FHEM - Entwicklung => FHEM Code changes => Thema gestartet von: System am 17 Juli 2016, 16:45:03
Titel: change: 93_DbRep: function "diffValue" added, readingnames changed to ensure valid reading order, write "-" for readingsvalue if no dataset is found in selection range
Beitrag von: System am 17 Juli 2016, 16:45:03
change:  93_DbRep:  function "diffValue" added, readingnames changed to ensure valid reading order, write "-" for readingsvalue if no dataset is found in selection rangeView Changes
Source: change:  93_DbRep:  function "diffValue" added, readingnames changed to ensure valid reading order, write "-" for readingsvalue if no dataset is found in selection range (https://sourceforge.net/p/fhem/code/11804/)
