Hallo
Ich habe zwei CUL an meinem Raspi und bis ich heute den TPUART USB Modul für KNX installiert habe lief Homematic CUL_HM pair: HM_4BE700 THSensor, model HM-WDS40-TH-I-2 serialNr auch wunderbar. Jetzt meldet sich dieser als dead.
hier mal das log:
2016.09.19 12:17:05 3: telnetPort: port 7072 opened
2016.09.19 12:17:06 3: WEB: port 8083 opened
2016.09.19 12:17:06 3: WEBphone: port 8084 opened
2016.09.19 12:17:06 3: WEBtablet: port 8085 opened
2016.09.19 12:17:06 2: eventTypes: loaded 0 events from ./log/eventTypes.txt
2016.09.19 12:17:06 3: Opening CUL_0 device /dev/ttyACM0
2016.09.19 12:17:06 3: Setting CUL_0 serial parameters to 9600,8,N,1
2016.09.19 12:17:06 3: CUL_0: Possible commands: BbCFiAZNkGMKUYRTVWXefmLltux
2016.09.19 12:17:06 3: CUL_0 device opened
2016.09.19 12:17:06 2: Switched CUL_0 rfmode to HomeMatic
2016.09.19 12:17:08 1: Including ./log/fhem.save
2016.09.19 12:17:08 3: Device HM_4BE700 added to ActionDetector with 001:00 time
2016.09.19 12:17:08 1: usb create starting
2016.09.19 12:17:08 3: Probing CUL device /dev/ttyAMA0
2016.09.19 12:17:08 3: Probing TCM_ESP3 device /dev/ttyAMA0
2016.09.19 12:17:08 3: Probing FRM device /dev/ttyAMA0
2016.09.19 12:17:14 1: usb create end
2016.09.19 12:17:14 2: SecurityCheck: WEB,WEBphone,WEBtablet has no associated allowed device with basicAuth. telnetPort has no associated allowed device with password/globalpassword. Restart FHEM for a new check if the problem is fixed, or set the global attribute motd to none to supress this message.
2016.09.19 12:17:14 0: Featurelevel: 5.7
2016.09.19 12:17:14 0: Server started with 13 defined entities (fhem.pl:12095/2016-08-30 perl:5.020002 os:linux user:fhem pid:444)
2016.09.19 12:17:41 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2016.09.19 12:20:31 3: Setting CUL_0 serial parameters to 9600,8,N,1
2016.09.19 12:20:31 3: CUL_0: Possible commands: BbCFiAZNkGMKUYRTVWXefmLltux
2016.09.19 12:20:31 1: /dev/ttyACM0 reappeared (CUL_0)
2016.09.19 14:35:12 0: Server shutdown
2016.09.19 14:35:16 1: Including fhem.cfg
2016.09.19 14:35:16 3: telnetPort: port 7072 opened
2016.09.19 14:35:16 3: WEB: port 8083 opened
2016.09.19 14:35:16 3: WEBphone: port 8084 opened
2016.09.19 14:35:16 3: WEBtablet: port 8085 opened
2016.09.19 14:35:16 2: eventTypes: loaded 13 events from ./log/eventTypes.txt
2016.09.19 14:35:17 3: Opening CUL_0 device /dev/ttyACM0
2016.09.19 14:35:17 3: Setting CUL_0 serial parameters to 9600,8,N,1
2016.09.19 14:35:26 1: Cannot init /dev/ttyACM0, ignoring it (CUL_0)
2016.09.19 14:35:26 2: Switched CUL_0 rfmode to HomeMatic
2016.09.19 14:35:28 1: Including ./log/fhem.save
2016.09.19 14:35:28 3: Device HM_4BE700 added to ActionDetector with 001:00 time
2016.09.19 14:35:28 1: usb create starting
2016.09.19 14:35:28 3: Probing CUL device /dev/ttyACM1
2016.09.19 14:35:28 1: define CUL_1 CUL /dev/ttyACM1@9600 1134
2016.09.19 14:35:28 3: Opening CUL_1 device /dev/ttyACM1
2016.09.19 14:35:28 3: Setting CUL_1 serial parameters to 9600,8,N,1
2016.09.19 14:35:28 3: CUL_1: Possible commands: BbCFiAZNkGMKUYRTVWXefmLltux
2016.09.19 14:35:28 2: Setting CUL fhtid from 1034 to 1134
2016.09.19 14:35:28 3: CUL_1 device opened
2016.09.19 14:35:28 3: Probing CUL device /dev/ttyAMA0
2016.09.19 14:35:28 3: Can't open /dev/ttyAMA0: Permission denied
2016.09.19 14:35:28 1: usb create end
2016.09.19 14:35:28 2: SecurityCheck: WEB,WEBphone,WEBtablet has no associated allowed device with basicAuth. telnetPort has no associated allowed device with password/globalpassword. Restart FHEM for a new check if the problem is fixed, or set the global attribute motd to none to supress this message.
2016.09.19 14:35:28 0: Featurelevel: 5.7
2016.09.19 14:35:28 0: Server started with 14 defined entities (fhem.pl:12095/2016-08-30 perl:5.020002 os:linux user:fhem pid:481)
2016.09.19 14:40:02 0: Using EIB is deprecated. Please migrate to KNX soon. Module 10_EIB is not maintained any longer. If you still want to use the module EIB,
please set the attribute useEIB to 1 within the tul-device. Please keep in mind, that 10_KNX has a changed syntax regarding the definition, arguments and readings. Please refer to the commandref.
As well 10_EIB and 10_KNX are compatible to daemon eibd and knxd.
2016.09.19 14:40:02 3: TUL opening EIB device tul:/dev/ttyACM0@57600
2016.09.19 14:40:02 3: TUL setting EIB baudrate to 57600
2016.09.19 14:40:02 3: TUL device opened
wer kann mir da bitte einen Tipp geben.
Ich bedanke mich schon mal jetzt für Eure Mühe
Lars
