der vor kurzem angelegte HomeMatic-Zweig (bestehend aus einem Cunx von busware + Fenstergriffsensor)
Macht mit folgenden Meldungen das System-Log voll:
2016.07.30 18:40:17 3: CUN1: Unknown code A0B4DA001206EA73CCB73010E::-58:CUN1, help me!
2016.07.30 18:40:17 3: CUN1: Unknown code A0E4DA4103CCB73206EA70601340044::-82.5:CUN1, help me!
2016.07.30 18:40:17 3: CUN1: Unknown code A0A4D8002206EA73CCB7300::-58:CUN1, help me!
2016.07.30 18:40:17 3: CUN1: Unknown code A0B09A001206EA720B099010E::-58:CUN1, help me!
2016.07.30 18:40:18 3: CUN1: Unknown code A0E09A41020B099206EA70601000048::-84.5:CUN1, help me!
2016.07.30 18:40:18 3: CUN1: Unknown code A0A098002206EA720B09900::-58.5:CUN1, help me!
2016.07.30 18:40:18 3: CUN1: Unknown code A0B63A001206EA7257C67010E::-58:CUN1, help me!
2016.07.30 18:40:18 3: CUN1: Unknown code A0E63A410257C67206EA7060114003E::-77:CUN1, help me!
2016.07.30 18:40:18 3: CUN1: Unknown code A0A638002206EA7257C6700::-58:CUN1, help me!
2016.07.30 18:40:18 3: CUN1: Unknown code A0B63A001206EA73CCB71010E::-58:CUN1, help me!
2016.07.30 18:40:18 3: CUN1: Unknown code A0E63A4103CCB71206EA70601140041::-79.5:CUN1, help me!
2016.07.30 18:40:18 3: CUN1: Unknown code A0A638002206EA73CCB7100::-58.5:CUN1, help me!
2016.07.30 18:40:18 3: CUN1: Unknown code A0B40A001206EA720B092010E::-58:CUN1, help me!
2016.07.30 18:40:18 3: CUN1: Unknown code A0E40A41020B092206EA70601C8003E::-70:CUN1, help me!
2016.07.30 18:40:19 3: CUN1: Unknown code A0A408002206EA720B09200::-58.5:CUN1, help me!
2016.07.30 18:41:04 3: CUN1: Unknown code A0C5B867019CB7400000000DC46::-75.5:CUN1, help me!
2016.07.30 18:41:48 3: CUN1: Unknown code A0A8C8002206EA7339C9500::-57:CUN1, help me!
2016.07.30 18:43:33 3: CUN1: Unknown code A0C5C867019CB7400000000DC46::-75.5:CUN1, help me!
2016.07.30 18:45:14 3: CUN1: Unknown code A0B5DA001206EA73CCB9B010E::-57.5:CUN1, help me!
2016.07.30 18:45:14 3: CUN1: Unknown code A0E5DA4103CCB9B206EA70601000045::-97:CUN1, help me!
2016.07.30 18:45:15 3: CUN1: Unknown code A0A5D8002206EA73CCB9B00::-57.5:CUN1, help me!
2016.07.30 18:45:15 3: CUN1: Unknown code A0B4EA001206EA73CCB73010E::-57.5:CUN1, help me!
2016.07.30 18:45:15 3: CUN1: Unknown code A0E4EA4103CCB73206EA70601340044::-83:CUN1, help me!
2016.07.30 18:45:15 3: CUN1: Unknown code A0A4E8002206EA73CCB7300::-57.5:CUN1, help me!
2016.07.30 18:45:15 3: CUN1: Unknown code A0B0AA001206EA720B099010E::-57.5:CUN1, help me!
2016.07.30 18:45:16 3: CUN1: Unknown code A0E0AA41020B099206EA70601000048::-86:CUN1, help me!
2016.07.30 18:45:16 3: CUN1: Unknown code A0A0A8002206EA720B09900::-57.5:CUN1, help me!
2016.07.30 18:45:16 3: CUN1: Unknown code A0B64A001206EA7257C67010E::-57.5:CUN1, help me!
2016.07.30 18:45:16 3: CUN1: Unknown code A0E64A410257C67206EA7060114003F::-77.5:CUN1, help me!
2016.07.30 18:45:16 3: CUN1: Unknown code A0A648002206EA7257C6700::-57.5:CUN1, help me!
2016.07.30 18:45:17 3: CUN1: Unknown code A0B64A001206EA73CCB71010E::-58:CUN1, help me!
2016.07.30 18:45:17 3: CUN1: Unknown code A0E64A4103CCB71206EA70601140042::-79.5:CUN1, help me!
2016.07.30 18:45:18 3: CUN1: Unknown code A0A648002206EA73CCB7100::-58.5:CUN1, help me!
2016.07.30 18:45:18 3: CUN1: Unknown code A0B41A001206EA720B092010E::-58:CUN1, help me!
2016.07.30 18:45:18 3: CUN1: Unknown code A0E41A41020B092206EA70601C8003D::-70:CUN1, help me!
2016.07.30 18:45:18 3: CUN1: Unknown code A0A418002206EA720B09200::-58:CUN1, help me!
2016.07.30 18:45:48 3: CUN1: Unknown code A0C5D867019CB7400000000DC46::-75.5:CUN1, help me!
2016.07.30 18:47:49 3: CUN1: Unknown code A0C5E867019CB7400000000DC46::-75.5:CUN1, help me!
