FHEM => fhem-users => Thema gestartet von: rudolfkoenig am 07 Oktober 2008, 21:43:40
Titel: [FHZ] radiator control?
Beitrag von: rudolfkoenig am 07 Oktober 2008, 21:43:40
Hi there,
not exactly a FHZ1000 question, but still somewhat related ;)
I think about installing several HomeMatic-Funk-Stellantrieb devices
to all the radiators in my appartment.
In a perfect World I would then be able to control these devices
using some kind of Modem Device connected to one of my embedded Linux
Computers or homeserver via USB or serial Port.
Unfortunately there is no such thing as a perfect World.
Am I right in the assumption, that the so called BidCos protocol is
not only proprietary but also undocumented?
Is it further correct, that the BidCos based devices are at least
using a bidirectional protocol?
 http://www.elv.de/HomeMatic-Funk-Stellantrieb/x.aspx/cid_74/ detail_10/detail2_21645
 http://www.elv.de/Ventilantrieb-FHT8V,-ARR-Bausatz,-inkl-Bat terien/x.aspx/cid_74/detail_10/detail2_11173
The latter one is about half the price of the first one which could
corroborate this belief.
I don't think, that I really need these strange thermostat devices.
Theses ones should be easily replaceable by an array of 1-wire temperature
sensors conencted to the already mentioned Linux based devices.
Any further hints?
Sven
P.S.: BTW, would Zigbee be a more standard aproach to do things like
this the way they should be done?
"In the land of the brave and the free, we defend our freedom
with the GNU GPL" (Richard M. Stallman on www.gnu.org)
/me is giggls@ircnet, http://sven.gegg.us/ on the Web
You received this message because you are subscribed to the Google Groups "FHZ1000 users on Linux" group.
To post to this group, send email to FHZ1000-users-on-unix@googlegroups.com
To unsubscribe from this group, send email to FHZ1000-users-on-unix+unsubscribe@googlegroups.com
For more options, visit this group at http://groups.google.com/group/FHZ1000-users-on-unix?hl=en
Titel: [FHZ] Re: radiator control?
Beitrag von: Guest am 07 Oktober 2008, 23:42:26
Sven Geggus:
Yes.
True.
... and while you're at it, you can control the radiators with cheaper
(10€ or so) wired solutions. Controlling these with 1wire is however a
bit more tricky because they need PWM-modulated 220V power. (I'm
thinking about doing the same thing.)
Definitely.
Matthias Urlichs   |   {M:U} IT Design @ m-u-it.de   |  smurf@smurf.noris.de
Disclaimer: The quote was selected randomly. Really. | http://smurf.noris.de
v4sw7$Yhw6+8ln7ma7u7L!wl7DUi2e6t3TMWb8HAGen6g3a4s6Mr1p-3/-6 hackerkey.com
Memories of you remind me of you.
-- Karl Lehenbauer
