FHEM - Hausautomations-Systeme => Unterstützende Dienste => Wettermodule => Thema gestartet von: BerHa am 05 September 2016, 18:21:03
Titel: [Gelöst]: 77_UWZ.pm Fehlermeldung seit letztem Update
Beitrag von: BerHa am 05 September 2016, 18:21:03
seit dem letzten Update von FHEM (Linux ist ebenfalls aktuell) bekomme ich immer folgende Fehlermeldungen und mein schönes 77_UWZ.pm tut es nicht mehr. Jemand eine Idee?
PERL WARNING: Argument "" isn't numeric in numeric ne (!=) at ./FHEM/77_UWZ.pm line 987
reload: Error:Modul 77_UWZ deactivated:
Can't locate XML/Simple.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.14.2 /usr/local/share/perl/5.14.2 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.14 /usr/share/perl/5.14 /usr/local/lib/site_perl . ./FHEM) at ./FHEM/77_UWZ.pm line 1290, <$fh> line 557.
BEGIN failed--compilation aborted at ./FHEM/77_UWZ.pm line 1290, <$fh> line 557.
2016.09.05 18:14:00 1: PERL WARNING: Argument "" isn't numeric in numeric ne (!=) at ./FHEM/77_UWZ.pm line 987.
2016.09.05 18:14:11 0: Server shutdown
2016.09.05 18:14:16 1: Including fhem.cfg
2016.09.05 18:14:16 3: telnetPort: port 7072 opened
2016.09.05 18:14:17 3: WEB: port 8083 opened
2016.09.05 18:14:21 2: eventTypes: loaded 1166 events from ./log/eventTypes.txt
2016.09.05 18:14:22 1: HMLAN_Parse: hmusbcfg new condition disconnected
2016.09.05 18:14:22 3: Opening hmusbcfg device 127.0.0.1:1234
2016.09.05 18:14:22 1: HMLAN_Parse: hmusbcfg new condition init
2016.09.05 18:14:22 3: hmusbcfg device opened
2016.09.05 18:14:24 1: reload: Error:Modul 77_UWZ deactivated:
2016.09.05 18:14:24 0: Can't locate XML/Simple.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.14.2 /usr/local/share/perl/5.14.2 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.14 /usr/share/perl/5.14 /usr/local/lib/site_perl . ./FHEM) at ./FHEM/77_UWZ.pm line 1290, <$fh> line 557.
2016.09.05 18:14:24 3: TABLETUI: new ext defined infix:ftui/: dir:./www/tablet:
2016.09.05 18:14:24 3: Registering HTTPSRV TABLETUI for URL /ftui   and assigned link ftui/ ...
2016.09.05 18:14:24 1: Including ./log/fhem.save
Die Datei 77_UWZ.pm hat die aktuelle Version, und die Dateirechte sind ebenfalls richtig gesetzt.
Eine Suche im Forum und über die Suchmaschine hat leider auch nicht geholfen.
Danke im Voraus
Titel: Antw:77_UWZ.pm Fehlermeldung seit letztem Update
Beitrag von: DeeSPe am 05 September 2016, 18:55:19
Das Perl Modul XML Simple fehlt offensichtlich.
Dan
Beitrag von: CoolTux am 05 September 2016, 19:52:29
Wie bereits erwähnt fehlt Dir das Modul XML Simple. Bitte einmal nachinstallieren.
Beitrag von: BerHa am 05 September 2016, 23:03:55
ich Doofi, mit dem Nachinstallieren da hätte ich auch drauf kommen können. Ich weiß gar nicht, warum ich das Paket nicht installiert habe / es irgendwie "verloren" gegangen ist.
Nachinstalliert und die ersten Fehler sind weg.
Jetzt bleibt "nur noch": 2016.09.05 22:52:15 1: PERL WARNING: Argument "" isn't numeric in numeric ne (!=) at ./FHEM/77_UWZ.pm line 987.
Hat dazu noch jemand eine Idee?
Danke im Voraus.
Beitrag von: DeeSPe am 05 September 2016, 23:07:23
Das wird Dir wohl nur der Modulentwickler selber beantworten können.
Genau diesen Fehler habe ich auch in einem anderen Modul.
Dan
Beitrag von: BerHa am 05 September 2016, 23:15:11
das Problem hat sich in Luft aufgelöst. sudo service fhem stop und start hat nicht gereicht. "shutdown restart" auch nicht. Kann ich mir auch alles nicht erklären, aber nach einem reboot kommt der Fehler jetzt nicht mehr.
Sollte also gelöst sein. Vielen Dank für die Hilfe! Einfach super!
Titel: Antw:[Gelöst]: 77_UWZ.pm Fehlermeldung seit letztem Update
Beitrag von: CoolTux am 06 September 2016, 07:59:46
Ich schaue mir die Zeile im laufe des Vormittags mal an. Denke aber nicht das es ein Fehler im Modul ist.
Beitrag von: CoolTux am 07 September 2016, 09:35:08
Ok ich konnte das Problem logisch nachvollziehen. Werde ein Patch bei Tobias einreichen.
