FHEM => fhem-users => Thema gestartet von: Guest am 19 Februar 2011, 09:00:29
Titel: FHT Actuator opening too small?
Beitrag von: Guest am 19 Februar 2011, 09:00:29
Hi All,
I analyzed the heating data of my FHTś the last week and i see the
following which i cannot explain / change.
In the morning when the boiler turns on the Livingroom is 15 degrees
which will be heated up to 18 degrees.
At 15 degrees the actuator(s) are 0% open and when the boiler starts
heating it opens the actuator to about 15%. This stays around 15% and
it takes about an hour to get the room to the desired temperature.
If te actuator would be open (lets say) 80% the flow of water should
be better and the room would heat up more quickly.
Is there a way to change / modify this behaviour?
If i look in my office this behaviour is totally dirfferent. This
actuator wil directly open to 60% and drop back down to 0% is the
desired temp is reached.
Sie haben diese Nachricht erhalten, da Sie der Google Groups-Gruppe FHEM users beigetreten sind.
Wenn Sie Nachrichten in dieser Gruppe posten möchten, senden Sie eine E-Mail an fhem-users@googlegroups.com.
Wenn Sie aus dieser Gruppe austreten möchten, senden Sie eine E-Mail an fhem-users+unsubscribe@googlegroups.com.
Besuchen Sie die Gruppe unter http://groups.google.com/group/fhem-users?hl=de, um weitere Optionen zu erhalten.
Titel: Re: FHT Actuator opening too small?
Beitrag von: Guest am 19 Februar 2011, 17:43:33
Ernst,
Am 19.02.2011 09:00, schrieb Ernst Cozijnsen:
maybe the two FHT's have different firmware versions?
To heat up fast in the morning, I set the desired-temp via fhem to
30.5°C for about one hour and then back to 21°C.
-Manfred
Beitrag von: Guest am 20 Februar 2011, 08:06:13
Hi Manfred,
How can i see which revision level the FHT's have? and is it possible to
upgrade it?
The tweak of 30 --> 21 is just to simple ;-) but it works like a charm
thanks for that
Ernst
2011/2/19 Manfred Caspari
> Ernst,
> -Manfred
> erhalten.
Beitrag von: Guest am 20 Februar 2011, 14:45:31
Hi Ernst,
Am 20.02.2011 08:06, schrieb Ernst Cozijnsen:
> Hi Manfred,
it is shown when putting in the batteries. I have some with V2.2 from
Conrad & ELV, and my latest ones from Aldi show 3.1
> and is it possible to upgrade it?
The latest ones have a contact area inside the battery enclosure. That
could indicate the possibility to upgrade. I assume You would have to
send them to the manufacturer, if possible at all.
-Manfred
Beitrag von: Guest am 20 Februar 2011, 15:09:23
Hi Manfred,
I have mailed ELV with this question and i hope to have some answer is a few
day.
Iĺl keep you posted.
Ernst
On Sun, Feb 20, 2011 at 2:45 PM, Manfred Caspari wrote:
> Hi Ernst,
> > Hi Manfred,
> -Manfred
> erhalten.
Beitrag von: Zrrronggg! am 20 Februar 2011, 22:34:47
If you have at least 2 actuators paired with the FHT80b, you can try
to use the offset function to open them further.
On 20 Feb., 15:09, Ernst Cozijnsen wrote:
> Hi Manfred,
> day.
> Ernst
> > Hi Ernst,
> > > Hi Manfred,
> > -Manfred
> > erhalten.
Beitrag von: Guest am 21 Februar 2011, 11:21:29
I got a reply from ELV today:
Sehr geehrter Herr Cozijnsen,
ein Upgrade von FS 20 auf FHT ist leider nicht möglich.
Mit freundlichen Grüßen aus Leer
ELV Elektronik AG
Very short but this is it.
On Sun, Feb 20, 2011 at 3:09 PM, Ernst Cozijnsen
wrote:
> Hi Manfred,
> few day.
> Ernst
>> Hi Ernst,
>> > Hi Manfred,
>> -Manfred
>> erhalten.
Beitrag von: rudolfkoenig am 21 Februar 2011, 11:40:35
:) I assume that you not asked for an update of FS20 to FHT, did you?
ELV Support must get a lot of very strange questions, at least this would
explain why one does not get a real answer to more interesting questions.
It still bugs me that my HomeMatic-security-hole report was not acknowledged...
