nach dem vorgestrigen Update bringen meine beiden Rolloaktoren HM-LC-Bl1PBU-FM im state einen IOErr und lassen sich nur noch von Hand schalten. Es war kein Stromausfall, keine Programmänderung etc. vorgekommen. Das List sieht so aus:
CFGFN ./FHEM/Arbeitszimmer.cfg
DEF 257247
IODev CUL_0
NAME AZ_Rolladen
NR 376
STATE IOerr
TYPE CUL_HM
protCmdDel 6
protIOerr 3 last_at:2016-04-14 20:38:11
protState CMDs_done_Errors:1
Readings:
2016-04-13 07:05:00 CommandAccepted yes
2015-05-03 19:32:47 D-firmware 2.2
2015-05-03 19:32:47 D-serialNr KEQ1022287
2015-05-03 19:33:14 PairedTo 0x31AD26
2015-02-18 12:19:18 R-confBtnTime permanent
2015-05-03 19:33:15 R-driveDown 20 s
2015-02-18 12:19:19 R-driveTurn 0.5 s
2015-05-03 19:31:32 R-driveUp 21 s
2015-02-18 12:19:18 R-intKeyVisib invisib
2015-02-18 12:19:18 R-localResDis off
2015-02-18 12:19:18 R-pairCentral 0x31AD26
2015-02-18 12:19:19 R-sign off
2015-02-18 12:19:19 R-statusInfoMinDly 3 s
2015-02-18 12:19:19 R-statusInfoRandom 0 s
2015-02-18 12:19:19 R-transmitTryMax 6
2016-04-13 07:05:35 deviceMsg on (to VCCU)
2016-04-13 07:05:35 level 100
2016-04-13 07:05:35 motor stop:on
2016-04-13 07:05:35 pct 100
2015-07-27 09:17:22 powerOn 2015-07-27 09:17:22
2016-04-13 07:05:35 recentStateType info
2016-04-14 20:38:11 state IOerr
2016-04-13 07:05:35 timedOn off
Helper:
HM_CMDNR 1
dlvl 00
dlvlCmd ++A01131AD262572470201000000
mId 006A
rxType 1
Expert:
def 1
det 1
raw 0
tpl 0
Io:
newChn +257247,00,00,00
prefIO
rxt 0
vccu
p:
257247
00
00
00
Mrssi:
mNo
Prt:
bErr 0
sProc 0
Q:
qReqConf
qReqStat 00
Role:
chn 1
dev 1
prs 1
IODev CUL_0
autoReadReg 5_readMissing
devStateIcon Auf:fts_shutter_10@green Zu:fts_shutter_100@black 9\d.*:fts_shutter_10 8\d.*:fts_shutter_20 7\d.*:fts_shutter_30 6\d.*:fts_shutter_40 5\d.*:fts_shutter_50 4\d.*:fts_shutter_60 3\d.*:fts_shutter_70 2\d.*:fts_shutter_80 1\d.*:fts_shutter_90 0\d.*:fts_shutter_100
event-on-change-reading state
eventMap on:Auf off:Zu
expert 1_on
firmware 2.2
fp_UG1024 640,989,1,Rolladen,
group Jalousie
model HM-LC-Bl1PBU-FM
peerIDs 00000000,
room 3.1_Arbeitszimmer
serialNr KEQ1022287
subType blindActuator
webCmd Auf:Zu
Hat jemand eine Idee, wie ich den Fehler beseitige? Finde im Forum nichts zu diesem speziellen Problem.
Gruß Jürgen
