FHEM => fhem-users => Thema gestartet von: Guest am 23 Januar 2011, 09:31:13
Titel: FHEM unable to send commands + faulty startup script
Beitrag von: Guest am 23 Januar 2011, 09:31:13
Yesterday i installed FHEM on my guruplug (Debian squeeze on a MArvell
ARM cpu)  and somehow it's givving multiple strange things.
1) At boot time the startup scipt locks up the entire system because
it's not started in the background. It stays in the foreground and
causes my ssh server to not get started because its started after
FHEM.
( i partially fixed this by doing a "nohup" before and a "&" at the
end but it's not a decent way to do it).
2) When you execute "service fhem stop" and "service fhem start"  it
locks up the screen like the point mentioned above
3) I got the following error after a reboot:
011.01.23 09:09:20 2: FHEMWEB port 8083 opened
2011.01.23 09:09:20 2: FHEMWEB port 8084 opened
2011.01.23 09:09:20 3: No I/O device found for Thermostaat_Huiskamer
2011.01.23 09:09:21 3: No I/O device found for Salon_Tafel
2011.01.23 09:09:21 3: No I/O device found for LEDStrip_Bank
2011.01.23 09:09:21 3: No I/O device found for Koof
2011.01.23 09:09:21 3: No I/O device found for Thermostaat_Ernst
2011.01.23 09:09:21 3: No I/O device found for Thermostaat_Steffi
2011.01.23 09:09:21 3: No I/O device found for Kleine_Staande_Lamp
2011.01.23 09:09:21 3: CUL opening CUNO1 device 192.168.10.2:2323
2011.01.23 09:09:21 3: CUL device opened
2011.01.23 09:09:21 0: Server started
After looking in the fhem.cfg file i saw that the CUNO1 init line was
moved to the end of the config file.
moving it back to the beginning fixed the issue but overall strange
behaviour.
Would the designer take a look at the startup scripts ( i know i
will ) to see if there is a better way for starting up fhem in the
background.
Sie haben diese Nachricht erhalten, da Sie der Google Groups-Gruppe FHEM users beigetreten sind.
Wenn Sie Nachrichten in dieser Gruppe posten möchten, senden Sie eine E-Mail an fhem-users@googlegroups.com.
Wenn Sie aus dieser Gruppe austreten möchten, senden Sie eine E-Mail an fhem-users+unsubscribe@googlegroups.com.
Besuchen Sie die Gruppe unter http://groups.google.com/group/fhem-users?hl=de, um weitere Optionen zu erhalten.
