98_Hyperion: config only available if at least two files are found and other code improvements
98_Hyperion: config only available if at least two files are found and other code improvementsView Changes
Source: 98_Hyperion: config only available if at least two files are found and other code improvements (https://sourceforge.net/p/fhem/code/12287/)
