Hallo an An Alle,
nach erneuter Installation von FHEM (Archlinux, fhem-5.7) mit anschließendem update all, scheint fhem nur noch auf systemctl stop|start fhem.service zu reagieren. Öffne oder schließe ich einen erkannten Fensterkontakt erscheint keine Reaktion im Log-File.
Was mir wohl aufgefallen ist, dass fhem in mehr oder weniger regelmäßigen Abständen disconnectet. Hier ein Auszug aus der heutigen Log-Datei
cat /opt/fhem-5.7/log/fhem-2016-09-28.log | grep disconnected > fhem.log.xxx
[guenter@fhempi:~]$ cat fhem.log.xxx | more
2016.09.28 02:32:42 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2016.09.28 02:33:02 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2016.09.28 03:32:45 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2016.09.28 03:33:05 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2016.09.28 04:32:48 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2016.09.28 04:33:08 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2016.09.28 05:32:51 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2016.09.28 05:33:11 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2016.09.28 08:32:54 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2016.09.28 08:33:14 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2016.09.28 09:32:57 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2016.09.28 09:33:17 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2016.09.28 10:33:00 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2016.09.28 10:33:15 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2016.09.28 11:08:27 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2016.09.28 12:08:21 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2016.09.28 12:08:37 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2016.09.28 14:08:24 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2016.09.28 14:08:32 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2016.09.28 14:08:47 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2016.09.28 14:08:58 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2016.09.28 14:56:09 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
[guenter@fhempi:~]$
Während ich diesen Text schrieb hat sich folgendes im Log niedergeschlagen
2016.09.28 14:56:09 3: Setting CUL_0 serial parameters to 9600,8,N,1
2016.09.28 14:56:09 3: CUL_0: Possible commands: BCFiAZEGMRTVWXefmltux
2016.09.28 14:56:09 1: /dev/ttyACM0 reappeared (CUL_0)
2016.09.28 15:08:27 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2016.09.28 15:08:27 1: Error in CUL_MAX_SendQueueHandler: CUL CUL_0 did not answer request for current credits. Waiting 5 seconds.
2016.09.28 15:08:29 1: Error in CUL_MAX_SendQueueHandler: CUL CUL_0 did not answer request for current credits. Waiting 5 seconds.
2016.09.28 15:08:34 3: Setting CUL_0 serial parameters to 9600,8,N,1
2016.09.28 15:08:34 2: CUL_0: unknown message 6001244
2016.09.28 15:08:34 3: CUL_MAX_Parse: Re-Pairing device 0d43a9 of type WallMountedThermostat with serial KEQ0947104
2016.09.28 15:08:34 3: CUL_0: Possible commands: BCFiAZEGMRTVWXefmltux
2016.09.28 15:08:34 1: /dev/ttyACM0 reappeared (CUL_0)
2016.09.28 15:08:43 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2016.09.28 15:08:43 1: Error in CUL_MAX_SendQueueHandler: CUL CUL_0 did not answer request for current credits. Waiting 5 seconds.
2016.09.28 15:08:45 1: Error in CUL_MAX_SendQueueHandler: CUL CUL_0 did not answer request for current credits. Waiting 5 seconds.
2016.09.28 15:08:47 3: Setting CUL_0 serial parameters to 9600,8,N,1
2016.09.28 15:08:47 2: CUL_0: unknown message 21 794
2016.09.28 15:08:47 3: CUL_0: Possible commands: BCFiAZEGMRTVWXefmltux
2016.09.28 15:08:47 1: /dev/ttyACM0 reappeared (CUL_0)
2016.09.28 15:09:00 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL_0)
2016.09.28 15:09:00 1: Error in CUL_MAX_SendQueueHandler: CUL CUL_0 did not answer request for current credits. Waiting 5 seconds.
2016.09.28 15:09:02 1: Error in CUL_MAX_SendQueueHandler: CUL CUL_0 did not answer request for current credits. Waiting 5 seconds.
2016.09.28 15:09:07 3: Setting CUL_0 serial parameters to 9600,8,N,1
2016.09.28 15:09:07 1: Device MAX_0d43a9 answered with: Invalid command/argument
2016.09.28 15:09:07 2: CUL_0: unknown message 21 701
2016.09.28 15:09:07 3: CUL_0: Possible commands: BCFiAZEGMRTVWXefmltux
2016.09.28 15:09:07 1: /dev/ttyACM0 reappeared (CUL_0)
2016.09.28 15:09:08 2: Got message for undefined device 0caae3, and failed to guess type from msg 'Ack' - ignoring
2016.09.28 15:11:42 2: Got message for undefined device 08feef, and failed to guess type from msg 'Ack' - ignoring
2016.09.28 15:12:02 2: Got message for undefined device 0caae3, and failed to guess type from msg 'Ack' - ignoring
2016.09.28 15:14:51 2: Got message for undefined device 0caae3, and failed to guess type from msg 'Ack' - ignoring
Ist das normal ?
Kann mich jemand aufklären?
Danke für Eure Hilfe und Tipps.
Bis dann ...
MfG
Günter
