FHEM - Entwicklung => FHEM Code changes => Thema gestartet von: System am 18 Dezember 2016, 14:45:07
Titel: Revision 12796: 66_ECMD, 67_ECMDDevice: - if split is used, the strings ...
Beitrag von: System am 18 Dezember 2016, 14:45:07
              - if split is used, the strings at which the messages are split
                are still part of the messages
              - no default attributes for requestSeparator and responseSeparator
              - input of raw data as perl-encoded string (for setting
                attributes)
              - be more verbose and explicit at loglevel 5
              - documentation corrected and amended
Source: Revision 12796: 66_ECMD, 67_ECMDDevice:
              - if split is used, the strings ... (http://svn.fhem.de/trac/changeset/12796/trunk)
