98_Heating_Control, 98_WeekdayTimer: a bug fixed when starting a WDT or a HC an trying to switch in the past.
98_Heating_Control, 98_WeekdayTimer: a bug fixed when starting a WDT or a HC an trying to switch in the past. now being able to use on-till:13:30:30 as a parameter the parameter can now be a PerlcodeView Changes
Source: 98_Heating_Control, 98_WeekdayTimer: a bug fixed when starting a WDT or a HC an trying to switch in the past. (https://sourceforge.net/p/fhem/code/12715/)
