FHEM => fhem-users => Thema gestartet von: Zwiebel am 29 November 2009, 15:27:22
Titel: [FHZ] FHZ 1000 PC disconnect
Beitrag von: Zwiebel am 29 November 2009, 15:27:22
I'm new with the FHZ stuff with FHEM.
I just installed it an run
perl /usr/local/bin/fhem.pl /var/log/fhem/fhem.cfg
do a telnet to localhost 7072
FHZ> list
Type list for detailed info.
_internal_:
  global               ()
FHEMWEB:
  WEB                  (Initialized)
FileLog:
  Logfile              (active)
When executing
define FHZ1 FHZ /dev/ttyUSB0
FHZ> define FHZ1 FHZ /dev/ttyUSB0
Connection closed by foreign host.
it disconnects??
dmesg output
[ 3778.002480] usb 4-1: new full speed USB device using uhci_hcd and
address 4
[ 3778.185863] usb 4-1: configuration #1 chosen from 1 choice
[ 3778.186933] ftdi_sio 4-1:1.0: FTDI USB Serial Device converter
detected
[ 3778.186933] ftdi_sio: Detected FT8U232AM
[ 3778.186933] usb 4-1: FTDI USB Serial Device converter now attached
to ttyUSB0
[ 3778.200766] usb 4-1: New USB device found, idVendor=0403,
idProduct=f06f
[ 3778.200766] usb 4-1: New USB device strings: Mfr=1, Product=2,
SerialNumber=3
[ 3778.200766] usb 4-1: Product: ELV FHZ 1000 PC
[ 3778.200766] usb 4-1: Manufacturer: ELV AG
[ 3778.200766] usb 4-1: SerialNumber: ELW9626M
any idea what goes wrong??
regards Richard
You received this message because you are subscribed to the Google Groups "FHEM users" group.
To post to this group, send email to fhem-users@googlegroups.com.
To unsubscribe from this group, send email to fhem-users+unsubscribe@googlegroups.com.
For more options, visit this group at http://groups.google.com/group/fhem-users?hl=en.
Titel: Re: [FHZ] FHZ 1000 PC disconnect
Beitrag von: rudolfkoenig am 29 November 2009, 16:22:50
After opening the device fhem sends an initialization string to the FHZ. It is
possible that the firmware reboots after receiving this string. Could you add
some "Log" entries to the FHZ_DoInit function in 00_FHEM.pm, and/or replace the
init2 string in this function with init3 or init1? I never really understood
the difference between these init strings...
Regards,
  Rudi
