Guten Abend zusammen,
ich versuche mich gerade an FakeRoku. Leider gelingt es mir nichtmal über diese Meldung hinaus
Cannot load module fakeRoku
Diese beiden Befehle habe ich schon ausgeführt
sudo apt-get install -y libjson-perl
sudo apt-get install libio-socket-multicast-perl
Fehlt noch was?
was genau steht im fhem log?
2016.11.26 14:01:26 1: reload: Error:Modul 37_fakeRoku deactivated:
Can't locate XML/Simple.pm in @INC (you may need to install the XML::Simple module) (@INC contains: fhem.p/lib fhem.p/FHEM/lib ./FHEM/lib ./lib ./FHEM ./ /usr/local/FHEM/share/fhem/FHEM/lib . /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabihf/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl) at ./FHEM/37_fakeRoku.pm line 14.
BEGIN failed--compilation aborted at ./FHEM/37_fakeRoku.pm line 14.
2016.11.26 14:01:26 0: Can't locate XML/Simple.pm in @INC (you may need to install the XML::Simple module) (@INC contains: fhem.p/lib fhem.p/FHEM/lib ./FHEM/lib ./lib ./FHEM ./ /usr/local/FHEM/share/fhem/FHEM/lib . /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabihf/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl) at ./FHEM/37_fakeRoku.pm line 14.
2016.11.26 14:01:42 1: reload: Error:Modul 37_fakeRoku deactivated:
2016.11.26 14:01:42 0: Can't locate XML/Simple.pm in @INC (you may need to install the XML::Simple module) (@INC contains: fhem.p/lib fhem.p/FHEM/lib ./FHEM/lib ./lib ./FHEM ./ /usr/local/FHEM/share/fhem/FHEM/lib . /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabihf/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl) at ./FHEM/37_fakeRoku.pm line 14.
da steht es doch: XML bzw. XML::Simple fehlt
