Hi!
I'm planing to buy CM11 computer com interface and LM12 and use FHEM
to manage that devices.
I've installed the last version of fhem from cvs:
cvs -z3 -d:pserver:anonymous@cvs.fhem.berlios.de:/cvsroot/fhem co fhem
I'm writing config as it is written on
http://groups.google.com/group/FHZ1000-users-on-unix/browse_ thread/thread/125859bf3dbcda82?hl=en
When I'm stating fhem, I have such text in log file:
2009.02.26 16:16:35 3: wrong syntax: define FHZ devicename
[normal|strangetty] [mobile]
2009.02.26 16:16:35 3: Unknown argument lm12, choose one of CM11 CUL
CUL_EM CUL_WS EM EMEM EMGZ EMWZ FHT FHZ FS20 FileLog HMS IPWE KS300
LIRC M232 M232Counter M232Voltage SCIVT WS2000 WS300 X10 at dummy
notify structure watchdog
2009.02.26 16:16:35 0: Server started (version =VERS= from =DATE=
($Id: fhem.pl,v 1.69 2009/02/11 12:58:22 rudolfkoenig Exp $), pid
21694)
Here is my whole fhem config file:
# Minimalistic fhem.pl configfile. Take a look at the other examples
for more.
attr global logfile /var/log/fhem/fhem-%Y-%m.log
attr global statefile /var/log/fhem/fhem.save # where to save
the state of the devices
attr global verbose 3 # "normal"
verbosity (min 1, max 5)
attr global port 7072 # our TCP/IP port
(localhost only)
attr global modpath /usr/local/lib/ # where our FHEM
directory is
define CM11 CM11
define lamp1 lm12 A 1
Can you please explain to me how can i set up CM11. Thank you.
bessaraobov
You received this message because you are subscribed to the Google Groups "FHZ1000 users on Linux" group.
To post to this group, send email to FHZ1000-users-on-unix@googlegroups.com
To unsubscribe from this group, send email to FHZ1000-users-on-unix+unsubscribe@googlegroups.com
For more options, visit this group at http://groups.google.com/group/FHZ1000-users-on-unix?hl=en
The message is somehow misleading, as it is a CM11 device, not an FHZ
device. You have to specify the CM11-devicename.
Something like
define myCM11 CM11 /dev/ttyUSB0
Thank you for your answer.
So, now my conf file has lines (I'm planning to buy com device, not usb):
define myCM11 CM11 /dev/ttyS0
In my log I have:
2009.02.26 18:30:50 3: CM11 opening CM11 device /dev/ttyS0
2009.02.26 18:30:50 3: CM11 opened CM11 device /dev/ttyS0
2009.02.26 18:30:50 3: Unknown argument lm12, choose one of CM11 CUL CUL_EM
CUL_WS EM EMEM EMGZ EMWZ FHT FHZ FS20 FileLog HMS IPWE KS300 LIRC M232
M232Counter M232Voltage SCIVT WS2000 WS300 X10 at dummy notify structure
watchdog
2009.02.26 18:30:50 0: Server started (version =VERS= from =DATE= ($Id:
fhem.pl,v 1.69 2009/02/11 12:58:22 rudolfkoenig Exp $), pid 2400)
So I don't have error for the wrong syntax, but I have error with unknown
argument lm12.
I stil don't understand. How should I define the X10 module?
2009/2/26 Rudolf Koenig
> Something like
bessarabov.
Am Donnerstag, 26. Februar 2009 schrieb Иван Бессарабов:
the correct syntax (see X10 section in commandref.html, especially examples)
is
define lamp1 X10 lm12 A 1
Regards,
Boris
Thank you! Now everythings seems ok. (Actually i have an error "CM11 device
myCM11: Timeout reading checksum", but I hope this is normal, I still
haven't buy any X10 devices =) Now I feel ready to buy some X10 modules and
try them.
Sorry for such dumb question - it is my first day with X10 things =)
So, thanks again! =)
2009/2/26 Boris Neubert
> examples)
> is
> Regards,
> Boris
bessarabov.
