FHEM => fhem-users => Thema gestartet von: Guest am 21 Juni 2010, 20:33:13
Titel: Encrypted connection
Beitrag von: Guest am 21 Juni 2010, 20:33:13
would it be possible to access FHEM over a password protected SSL
connection? this would make it possible to open a public port for FHEM,
and have a native iphone app. i rather liked that from the homematic
system.
and i am taking my first steps into developing iphone apps
Remco
Sie haben diese Nachricht erhalten, da Sie der Google Groups-Gruppe FHEM users beigetreten sind.
Wenn Sie Nachrichten in dieser Gruppe posten möchten, senden Sie eine E-Mail an fhem-users@googlegroups.com.
Wenn Sie aus dieser Gruppe austreten möchten, senden Sie eine E-Mail an fhem-users+unsubscribe@googlegroups.com.
Besuchen Sie die Gruppe unter http://groups.google.com/group/fhem-users?hl=de, um weitere Optionen zu erhalten.
Titel: Re: Encrypted connection
Beitrag von: Guest am 22 Juni 2010, 21:36:49
Hi Remco,
you can use mod_ssl from Apache web server as reverse proxy
for accessing the web-frontends for example or an OpenSSL
tunnel for the fhem port 7072.
In Apache you define a virtual host for the SSL access over https.
ProxyPass               /fhem http://localhost:8083/fhem
ProxyPassReverse  /fhem http://localhost:8083/fhem
Gerald
On 21 Jun., 20:33, Remco wrote:
> Hi,
> system.
> Remco
Titel: Re: Re: Encrypted connection
Beitrag von: rudolfkoenig am 23 Juni 2010, 08:28:06
> system.
Of course it is possible, it is only a question of the effort you want to
invest :)
On the fhem side I would suggest a simplified copy of the 01_FHEMWEB module,
but instead of using IO::Socket::INET you probably have to use
Net::SSLeay::Handle. Note: I do not have any experience with this module.
After receiving some unencrypted data, the module should create a %client
entry like it is done after $server->accept() in fhem.pl, fill
$client{$c}{buffer}, and call AnalyzeInput($c).
I can imagine that netcat could be useful for testing the fhem side, as it can
translate between SSL and a terminal.
On the iPhone side you will probably use NSURLConnection, which according to
some blogs has even support for handling self-signed certificates.
Keep me informed: as I have some experience on both areas, I will try to help
you if time permits.