So geht das immer weiter.
Hier das Listing des Sensors:
DEF 2C37F7
IODev CUN1
NAME WC.Fenster
NR 126
NTFY_ORDER 50-WC.Fenster
STATE closed
TYPE CUL_HM
Readings:
2016-07-29 22:02:07 Activity alive
2016-07-28 22:46:34 CommandAccepted yes
2016-07-28 22:46:33 D-firmware 2.4
2016-07-28 22:46:33 D-serialNr LEQ0889568
2016-07-28 22:46:33 R-pairCentral set_0x47A11B
2016-07-28 22:51:29 alive yes
2016-07-29 19:43:46 battery ok
2016-07-29 19:43:46 contact closed (to CUN1)
2016-07-28 22:51:29 cover closed
2016-07-28 22:51:29 recentStateType info
2016-07-29 19:43:46 state closed
2016-07-29 19:43:46 trigDst_47A11B noConfig
2016-07-29 19:43:46 trigger_cnt 23
Helper:
HM_CMDNR 1
mId 0030
rxType 4
Expert:
def 1
det 0
raw 1
tpl 0
Io:
newChn +2C37F7,00,00,00
prefIO
rxt 0
vccu
p:
2C37F7
00
00
00
Mrssi:
mNo
Prt:
bErr 0
sProc 0
Q:
qReqConf 00
qReqStat
Role:
chn 1
dev 1
IODev CUN1
actCycle 028:00
actStatus alive
autoReadReg 4_reqStatus
expert 2_raw
firmware 2.4
icon fts_window_1w_open
model HM-SEC-RHS
room GaesteWC,CUL_HM
serialNr LEQ0889568
subType threeStateSensor
Hier das Listing vom CUNx:
CMDS BbCFikApZGMKUYRTVWXefmltuxEz
CUN1_MSGCNT 5424
CUN1_TIME 2016-07-30 18:47:49
Clients :CUL_HM:HMS:CUL_IR:STACKABLE_CC:
DEF 192.168.178.66:2323 0000
DeviceName 192.168.178.66:2323
FD 48
FHTID 0000
NAME CUN1
NR 123
PARTIAL
RAWMSG A0C5E867019CB7400000000DC46FD
RSSI -75.5
STATE Initialized
TYPE CUL
VERSION V 2.66 CUL868
initString X21
Ar
Matchlist:
1:CUL_HM ^A....................
8:HMS ^810e04....(1|5|9).a001
D:CUL_IR ^I............
H:STACKABLE_CC ^\*
Readings:
2016-07-29 22:02:06 cmds B b C F i k A p Z G M K U Y R T V W X e f m l t u x E z
2016-07-30 18:47:49 state Initialized
2016-07-29 18:42:40 uptime 0 00:03:28
2016-07-27 22:43:01 version V 2.66 CUL868
hmId 47A11B
icon cul_868
rfmode HomeMatic
room CUL_HM
Hat jemand eine Ahnung, was hier schief geht?
Markus
Ist doch alles i.O.
du siehst alle Funknachrichten von Homematic an deinem Cunx die er empfangt und nicht in Fhem als device vorhanden sind.
da du keine vccu eingerichtet hast....
damit kann man diese Unknown code A... verwalten
Guten Morgen Hary,
danke für den Tipp mit der VCCU!
Ich wusste, ich hatte etwas vergessen. ;)
Ich versuch' gleich mal eine einzurichten.
Markus
Hallo nochmal,
ich habe mir jetzt eine VCCU eingerichtet.
Die kommunikation mit dem Fenstergriffsensor funktioniert weiterhin.
Muss ich jetzt noch etwas konfigurieren oder hält mir die VCCU die
Unknown code A0E43A410257C67206EA7060 ....jetzt automatisch vom Leib?
Markus
So ist es
Cool 8)
Moin Markus,
ist der Griffsensor denn überhaupt schon richtig gepairt?
Zitat2016-07-28 22:46:33 R-pairCentral set_0x47A11B
Andreas
Zitat von: Vize am 02 August 2016, 08:56:06
Moin Markus,
Andreas
Hallo Andreas,
ja, ich denke schon.
Warum?
Falls es Unstimmigkeiten mit der hmID gibt, die habe ich in meioem Posting geändert.
Markus
Ich meine, weil in deinem list (bzw. meinem Zitat) noch ein set_ vor der ID steht, und das heißt doch, dass noch nicht "fertig" gepairt wurde, oder?
Andreas
Oh,
da bin ich jetzt überfragt.
Meine HomeMatic-Erfahrung ist erst ein paar Tage alt und der Griffsensor, außer dem CUNx das einzige HomeMatic-Device.
FHEM zeigt mir jedenfalls alle drei Zustände "open", "closed" und "tiltet" an, wenn ich den Griff entsprechend betätige.
Was hat die unfertige Paarung (ist das jetzt ein coitus interruptus? scnr ;D) denn für Konsequenzen?
Markus
Hallo Markus,
die Konsequenz ist in der Regel, dass Du zwar vom Gerät empfangen, es aber nicht steuern kannst. Das ist in deinem Fall ja auch nicht vorgesehen.
Das set_ bedeutet, FHEM hat die Config zum Gerät gesendet aber noch keine Bestätigung erhalten. Du solltest also nochmal kurz die Anlerntaste drücken, damit wird die Datenübertragung eingeleitet und eventuell auch abgeschlossen.
