FHEM => English Corner => Thema gestartet von: paj am 03 Dezember 2016, 17:35:57
Titel: Newbie Help Required
Beitrag von: paj am 03 Dezember 2016, 17:35:57
I am pretty much a newbie with FHEM. I am using the RFXtrx433 receiver/transmitter connected to my Pi, I am controlling one make of 433 sockets with no problem, they were auto detected by FHEM and I was able to configure them and they work fine.
I have a new set of external 433 sockets from ALDI and I can see that the RFXtrx433 and TRX_PT2262 can see the codes coming from the socket remote but I am unable to configure any devices.
TRX_PT2262 Readings
state 202322320100 2016-12-03 17:37:27
The codes do not look like normal binary strings, here is the log from my TRX_PT2262
2016-12-03_16:58:02 TRX_PT2262 201312032200
2016-12-03_16:58:12 TRX_PT2262 200210301300
2016-12-03_16:58:13 TRX_PT2262 202322320100
2016-12-03_16:58:27 TRX_PT2262 201231110300
2016-12-03_16:58:40 TRX_PT2262 201312032200
Fhem gives me this kind of error when I try and use the codes to configure a device
error set name=RFS_ALDI_1_X_X deviceid=2002103013001 (needs to be base4 and has 12 digits)
Maybe I am making a newbie mistake here, or maybe the 433 sockets are not compatible, any help as to how to send the on off codes via fhem would be greatly appreciated!!
PAJ
Titel: Antw:Newbie Help Required
Beitrag von: fruit am 03 Dezember 2016, 21:58:23
Quite possible the devices are not compatible with RFXtrx433,. From memory the RFXtrx manual lists suitable devices though that does not mean other/newer devices will not work.
Are you able to test with a Windows computer and the RFMmngr program? That may give you an idea of whether the Aldi devices can be controlled with it or not
