habe gerade ein weiteres HM-Wandthermostat (HM-TC-IT-WM-W-EU) gepaired.
Hauptsystem mit HM-CFG-USB, PI 2B und vccu...
EDIT: hier noch die fhem Version(en):
Latest Revision: 12225
File Rev Last Change
fhem.pl 12192 2016-09-22 07:44:52Z rudolfkoenig
90_at.pm 12028 2016-08-21 12:08:28Z rudolfkoenig
98_autocreate.pm 11984 2016-08-19 12:47:50Z rudolfkoenig
10_CUL_HM.pm 12138 2016-09-11 15:21:08Z martinp876
98_dewpoint.pm 6757 2014-10-12 18:58:57Z joachim09876
98_dummy.pm 11984 2016-08-19 12:47:50Z rudolfkoenig
91_eventTypes.pm 11984 2016-08-19 12:47:50Z rudolfkoenig
01_FHEMWEB.pm 12007 2016-08-20 09:50:51Z rudolfkoenig
92_FileLog.pm 12193 2016-09-22 19:17:26Z rudolfkoenig
98_HMinfo.pm 12138 2016-09-11 15:21:08Z martinp876
00_HMLAN.pm 12138 2016-09-11 15:21:08Z martinp876
98_HTTPMOD.pm 12220 2016-09-29 18:25:09Z ststrobel
91_notify.pm 11984 2016-08-19 12:47:50Z rudolfkoenig
No Id found for 99_perfmon.pm
33_readingsGroup.pm 12137 2016-09-11 14:45:55Z justme1968
99_SUNRISE_EL.pm 11984 2016-08-19 12:47:50Z rudolfkoenig
98_SVG.pm 11984 2016-08-19 12:47:50Z rudolfkoenig
50_TelegramBot.pm 11714 2016-06-25 14:45:00Z viegener
99_Utils.pm 11984 2016-08-19 12:47:50Z rudolfkoenig
98_version.pm 11987 2016-08-19 17:13:41Z markusbloch
59_Weather.pm 11249 2016-04-16 17:03:47Z borisneubert
98_weblink.pm 11984 2016-08-19 12:47:50Z rudolfkoenig
Blocking.pm 11918 2016-08-07 16:51:00Z rudolfkoenig
DevIo.pm 11786 2016-07-12 08:44:10Z rudolfkoenig
HMConfig.pm 12083 2016-08-28 06:10:21Z martinp876
HttpUtils.pm 12174 2016-09-19 05:53:59Z rudolfkoenig
RTypes.pm 10476 2016-01-12 21:03:33Z borisneubert
SetExtensions.pm 11513 2016-05-24 17:56:05Z rudolfkoenig
TcpServerUtils.pm 11908 2016-08-06 15:09:55Z rudolfkoenig
YahooWeatherAPI.pm 11249 2016-04-16 17:03:47Z borisneubert
Device und Pairing(ergebnis) sieht gut aus.
Hier das List des Device:
CFGFN
DEF 453732
IODev hmusb
LASTInputDev hmusb
MSGCNT 149
NAME Wandthermostat_EssZi2
NOTIFYDEV global
NR 1114
STATE CMDs_done
TYPE CUL_HM
channel_01 Wandthermostat_EssZi2_Weather
channel_02 Wandthermostat_EssZi2_Climate
channel_03 Wandthermostat_EssZi2_WindowRec
channel_06 Wandthermostat_EssZi2_remote
channel_07 Wandthermostat_EssZi2_SwitchTr
hmusb_MSGCNT 149
hmusb_RAWMSG E453732,0000,4DC77206,FF,FFCB,09847045373200000000DA35
hmusb_RSSI -53
hmusb_TIME 2016-10-10 22:25:25
lastMsg No:09 - t:70 s:453732 d:000000 00DA35
protLastRcv 2016-10-10 22:25:25
protResnd 1 last_at:2016-10-10 22:08:53
protSnd 120 last_at:2016-10-10 22:09:16
protState CMDs_done
rssi_at_hmusb avg:-52.83 min:-55 max:-51 lst:-53 cnt:149
Readings:
2016-10-10 22:08:34 Activity alive
2016-10-10 22:08:59 CommandAccepted yes
2016-10-10 22:08:29 D-firmware 1.3
2016-10-10 22:08:29 D-serialNr NEQ0122536
2016-10-10 22:08:59 PairedTo 0xAFFE11
2016-10-10 22:08:34 R-btnLock off
2016-10-10 22:08:34 R-burstRx on
2016-10-10 22:08:34 R-cyclicInfoMsg on
2016-10-10 22:08:34 R-cyclicInfoMsgDis 0
2016-10-10 22:08:34 R-globalBtnLock off
2016-10-10 22:08:34 R-localResDis off
2016-10-10 22:08:34 R-lowBatLimitRT 2.2 V
2016-10-10 22:08:34 R-modusBtnLock off
2016-10-10 22:08:34 R-pairCentral 0xAFFE11
2016-10-10 22:15:02 battery ok
2016-10-10 22:15:02 batteryLevel 2.8
2016-10-10 22:15:02 desired-temp 17.0
2016-10-10 22:15:02 measured-temp 21.8
2016-10-10 22:09:17 state CMDs_done
2016-10-10 22:08:48 time-request -
Helper:
HM_CMDNR 9
cSnd 01AFFE114537320703,01AFFE1145373207040000000001
mId 00AD
rxType 6
Expert:
def 1
det 1
raw 0
tpl 0
Io:
newChn +453732,00,00,00
nextSend 1476131125.72114
prefIO
rxt 0
vccu
p:
453732
00
00
00
Mrssi:
mNo 09
Io:
hmusb -51
Prt:
awake 0
