Mach erst mal auf deiner Linux-Konsole ein "top"
Das zeigt die an welche Prozesse laufen und wie viel CPU-Last sie ziehen.
Wenn da oben ein Prozess "Perl" mit nahezu 100% CPU-Last steht, würde ich da anfangen zu suchen...
PS:
Off topic:
Was auch lustig ist: wenn man seinen fhem Rechner auf DHCP gestellt hat, und der Strom ausfällt...
Wenn er wieder kommt, kann er durchaus schneller sein als der DHCP-Server im Netz (Fritte) => dann gibt er sich eine eigene. Er läuft zwar, aber in einem völlig falschen Netz.
Beitrag von: VB90 am 13 April 2016, 12:39:02
Ich würde versuchen, fhem über die Konsole per Hand zu stoppen und starten.
Wenn das fehlschlägt, bekommst du eine entsprechende Meldung.
Wenn du gestern irgendwelche Änderungen vorgenommen hast, würde ich diese händisch über die .cfg auskommentieren und somit deaktivieren.
Eventuell erneuerte Module wieder auf den alten Stand bringen.
Logfiles sichern und sichten. Vielleicht ist im Log von heute Nacht mehr zu erkennen.
Wenn das alles nichts bringt, mit einer "Nackten" fhem.cfg starten, um sicherzustellen, das das System ansich läuft und einzugrenzen ob es ein Config-Problem deines FHEM ist.
vb
Beitrag von: CoolTux am 13 April 2016, 12:41:02
Und einfach mal alles abziehen was so an CUL's oder anderen USB Stickgeraffel dran hängt. Alternativ die automatische USB erkennung aus dem global Bereich auskommentieren.
Beitrag von: FHEMAN am 13 April 2016, 12:50:23
OK, ihr macht mir Hoffnung :)
ZitatWas passiert nach einem kompletten reboot des Systems?
Nichts auffälliges. Bzw. worauf zielt Deine Frage ab? Anscheinend wird fhem.pl gestartet, die Weboberfläche bzw. FHEM allgemein sind nicht erreichbar.
ZitatMach erst mal auf deiner Linux-Konsole ein "top"
Nix auffälliges, max. 2% CPU Load von Squeezelite:
top - 12:41:42 up  4:37,  1 user,  load average: 0.19, 0.07, 0.06
Tasks:  83 total,   1 running,  82 sleeping,   0 stopped,   0 zombie
%Cpu(s):  0.7 us,  0.7 sy,  0.0 ni, 97.6 id,  0.0 wa,  0.0 hi,  1.1 si,  0.0 st
KiB Mem:   2046904 total,   299704 used,  1747200 free,    20272 buffers
KiB Swap:        0 total,        0 used,        0 free,   203676 cached
  PID USER      PR  NI  VIRT  RES  SHR S  %CPU %MEM    TIME+  COMMAND
2499 root      20   0 10492 9032 2764 S   1.3  0.4   4:12.74 squeezelite-arm
3166 derron    20   0  6136 1188  856 R   1.0  0.1   0:01.31 top
   62 root      rt   0     0    0    0 S   0.3  0.0   0:00.97 cfinteractive
  646 root      -2   0     0    0    0 S   0.3  0.0   0:09.27 dhd_dpc
3119 derron    20   0  8548 1416  832 S   0.3  0.1   0:00.08 sshd
3170 root      20   0     0    0    0 S   0.3  0.0   0:00.02 kworker/0:0
    1 root      20   0  1756  624  524 S   0.0  0.0   0:02.78 init
    2 root      20   0     0    0    0 S   0.0  0.0   0:00.01 kthreadd
    3 root      20   0     0    0    0 S   0.0  0.0   0:00.64 ksoftirqd/0
    5 root      20   0     0    0    0 S   0.0  0.0   0:00.00 kworker/u:0
    6 root      rt   0     0    0    0 S   0.0  0.0   0:00.01 migration/0
    7 root      rt   0     0    0    0 S   0.0  0.0   0:00.01 migration/1
    8 root      20   0     0    0    0 S   0.0  0.0   0:01.13 kworker/1:0
    9 root      20   0     0    0    0 S   0.0  0.0   0:00.43 ksoftirqd/1
   10 root       0 -20     0    0    0 S   0.0  0.0   0:00.00 cpuset
   11 root       0 -20     0    0    0 S   0.0  0.0   0:00.00 khelper
   12 root      20   0     0    0    0 S   0.0  0.0   0:00.01 kdevtmpfs
sudo /etc/init.d/fhem stop
sudo /etc/init.d/fhem start
derron@cubie:~$ sudo /etc/init.d/fhem stop
[sudo] password for derron:
Stopping fhem...
derron@cubie:~$ sudo /etc/init.d/fhem start
Starting fhem...
derron@cubie:~$
Ich lag falsch, ich kann mich nicht per TELNET verbinden, sondern nur per SSH. Ich gehe der Sache mal den Grund.
Beitrag von: franky08 am 13 April 2016, 12:56:30
Deshalb hatte ich gefragt was nach einem reboot passiert, kommentiere das usb create zeugs mal aus.
Beitrag von: Morgennebel am 13 April 2016, 12:56:52
Entscheidend ist diese Information:
Dein fhem möchte auf Port 7072 lauschen. Kann es aber nicht, weil ein anderes Programm diesen Port bereits nutzt.
Möglichkeiten: reboot (falls ein alter fhem-Prozeß hängen geblieben ist und den Port blockiert). netstat zur Analyse, welcher Prozeß den Port öffnet. Virenscanner :)
Ciao, -MN
