FHEM => fhem-users => Thema gestartet von: Hausautomat am 16 November 2009, 14:07:21
Titel: [FHZ] [pgm3] New release pgm3 v091116
Beitrag von: Hausautomat am 16 November 2009, 14:07:21
H@i,
there is a new pgm3 version in the CVS.
Look at the following screenshot for the first overview:
http://martin.htsv.net/fhz/pgm3091116.jpg
And look at the other screenshots for further information:
http://martin.htsv.net/fhz/screenshots.html
New HISTORY:
-- Feature: Google-Weather-Api added.
-- Feature: Display of all Logs including the FS20-devices (grep on
fhem.log)
-- Feature: The status of the batteries of FHT and HMS are shown in
the graphics
-- php4 disabled. Now only php5 is supported.
-- A lot of examples of the UserDefs are added.
-- UTF-8 now for everything
The new section of fhem.html:
Web frontend 3 (webfrontend/pgm3)
This frontend is PHP based and was contributed by Martin Haas. Look at
the webfrontends/pgm3/docs for more documentation. A lot more details
and screenshots can be found on Martins page: http://www.martin-haas.de/fhz
 pgm3 must not run on the same maschine like fhem.
The Devices of 95% of the users are detected and configured
automatically. Further 4% are adaptable by the function UserDef. See
config.php for explanation.
      Installation:
          o Install PHP5, the php5-Apache-Modules and php-gd. Every
current distribution should do all the needed configuration without
your input.
          o Create a directory in the Apache2 DocumentRoot (e.g.: /
home/httpd/html/pgm3) and copy all the files from the webfrontend/pgm3
to this directory.
            Make sure that this directory is writeable by the
webserver (e.g. User www-data.www-data)!
          o If you want to have access to the FHT temperature logs,
then:
                + Make sure gnuplot is installed
          o Call /pgm3/index.php
For remember: the UserDefs are desgined for all of the devices (e.g.
wired devices) which are not used from 95% of the users. If you use it
succesfull please send your UserDefs and I will add them to the
UserDef-Examples.
Have fun :-)
Martin
You received this message because you are subscribed to the Google Groups "FHEM users" group.
To post to this group, send email to fhem-users@googlegroups.com.
To unsubscribe from this group, send email to fhem-users+unsubscribe@googlegroups.com.
For more options, visit this group at http://groups.google.com/group/fhem-users?hl=.
Titel: [FHZ] Re: New release pgm3 v091116
Beitrag von: Guest am 16 November 2009, 14:35:32
Sorry, that should be "pgm3 may run on an other machine than fhem"
Beitrag von: Guest am 16 November 2009, 20:45:37
sollte eine Warnmeldung bzgl. include-Anweisung in Zeile 4 aus
weather.php erscheinen, dann einfach diese Zeile auskommentieren oder
die neueste Version aus dem CVS holen.
Martin
