Hello,
I am planning to install a FS20 system in my new house, and was
looking at dimmers for CFLs when I discovered the Govena product
range.
They sell inexpensive (~20€ street price) 20W CFL light bulbs
including the radio-controlled dimmer (built-in!), along with a range
of dimmable CFL bulbs.
The protocol of communication is undisclosed on their website, and
uses 433MHz.
I guess it would be easy to "listen" to the remote controller they
sell to reproduce its messages with a CUL/CUN adapter and the FHEM
system.
What do you think of this idea?
Any other idea to have dimmable light sources "on the cheap" ?
Best regards from Paris, France
Jerome
I forgot the link: http://www.govena.com/en;govena,aslo,dimmable_energy-saving_bulbs.html
On 15 juin, 11:13, Jerome wrote:
> Hello,
> range.
> uses 433MHz.
> system.
> Jerome
You should not underestimate the time needed to reverse engineer a protocol.
You will learn a lot, which in itself may be worth of it, but I'd rather invest
my time and money into implementing some widely used protocol which is supposed
to be available longer. I dont think that the govena protocol belongs to this
category (without really knowing the company or who is backing it).
AFAIK there are FS20/HomeMatic dimmers available, but I dont know if they can
dim CFL bulbs.
Thanks a lot for your great comments.
However, their solution seems very smart.
To dimm CFLs you need usually 2 parts : a dimmer and a dimmable
ballast (to provide the high voltage for the tube).
They have integrated both within the compact design!! that is so
smart ! Then there is only one thing that requires wiring : the
control of the dimmer. and they were so smart that they included a
wireless system within the bulb! All that for 20€ each bulb, where the
FS20 dimmer receptor is alone >30€, then you have to add a dimmable
bulb or ballast...
What I will probably do is use at first standard FS20 switches and
then when their protocol will be known, add their bulbs for dimming...
Any other idea?
Best regards,
Jerome
> dim CFL bulbs.
the govena aslo system uses 433,92 MHz - FS20 868 MHz. So, there is no
way to control govena aslo bulbs with FS20 equipment. Maybe you can use
fhem with a second CUL with 433 MHz. In any case there is much
programming work to do... Worth it?
Best regards,
Martin
Am 15.06.2011 23:35, schrieb Jerome:
> bulb or ballast...
> Any other idea?
> Best regards,
> Jerome
Indeed, I was thinking of a gateway through the PC with two CUL
antennas.
it is frequent to see configuration with at least 2 kind of
protocols : FS20 + HomeMatic + One-Wire for example...
I will work on that in the future.
Anybody else interested ?
For your info, Govena is sold through Amazon : see http://www.amazon.de/dp/B001UQ6CUU
or http://www.amazon.de/dp/B001BX45EC
Best regards,
Jerome
On 16 juin, 16:15, marte-googlegro...@xmn-berlin.de wrote:
> Hi,
> Best regards,
> Martin
> Am 15.06.2011 23:35, schrieb Jerome:> Thanks a lot for your great comments.
> > wireless system within the bulb! All that for 20 each bulb, where the
> > FS20 dimmer receptor is alone >30 , then you have to add a dimmable
> > bulb or ballast...
> > Any other idea?
> > Best regards,
> > Jerome
not a bad product at all.
> antennas.
> For your info, Govena is sold through Amazon : seehttp://www.amazon.de/dp/B001UQ6CUU
> orhttp://www.amazon.de/dp/B001BX45EC
> Best regards,
> Jerome
> > Hi,
> > Best regards,
> > Martin
> > > bulb or ballast...
> > > Any other idea?
> > > Best regards,
> > > Jerome