bErr 0
sProc 0
Rspwait:
Q:
qReqConf
qReqStat
Role:
dev 1
Rssi:
At_hmusb:
avg -52.8389261744966
cnt 149
lst -53
max -51
min -55
Shregw:
07 02
Shadowreg:
Tmpl:
IODev hmusb
IOgrp vccu:hmusb
actCycle 000:10
actStatus alive
autoReadReg 4_reqStatus
expert 1_allReg
firmware 1.3
model HM-TC-IT-WM-W-EU
msgRepeat 1
room Esszimmer 2
serialNr NEQ0122536
subType thermostat
webCmd getConfig:clear msgEvents
Allerdings sind mir im Log (mach ja immer eine Kontrolle) folgendes aufgefallen:
2016.10.10 22:08:18 3: CUL_HM set vccu hmPairForSec 60
2016.10.10 22:08:28 2: CUL_HM Unknown device HM_453732 is now defined
2016.10.10 22:08:28 2: autocreate: define HM_453732 CUL_HM 453732
2016.10.10 22:08:28 2: autocreate: define FileLog_HM_453732 FileLog ./log/HM_453732-%Y.log HM_453732
2016.10.10 22:08:29 3: Device HM_453732 added to ActionDetector with 000:10 time
2016.10.10 22:08:29 3: CUL_HM pair: HM_453732 thermostat, model HM-TC-IT-WM-W-EU serialNr
2016.10.10 22:08:29 1: my_SignalDeadDevice DeviceEvt: HM_453732: alive
2016.10.10 22:08:29 1: my_SignalDeadDevice Event: status_HM_453732: alive Device: HM_453732 State: alive
2016.10.10 22:08:33 3: CUL_HM set HM_453732 getConfig
2016.10.10 22:08:34 3: Device HM_453732 added to ActionDetector with 000:10 time
2016.10.10 22:08:47 1: my_StoreBatteryStatus ignoring Device: HM_453732
2016.10.10 22:08:52 3: YahooWeather: 0 result(s) retrieved
2016.10.10 22:08:58 3: CUL_HM set HM_453732 getConfig
2016.10.10 22:09:09 3: CUL_HM set Steckdose_FabiZi_SchreibTisch_Drucker_Sw statusRequest
2016.10.10 22:09:10 3: CUL_HM set Steckdose_FabiZi_SchreibTisch_RasPI_Sw statusRequest
2016.10.10 22:09:13 1: PERL WARNING: Use of uninitialized value in join or string at ./FHEM/10_CUL_HM.pm line 7997.
2016.10.10 22:09:13 3: stacktrace:
2016.10.10 22:09:13 3: main::__ANON__ called by ./FHEM/10_CUL_HM.pm (7997)
2016.10.10 22:09:13 3: main::CUL_HM_TCITRTtempReadings called by ./FHEM/10_CUL_HM.pm (7613)
2016.10.10 22:09:13 3: main::CUL_HM_updtRegDisp called by ./FHEM/10_CUL_HM.pm (3218)
2016.10.10 22:09:13 3: main::CUL_HM_parseCommon called by ./FHEM/10_CUL_HM.pm (1339)
2016.10.10 22:09:13 3: main::CUL_HM_Parse called by fhem.pl (3382)
2016.10.10 22:09:13 3: main::Dispatch called by ./FHEM/00_HMLAN.pm (777)
2016.10.10 22:09:13 3: main::HMLAN_Parse called by ./FHEM/00_HMLAN.pm (602)
2016.10.10 22:09:13 3: main::HMLAN_Read called by fhem.pl (3221)
2016.10.10 22:09:13 3: main::CallFn called by fhem.pl (671)
2016.10.10
EDIT2: (war schon mal drin ist irgendwie zers
Hmmm, wohl zu viel Input... ;-)
Dann hier der Rest:
EDIT2: (war schon mal drin ist irgendwie zerschossen worden)
Einige Erläuterungen zu Logeinträgen (die wie ich denke nichts mit dem Problem/Warning zu tun haben sollten)...
CUL_HM set Steckdose_FabiZi_SchreibTisch_Drucker_Sw statusRequest: bzw. ..._RasPI sind Steckdosenzwischenstecker, die über eine weitere Steckdose bei Bedarf eingeschaltet werden, daher nicht immer erreichbar sind...
my_StoreBatteryStatus ignoring Device: HM_453732: in der Funktion my_StoreBatteryStatus berechne und speichere ich Batteriezustände in einem dummy. Neu angelegte Geräte will ich da nicht speichern...
my_SignalDeadDevice DeviceEvt: HM_453732: alive: my_SignalDeadDevice wird über einen notify auf den ActionDetector getriggert dort asse ich mich dann u.a. benachrichtigen, wenn ein Gerät ausgefallen ist...
StackTrace war (zufällig) noch an, da ich vor einiger Zeit ein Problem analysiert habe...
Wie gesagt es sieht (für mich) so aus als wäre trotzdem alles ok.
Wollte es nur mal posten, vielleicht schlummert ja doch was...
Gruß, Joachim
