Hallo
ich habe die letzten Tage ein update gemacht von meinem Haupt-FHEM.
Latest Revision: 11704
File Rev Last Change
fhem.pl 11655 2016-06-13 16:52:23Z rudolfkoenig
98_autocreate.pm 11094 2016-03-20 09:41:03Z rudolfkoenig
00_CUL.pm 11637 2016-06-09 18:01:20Z rudolfkoenig
15_CUL_EM.pm 11348 2016-04-30 13:41:18Z rudolfkoenig
09_CUL_FHTTK.pm 7529 2015-01-11 18:52:43Z matscher
14_CUL_WS.pm 10794 2016-02-11 06:26:06Z rudolfkoenig
93_DbLog.pm 11424 2016-05-10 10:05:08Z rapster
98_DOIF.pm 11314 2016-04-26 18:29:24Z damian-s
98_dummy.pm 11442 2016-05-15 12:43:12Z rudolfkoenig
10_EIB.pm 11307 2016-04-25 08:02:06Z rudolfkoenig
91_eventTypes.pm 10530 2016-01-16 19:27:21Z rudolfkoenig
93_FHEM2FHEM.pm 10530 2016-01-16 19:27:21Z rudolfkoenig
01_FHEMWEB.pm 11690 2016-06-18 18:25:33Z rudolfkoenig
92_FileLog.pm 11336 2016-04-28 19:28:05Z rudolfkoenig
10_FRM.pm 11565 2016-05-30 12:42:10Z arnoaugustin
10_FS20.pm 11432 2016-05-12 08:35:57Z rudolfkoenig
# $Id: 10_HM485.pm 0743 2016-02-26 09:02:00Z Thorsten Pferdekaemper $
No Id found for 00_HM485_LAN.pm
12_HMS.pm 5097 2014-03-02 15:25:08Z rudolfkoenig
No Id found for hmw_io12_sw14_dr.pm
No Id found for hmw_io12_sw7_dr.pm
No Id found for hmw_io12_sw7_dr_V3_02.pm
No Id found for hmw_io_12_fm.pm
No Id found for hmw_sen_sc_12_dr.pm
10_KNX.pm 11643 2016-06-10 14:43:04Z andi291
No Id found for 99_MyUtils.pm
91_notify.pm 11178 2016-04-03 14:20:32Z rudolfkoenig
11_OWDevice.pm 11360 2016-05-01 13:11:21Z borisneubert
10_OWServer.pm 11137 2016-03-28 14:07:20Z borisneubert
No Id found for 99_perfmon.pm
98_PID20.pm 10722 2016-02-04 17:12:18Z john99sr
73_PRESENCE.pm 11650 2016-06-12 14:28:18Z markusbloch
33_readingsGroup.pm 11573 2016-05-31 06:54:52Z justme1968
98_structure.pm 10530 2016-01-16 19:27:21Z rudolfkoenig
99_SUNRISE_EL.pm 10569 2016-01-19 06:30:28Z rudolfkoenig
98_SVG.pm 11687 2016-06-18 16:47:13Z rudolfkoenig
50_TelegramBot.pm 11548 2016-05-29 15:34:26Z viegener
98_telnet.pm 11606 2016-06-03 18:43:06Z rudolfkoenig
00_TUL.pm 11659 2016-06-13 18:01:40Z andi291
98_update.pm 10942 2016-02-26 11:08:14Z rudolfkoenig
99_Utils.pm 10570 2016-01-19 06:39:23Z rudolfkoenig
98_version.pm 11026 2016-03-08 07:25:45Z markusbloch
# $Id: 15_vz.pm 2016-01-14 09:25:24Z stephanaugustin $
No Id found for Base.pm
Blocking.pm 11465 2016-05-16 11:56:10Z rudolfkoenig
No Id found for ConfigurationManager.pm
No Id found for Constants.pm
DevIo.pm 11701 2016-06-21 09:41:19Z rudolfkoenig
No Id found for FhemWebHelper.pm
GPUtils.pm 6653 2014-10-02 11:59:37Z ntruchsess
No Id found for hmw_central.pm
No Id found for hmw_generic.pm
No Id found for hmw_io_4_fm.pm
No Id found for hmw_io_4_fm_V3_02.pm
No Id found for hmw_io_sr_fm.pm
No Id found for hmw_lc_bl1_dr.pm
No Id found for hmw_lc_bl1_dr_V3_02.pm
No Id found for hmw_lc_dim1l_dr.pm
No Id found for hmw_lc_sw2_dr.pm
No Id found for hmw_lc_sw2_dr_V3_02.pm
No Id found for hmw_virtual.pm
HttpUtils.pm 11700 2016-06-20 20:46:10Z rudolfkoenig
# $Id: OWNet.pm,v 1.24 2013/02/02 11:41:28 alfille Exp $
No Id found for PeeringManager.pm
No Id found for Platform.pm
No Id found for Protocol.pm
RTypes.pm 10476 2016-01-12 21:03:33Z borisneubert
SetExtensions.pm 11513 2016-05-24 17:56:05Z rudolfkoenig
TcpServerUtils.pm 10346 2016-01-03 12:34:27Z rudolfkoenig
No Id found for Util.pm
Jetzt habe ich ne Menge Probleme mit Codemirror.
Was mir schon alles aufgefallen ist:
ich kann keine Attribute speichern, nachdem ich eine DEF bearbeitet habe. Dazu gibts schon nen Thread:
https://forum.fhem.de/index.php/topic,54821.msg463965.html#msg463965
Ich kann keine Namen mehr vervollständigen mit STRG+Leertaste
als drittes ist mir aufgefallen, dass (noch nicht belegt - keine Zeit) es einen Unterschied mache, ob ich die Klammern in die gleiche oder in eine Leerzeile schreibe
DOELSEIF ( [08:00])(set FS20 on) funktioniert teilweise anders als
DOELSEIF (
[08:00]
set FS20 on
Als Referenz habe ich nen raspi mit fhem laufen, welches ich noch nicht upgedated habe:
fhem.pl 9893 2015-11-15 08:43:05Z rudolfkoenig
98_autocreate.pm 9415 2015-10-09 17:22:35Z rudolfkoenig
91_eventTypes.pm 8725 2015-06-10 09:50:06Z rudolfkoenig
01_FHEMWEB.pm 9867 2015-11-12 16:41:48Z rudolfkoenig
92_FileLog.pm 9838 2015-11-09 17:32:44Z rudolfkoenig
98_JsonList2.pm 8525 2015-05-04 20:48:25Z rudolfkoenig
91_notify.pm 8953 2015-07-13 15:13:06Z rudolfkoenig
11_OWDevice.pm 8629 2015-05-24 20:31:31Z borisneubert
10_OWServer.pm 8629 2015-05-24 20:31:31Z borisneubert
99_SUNRISE_EL.pm 9831 2015-11-08 19:13:09Z rudolfkoenig
98_telnet.pm 9511 2015-10-18 10:13:01Z rudolfkoenig
99_Utils.pm 7914 2015-02-08 11:14:10Z rudolfkoenig
Was ich schon getan habe:
- noch ein update
- anderen Browser probieren( Firefox, Chrome)
- Codemirror deaktivieren ( dann kann ich zumindest die attribute speichern)
- Cache löschen (steht bei mir auf 0 MB, habe trotzdem nochmal alles geleert
- reboot von Server und Workstation
Andere haben das Problem anscheinend nicht. Wenn noch Informationen notwendig sind (fhem.cfg), liefere ich diese gerne nach.
Danke,
Stephan
Andere Tasten, STRG+Q, Closebrackets, height, SmartIndent usw funktionieren...
